cbeck Samba Member
Posted: Thu May 19, 2016 6:54 pm Post subject: Re: so soon? |
I'm getting too old for this 12hour day stuff. I'ts hard to think about this when you can't walk upright after a 50 minute ride home. Thanks for the input, I appreciate it a lot. Some body pointed out I should cycle the front and check everything. I know better but for some reason it didn't cross my mind. Then I want to get the tires on and set the front down and see where it settles in at. I am planing on some more 7100's for the front. Of course Bilstein states you should not use their shock as a droop stop. I did manage to pick up the hardware to hold the rotors on the spindles. It keeps getting harder with my flaps only open tuesday thru friday. |
cbeck Samba Member
Posted: Sun May 22, 2016 9:28 am Post subject: Re: so soon? |
While screwing around on the newer computer I found some pics from the old computer of the first redo.
cbeck Samba Member
Posted: Sat May 28, 2016 6:46 pm Post subject: Re: so soon? |
Finally got some time to get in the garage. Got it sitting on the wheels after cycling the suspension and checking bump steer. Gained 8" in width and several inches of clearance. The al tierods are about 11/2 " too long. Going to have to be drilled and tapped. I think if I had to do it again,I would buy the bungs and some tubing and make my own.
Stopped by my flaps the other day. He said my heads came in and showed me these. The first thing I thought was I need a bigger cam. these arn't mine it turns out. I thought the castings looked pretty good for bugpack,err empi. Could have used a little polish in the chamber.
cbeck Samba Member
Posted: Sun May 29, 2016 6:29 pm Post subject: Re: so soon? |
Got the dashbar and steering fabbed today. Put on the regular wheels and tires and rolled it out for pics. Gained 5"in front with 17" to the bottom of the beam and 3"in the rear with 15" to the bottom of the solid tranny mount.
cbeck Samba Member
Posted: Wed Jun 08, 2016 3:26 pm Post subject: Re: so soon? |
Finished fabbing the lexan roof panels. still need to buff with a brick. Got to keep going forward so today I joined the club and procured this.
And I used it to do this.
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Wed Jun 08, 2016 3:44 pm Post subject: Re: so soon? |
Nice work. I like your new toy! _________________ HBB took me to BBV. |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1057 Location: St. Louis
Posted: Thu Jun 09, 2016 5:08 am Post subject: Re: so soon? |
Haha YESSS I'm so happy you saved the frame.
When I went over to your place after the bump from behind, I figured you would have to ditch it for new one. Looks like you saved it and saved it well!
I'm really curious if anyone has any direct experience using those 7100s as droop stops on the front beam. I could definitely see how using them in the rear would be bad, but what Richard said earlier about "Fox shocks and similar surviving the droop no issue" makes sense to me with the low spring rate in the front. I'm in the EXACT situation as you in the front end cbeck, and I'd love to know I didn't need straps or a hard lower stop. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Jun 09, 2016 6:11 am Post subject: Re: so soon? |
Nice job saving this one, it's looking good! I did notice one thing I want to point out. In this pic:
I noticed you have one of those chrome fuel pressure regulators plumbed in. Those things are terrible, they are about the worst "regulator" you can buy. I would suggest either getting a rotary pump with the correct output pressure for your dual carbs, shimming the stock fuel pump or adjusting the rod length to suit, or getting a real regulator. Save yourself the tuning hassle down the road! Ask me how I know |
cbeck Samba Member
Posted: Thu Jun 09, 2016 3:23 pm Post subject: Re: so soon? |
enjoy the ride, thank you thank you. In a former life I managed to save the lexan out of several roached full glass aluminum doors and used sectional door track bolts to hold it on.
basher, man nothing gets by u guys. That regulator has done me fine so far, but I do see all the posts saying not to use them. Cured my epc's {not supposed to use empi either] from loading up off road. Another one of those bridges to cross.
jimmy who? Haven't heard from you in at least 7 or 8 months. I see you have plates on yours, you ought to ride over[ its nice out now] so I can see how soft yours is with 2 leaves removed from each pack. I saw on stf where cwb? or getrdone just jacked up their front and stuck on a piece of angle and capped it for droop. I'm not sure I want to find out the hard way. I heard you got a place up in town. Did you watch the movie money pit first? |
cbeck Samba Member
Posted: Sun Jun 12, 2016 6:40 am Post subject: Re: so soon? |
Finished the front x and cut and tacked the 2 tubes for the front wall of the bed. Then came my o shit moment. Tried to slide the tank in from the top, first try fail. I think my options are to move the front wall to the rear about 3" or remove the trans and slide the tank in from the bottom. I would hate to lose 3" of bed length, but I would also hate to remove trans to remove tank. The tank is to go behind the x, just clearing the starter with the top of the tank just below the floor of the bed offset to the left and the battery next to it on the right. Tank fittings are to be in front of the front bed wall.
