jason Samba Member
Posted: Sun May 15, 2016 5:19 pm Post subject: Tach placement |
I have been trying to figure out where to put my tach so I can see it. The tray is a terrible spot to see. I think I will put it where the fuel gauge is and put the fuel gauge on the tray. I look at it less than the tach. Here is a picture of a trial fit.
Das67bus Samba Member
Joined: April 06, 2008 Posts: 242 Location: Prescott, AZ
Posted: Sun May 15, 2016 7:12 pm Post subject: Re: Tach placement |
This is where I put mine.....just below the parcel tray. Easy to see with a quick glance.
_________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun May 15, 2016 7:23 pm Post subject: Re: Tach placement |
Can you mount the guts of that thing in a bus gas gauge housing? The gapping from the Ghia-style ring would make me cringe every time I looked at it. _________________
EverettB wrote: |
FU#5 |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sun May 15, 2016 8:10 pm Post subject: Re: Tach placement |
I'm tall enough to not need a sun visor. 5'-6" should be tall enough to not need one either (in a '58 anyway... seats seem high). I used the visor bracket location to put a tach bracket I made out of 16ga steel (using the three factory holes)...
It sits up higher than I'm holding it. I can't see the screws now that it's mounted.
I put my fuel gauge & CHT gauge on opposing (mickey mouse ears) layout on the steering column (with moto-meter style brackets)
http://www.thesamba.com/vw/classifieds/detail.php?id=327614
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
jason Samba Member
Posted: Sun May 15, 2016 10:55 pm Post subject: Re: Tach placement |
I have one of the motometer column mount but I don't like seeing the sides of my tach, plastic. I was thinking about making a seal for the gauge, the gap is tiny but can be seen. I also don't have much space around my column. I have a swivel seat, it sits quite high, my knees are right in that area. |
54bug Samba Member
Joined: January 16, 2011 Posts: 142 Location: WashingtonDC
Posted: Mon May 16, 2016 4:51 am Post subject: Re: Tach placement |
Hi
I have a large VDO tach (with a finished back) mounted in my 1964 double cab. It's mounted to a damaged ash tray I picked up at a swap meet. I was never going to use the ash tray, and saved the original one. The tach sits just behind the windshield split and is visible and out of the way.
Mounting it here makes the installation reversible. I also picked up a spare under dash tray and mounted all the accessory gauges, warning lights, and stereo on the spare tray. Using modular plugs the tray and all the extras are easy pulled out for repair and service.
Food for thought.
Scott |
lightice Samba Member
Posted: Mon May 16, 2016 5:55 am Post subject: Re: Tach placement |
I like the ash tray idea, also can do the same thing on the radio cutout using a spare/home made. |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1783 Location: Santa Rosa, Ca
Posted: Mon May 16, 2016 6:24 am Post subject: Re: Tach placement |
Yours looks great where you have it, the PO of my bus thought it would look cool here
Britt Samba Member
Posted: Fri May 27, 2016 7:05 pm Post subject: Re: Tach placement |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Fri May 27, 2016 8:34 pm Post subject: Re: Tach placement |
I never understood the air vent panel spot for gauges, you need to take your eyes off the road to see any of them....
What I really don't like is the og spot for the Gen. & oil lights on the speedo pod, by the time I see one of those lit up, my motor would be toast... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Daddybus Samba Member
Posted: Fri May 27, 2016 10:56 pm Post subject: Re: Tach placement |
My gauge set up. Old picture.
I'm running a smaller 52mm tach now. |
67dubcab Samba Member
Joined: February 12, 2009 Posts: 214 Location: sebastopol C.A
jason Samba Member
Posted: Sat May 28, 2016 9:49 pm Post subject: Re: Tach placement |
I'm going to run the motometer mount. I bought it NOS years ago, time to use it.
busworks Samba Member
Joined: May 21, 2004 Posts: 201 Location: Moncks Corner,S.C.
Posted: Sun May 29, 2016 11:08 am Post subject: Re: Tach placement |
Big Bill wrote: |
I installed that same setup in my last bus as well. I had no problem seeing the tach while driving. Easy out of the corner of my eye. Also had warning lights wired into it as well. |
quartermilecamel Samba Member
Posted: Sun May 29, 2016 12:45 pm Post subject: Re: Tach placement |
The only problem I see with the overhead vent is if your vent gasket is leaky and your in a hard rain at 60mph, the guage isnt going to like that. The issue with the guages in the leg banger/knee destroyer area is well, .........your very short, with paper thin legs that dont mind requesting a guage/steering wheel column fly by when entering/leaving vehicle. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Sun May 29, 2016 5:36 pm Post subject: Re: Tach placement |
quartermilecamel wrote: |
The only problem I see with the overhead vent is if your vent gasket is leaky and your in a hard rain at 60mph, the guage isnt going to like that. The issue with the guages in the leg banger/knee destroyer area is well, .........your very short, with paper thin legs that dont mind requesting a guage/steering wheel column fly by when entering/leaving vehicle. |
You could silicone a rubber foam speaker baffle behind it, used to protect speakers in boats/door panels from water (and help sound).
_________________ 1957 Beetle
1966 Bus |
Posted: Mon May 30, 2016 3:16 am Post subject: Re: Tach placement |
I welded in a pod for mine. With a sealed wire harness going to it |
54bug Samba Member
Posted: Tue May 31, 2016 5:50 am Post subject: Re: Tach placement |
Hi All
I mounted a 90's 2.5 VDO tach on a spare Split window ash tray. The tach came with a back and mounting hardware for the dash, easily modified to mount to a flat surface. The finished back was chromed plastic, and not too ugly.
I found a chromed (probably delux) ashtray with missing tabs to hold the top onto the bottom half and with the retention clips bent. I modified the bottom half and drilled a hole for a hollow threaded tube (from a lamp) to hold the tach to the and the top to the bottom. The wires ran down the tube. After repairing the retention clips the ashtray with the tach mounted to it fit into the dash.
The tach sits just behind the window divider, it's visible but doesn't stand out from the exterior. The center mounted tach is easly visible and no holes were drilled in the dash. I retained the original ashtray.
In addition, all the accessory warning lights and wiring were attached to the tray below the dash... easily removable, if it was to return to stock
Scott |
Posted: Tue May 31, 2016 6:13 am Post subject: Re: Tach placement |
54bug wrote: |
Hi All
Scott |
Any pictures? |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2542 Location: Ocean Beach in Beautiful BLUE California
Posted: Tue May 31, 2016 9:48 am Post subject: Re: Tach placement |
54bug wrote: |
Hi All
Scott |
Thank you! I have been planning to mount the tach in a rusty ash tray that I had. My quandary was how to mount the tach. The hollow threaded tube in a genius idea. I will be happy to borrow your idea. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
