TheViking Samba Member
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
Posted: Thu May 05, 2016 2:13 am Post subject: Re: DRD cranks, any good? |
I actually think the crank are made to him.
Are you interested in the kit ?
If yes, why ?
T |
jl_1303 Samba Member
Posted: Thu May 05, 2016 2:57 am Post subject: Re: DRD cranks, any good? |
I'd suggest to buy from air-cooled.net. John has quite a selection and he always stand behind the products he sells.
As to DRD, you can always read the DRD buyers' feedback page. |
mark tucker Samba Member
Posted: Thu May 05, 2016 8:53 am Post subject: Re: DRD cranks, any good? |
they arent real good at questions or trying to get work done like you want it.I got my 86mm crank from them,I doubt it's balanced right they would not answer any questions as to how they would do it and would that do it the way I wanted it done,(with flywheel witch I also got there then, and the keys installed with a gear(slip fit gear so no press or puller required)and I got zero responce....I would of even sent them a slip fit gear to keep.wish i had waited & got it from cb perf. but I was in a hurry......there was an empty spot on my shelf |
Posted: Thu May 05, 2016 11:51 am Post subject: Re: DRD cranks, any good? |
Im looking at it because it looks like btb for me. I may buy everything from acn then a dpr crank. Cheaper freight to norway |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Thu May 05, 2016 2:51 pm Post subject: Re: DRD cranks, any good? |
DRD sells the same Chinese forged cranks that everybody else sells. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Thu May 05, 2016 3:13 pm Post subject: Re: DRD cranks, any good? |
I would use a china crank over a welded crank any day. I have yet to axchuly have a welded crank in my hands that was right. I have a "new unused" welded 78.4 on the shelf that isant right.Ive had to rework costomers welded cranks that were not right. I see zero upside to the welded cranks now days. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Thu May 05, 2016 5:44 pm Post subject: Re: DRD cranks, any good? |
Mark please, by "right" what exactly do you mean? It'd help if we could keep an eye out for what you're finding. DPR cranks and DMS have excellent reputations. Is there an issue with theirs as well? |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Thu May 05, 2016 5:57 pm Post subject: Re: DRD cranks, any good? |
DPR used to have some runout problems but LONG ago, very long ago. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu May 05, 2016 7:53 pm Post subject: Re: DRD cranks, any good? |
Lingwendil wrote: |
buy your crank from DPR, better steel on the OEM cranks. |
so they use better oem steel than the oem steel vw used sweet.
Ive seen oil holes almost totaly welded up, gear runout over .002" . thrust serface at a 3 degree angle or more,burs hanging off and more.
as far as right. the flywheel should be balanced than put on the crank that has been balanced with keys installed&slip fit gear. how much do the keys weigh? how much material is missing from the key slots.......and missing from the gear key slots too so.. .Ive balanced well over a thousand assys. yes it makes a differance. but I reckon it's just a vw so... thattell do pig. |
Posted: Thu May 05, 2016 9:19 pm Post subject: Re: DRD cranks, any good? |
mark tucker wrote: |
Lingwendil wrote: |
better than the "hecho en china" 4340 cranks everyone sells.
i bought a 69 DRD CW a couple years back, and it came in covered in surface rust (heavy rust, not just easy polish, crusty and pitted) on all the journals and body, and was basically told to eff off.
"we cant control what happens after we ship"
mhmmm. looked like it was that way when they got it, unopened packaging, wouldnt refund.
and thats all im saying on that matter. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
