BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Wed May 25, 2016 4:34 pm Post subject: Advice on front sway bar for an Oval Convertible... |
Okay, I'm interested in your suggestions for adding a front sway bar and I'll probably mount a vintage style camber compensator on a '57 Deluxe Kabriolett. Stock height, stock suspension and a Okrasa engine with stock spit-case swing axle transmission. I will not be racing the car, but I do hope to improve cornering and handling, especially if I ever had to make an evasive swerving turn to avoid some idiot.
Has anyone with a basically stock Oval Beetle already been thru these improvements for your Bug and care to comment on your purchases and how your front sway bar and rear compensator combination has worked out? Does anyone have any suggestions for my planned improvements?
I asked the folks at "Sway away" via email if they made a sway bar kit for a stock-ish Oval Bug. I eventually received a reply from those folks and they said they have a PN9164 with urethane bushings. I can't find it in any on-line catalog, so I have no idea what the kit looks like or how it might work. Anyone using this already? Again, I'll also be adding a vintage rear camber compensator.
Talk to us!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
EVfun Samba Member
Posted: Wed May 25, 2016 4:53 pm Post subject: Re: Advice on front sway bar for an Oval Convertible... |
I've driven a number of late '50's and early '60's Bugs. The 40 horse ones do seem to handle a little better. I was even thinking of fitting the sway bar from a early '60's Bug under my '57. Fitting later parts under a Bug is about as vintage a move as one can get. _________________
Wildthings wrote: |
janerick3 Samba Member
Posted: Thu May 26, 2016 3:43 am Post subject: Re: Advice on front sway bar for an Oval Convertible... |
My '54 has had a stock front sway bar installed on the original front end as long as I have owned the car (36 years). It looks like it's always been there. _________________ Thanks,
Jan K. |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Thu May 26, 2016 8:28 am Post subject: Re: Advice on front sway bar for an Oval Convertible... |
stock sway bar and camber compensator is all you need. the front sway a way bar is too stiff for me. when pushed hard in a corner or freeway on ramp i used to( push) the front tires on my 68 cal bug with 195/50's on the front.but that is with a 2276 trying to gas it in a turn. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu May 26, 2016 9:59 am Post subject: Re: Advice on front sway bar for an Oval Convertible... |
Stock is a huge improvement over none at all, especially on a stock beetle. The sway bar won't know it's a convertible, so that makes no difference.. _________________ modok wrote:
slalombuggy Samba Member
Posted: Thu May 26, 2016 11:11 am Post subject: Re: Advice on front sway bar for an Oval Convertible... |
Make sure the camber compensator you get will fit a split case transaxle. All the modern ones are made for tunnel trannies. All the ones I've seen also seem to make the side covers leak like sieves. I would make a mount that fit on the frame horns if it were my car.
brad |
Posted: Sun May 29, 2016 8:37 am Post subject: Re: Advice on front sway bar for an Oval Convertible... |
Here is the exact camber compensator that I have laid away for the '57 Kabriolett.
http://www.thesamba.com/vw/forum/viewtopic.php?t=587621
This is the type of unit that doesn't use a bracket that attaches to the bottom of the split case transaxle. This one has rubber pads that cradle the frame horns. Very different than the more available bracket/tranny mount style. I haven't trial-fit it yet, the '57 Kab is buried away in my storage. Just hoping this will work well and make the Kab safer to throw around occasionally.
Some of you mention a "stock" front sway bar, but I don't believe that my '57 Oval Kab or my '55 Oval Sunroof had front sway bars in the Oval era. When did the front sway bar become standard on all USA spec Beetles? I'll be looking for recommendations on a complete add-on front sway bar kit for my Ovals...
Bill _________________ I'm looking for these license plate frames for my fleet:
EVfun Samba Member
Posted: Sun May 29, 2016 9:25 am Post subject: Re: Advice on front sway bar for an Oval Convertible... |
The front sway bar was introduced with the 1960 model year Bugs. You should be able to get the sway bar and clamps from any 1960-1965 Beetle and install it onto your front end. _________________
Wildthings wrote: |
