snowbug Samba Member
Joined: June 12, 2005 Posts: 167 Location: Oshawa Ontario Canada
Posted: Sat Jun 08, 2013 8:21 am Post subject: |
36hplandspeedracer wrote: |
Snowbug, NEVER run a power pulley on the street! It just turns the fan too slow to cool the engine for everyday street use. Just my 2 cents worth of caution......
Burly |
You don`t think a dog house oil cooler and power pulley would work? What size pulley is on a 356 engine? |
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Sat Jun 08, 2013 8:54 am Post subject: |
I ran an independent VW service facility for 18 years as well as served as a VW dealer service manager and power pulleys are just too small. Engines used daily will overheat. I have not owned a Porsche 356 with the smaller pulley so I cannot answer your question regarding them, but the smaller pulleys proved unacceptable when applied to a VW engine.
I run the standard VW size aluminum pulley on my dog house 36 and have had no overheating or noticeable power loss in city or freeway driving.
Just food for thought!
Burly |
Posted: Sat Jun 08, 2013 12:05 pm Post subject: |
Burly |
I was hoping to get some free HP from the power pulley. I was hoping to gain back cooling from the dog house. I don`t have any gauges or even testing time to know for sure if it would work out close to original set up. I will be running a stroker crank( makes engine run hotter). I will be running dual carbs(makes it run cooler). |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sat Jun 08, 2013 4:01 pm Post subject: |
snowbug wrote: |
Burly |
I was hoping to get some free HP from the power pulley. I was hoping to gain back cooling from the dog house. |
Well, it takes more hp to drive the bigger fan, so probably you will not gain anything. And when you use more hp, the engine get hotter. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
Posted: Sat Jun 08, 2013 8:20 pm Post subject: |
snowbug wrote: |
Burly |
If you decide to run the power pulley, I hope it works to your satisfaction.
Good luck. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13954 Location: Southampton U.K.
Posted: Sun Jun 09, 2013 5:05 am Post subject: |
John Moxon wrote: |
What the point of asking for expert advice...if you ignore it.
First law of forum life. |
Hi John, I have been working on VWs for 40 years But I am still learning. Ever watch the show Who Wants to be a Millionaire? When they poll the audience, some times the whole audience is wrong. I have read Gene Berg writings, but there is not much on the old 36 pounders. He was a smart guy from years of testing experience I know most of his info can be applied. In the early days , you would take out the 36 and chuck it into the scrap bin.Put in a 40hp or 1500 with header and almost double your HP. cheers Jim |
AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Sun Jun 09, 2013 10:00 am Post subject: |
Sounds like you want to rob Peter to pay Paul. Burlys right If you want a power pulley on the street your playing with fire.If your looking for racetrack results they work but for a driver they are trouble.Especially in stop and go traffic.You got to make up your mind is this a all out results engine or a easy to enjoy one. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Sun Jun 09, 2013 11:28 am Post subject: |
just skip the power pulley, and put an extra shim in your generator pulley. It'll cool just fine a low revs and idling around town, and slip a bit when you occasionally wind er up, freeing up a little hp. ($.02) |
Posted: Sun Jun 09, 2013 11:40 am Post subject: |
avus wrote: |
OH NO! now you have given me an idea for a clutch fan! |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Sat Jun 15, 2013 1:06 pm Post subject: |
I have doghouse shrouds/coolers on all 3 of my Bonneville 36hp engine. I used the small one in my daily driver SC for a year after Boneville, even in 120 degree Havasu summers and NEVER over heated the engine. My big engine 124hp on a flywheel dyno ran cooler then I thought with numerous 7500 rpm passes on the salt.
I'll have to wait and see how hot the supercharged runs.
For even better cooling use a late type3 tight finned oil cooler _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
dandand Samba Member
Posted: Sun Jun 16, 2013 10:14 am Post subject: |
re Power Pullies
We ran at Bonneville 2 years with a doghouse on our Stone Stock 36hp VW, and never had a cooling problem. (according to cylinder head temp gage).
Last year we also ran our version of a power pulley....we loosened the fan belt to the point that a good tug by one of the tech inspectors pulled it off!
Still, no change in cyl head temp. And we gained a few hp
Of course no one would advocate driving around for any lenghth of time with a slipping fan belt. And a one mile run in a stone stock 36'er isn't the worst case.
Don't know if this is helpful or not.
Dan
BeavergeezersRacing Team |
trackwesty Samba Member
Joined: May 11, 2004 Posts: 511 Location: Long Beach, CA
Posted: Sun May 29, 2016 3:08 pm Post subject: Re: Dog house cooler onto a 36hp motor? |
Has anyone done this with the engine installed. I know it's not much to pull the engine but just wondering _________________ AKA The Mummy |
Posted: Sun May 29, 2016 9:19 pm Post subject: Re: Dog house cooler onto a 36hp motor? |
Anything would be possible "Mummy" but you would spend a great deal more time fitting it than R&R'ing the engine and doing it outside the engine bay. Just sayin'.................... |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Thu Jun 02, 2016 1:52 am Post subject: Re: Dog house cooler onto a 36hp motor? |
quick question... would this kinda conversion be reversible?
the studs drilled out to 8mm could use 8mm-6mm repair studs in reverse?
what about the engine mount? _________________ 1954 L227 Type 113
1964 L31 Type 265 |
Posted: Thu Jun 02, 2016 1:26 pm Post subject: Re: Dog house cooler onto a 36hp motor? |
pig-pen wrote: |
what about the engine mount? |
Definetly Mummy! Just labor and a return to old parts with old style seals! |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Jun 02, 2016 4:00 pm Post subject: Re: Dog house cooler onto a 36hp motor? |
Lingwendil wrote: |
im trying to decide on building either a 40 horse or a 36 this summer for a vintage speed style engine. how well does the doghouse shroud and front (front is front) tin line up with the cylinderhead tin of the 36?
any pictures of it all together? |
I used the EMPI 36hp dog house fan shroud with heater duct outlets (with 1600cc heater boxes and did not have any serious issues or concerns.
Burly |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Sun Jun 05, 2016 10:36 am Post subject: Re: Dog house cooler onto a 36hp motor? |
Lingwendil wrote: |
Burly |
Is that a model? it just doesn't look real |
avus Samba Member
Posted: Sun Jun 05, 2016 10:57 am Post subject: Re: Dog house cooler onto a 36hp motor? |
Burly |
Any trouble using the 1600 heater boxes, Burly? When I modified the headers for the Rivets engine, I had to cut and turn all the flanges, because the exhaust bolt pattern was at a different angle than the 1600. |