Posted: Mon Jun 13, 2016 8:39 am Post subject: Re: so soon? |
I agree, tank behind the X and maximize bed space if possible |
cbeck Samba Member
Posted: Mon Jun 13, 2016 2:55 pm Post subject: Re: so soon? |
Thanks. I think I've decided to loose a couple of inches of bed length to be able to remove the tank from above without yanking engine/trans. I guess thats why everything is only tacked together so far. Sorry chief, I missed it by that much. |
Posted: Tue Jun 14, 2016 4:19 am Post subject: Re: so soon? |
cbeck wrote: |
You'll be much happier in the long run if you do it right/the way you want it now! Setbacks suck, but it'll be worth it.
Are you using flux core wire on those tubes? |
cbeck Samba Member
Posted: Tue Jun 14, 2016 3:37 pm Post subject: Re: so soon? |
All the residue give it away? It is a handler 140 off of the work truck, I buy a spool once in a while. I work with it every day so I am used to it. |
dustymojave Samba Member
Posted: Tue Jun 21, 2016 4:13 pm Post subject: Re: so soon? |
Those tabs for the shoulder belts are set at the wrong angle. They should be welded on the tube so the belt pulls in line with the tab. I would reject it at a race.
I would have run those upper diagonal tubes to the upper beam clamps.
Do you have stop pieces welded to the beam tubes to keep the beam from sliding sideways in the frame? I use tube that's a slip fit over the beam tube, could use 1/4" thick strap bent to fit or bent as it gets welded. Cut to about 1/3 of the diameter and welded on against the side of the beam clamp. Upper or lower tube or both. Be sure you don't melt the trailing arm bushings when you weld the stops on. _________________ Richard
SoCalBajas Member
cbeck Samba Member
Posted: Tue Jun 21, 2016 7:02 pm Post subject: Re: so soon? |
Richard, I still have to install two horizontal bars in the x for the belts to loop over from the rear going forward thru my harness slots in seat- 0 to 10* below top of shoulders. I am trying to listen but between the heat and the bulging disc not much has been happening lately. 2 of my union brothers died on the job due to the heat last week.
I still have some work I want to do on the beam. I was thinking about using some 1" between the 2 tubes just outside of the bottom clamps with some 1/8 plate filling the space between the 1" tube and the shock towers. I think I still want some kind of droop stop also. It is beginning to look like I might not get it done this summer. All the little details are eating up more time than I guessed. This has been one of my busiest springs with graduation/ grad party, and getting the youngest boy in college, getting same son his first car, and 6 long months of the mother in law passing from cancer. My wife has been a train wreck for 6 months. |
Posted: Tue Jun 21, 2016 8:28 pm Post subject: Re: so soon? |
My condolences on all that...
If the belts are going to wrap over the top of the upper bars, then the tabs are correct.
Re the heat:
It's been 111° in the shade here the last 2 days. Only 104° Sunday. Forecast is for 104+ for the next week. My son is working in a factory with large ceiling fans and he's working in the shade. But it's often warmer air temp inside the RV factory than outdoors. The neighbor behind us is having his 1,200sq ft workshop garage re-roofed. The guys are done now after tearing it off and replacing the roof yesterday and today out in the sun. If I were their boss, I'd have had them working 6:00AM to 11:00AM. Then resuming at 6:00PM continuing to 8:00PM.
I understand people working in hot environments.
I really feel the droop stop is not necessary. The bolt on the upper arm contacting the lower arm is probably the simplest or 1/4" plate in an angle welded on the side of the upright. _________________ Richard
SoCalBajas Member
cbeck Samba Member
Posted: Fri Jul 01, 2016 6:32 pm Post subject: Re: so soon? |
Found a little time to waste in the garage. Added the metal on the outboard ends of the bams. Must have remembered wrong, the tubing rests against the upper beam mount. I am rethinking the forces may be able to use the leverage that the length of those mounts can create on the top tubes. Plan b will be using some 1/4" keystock that I have and welding onto the beam so they ride against the inside of the bottom frame beam clamps.
Bent my 2nd and 3rd attempts and used them to restore the lacing that was removed earlier.
Cut out the 2 pieces that will form the front of the bed and got 1 of the shoulder harness bars lightly tacked in place.
cbeck Samba Member
Posted: Sun Jul 10, 2016 6:04 pm Post subject: Re: so soon? |
Got the fuel tank down where I want it, but I need to cycle the suspension again. It should be close.
cbeck Samba Member
Posted: Sat Jul 16, 2016 5:47 pm Post subject: Re: so soon? |
Check clearance.
Bolt in tank and battery. Tack in frame horn supports.
I think I have enough support for the outer ends of the torsion, what to do for some more support for the middle of the torsion?
