LED Replacement lights. Worth it?
tommyguns18
tommyguns18 is offline
PostPosted: Fri Jun 24, 2016 7:02 am    Post subject: LED Replacement lights. Worth it? Reply with quote
Wondering if drop in LED lights make a difference and if so who do you recommend getting them from?
Headlights, turn signals, brake lights ect...
Thanks!
raul arrese
raul arrese is offline
PostPosted: Fri Jun 24, 2016 7:25 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
Its all i have except for the HID headlights , brighter , cooler , less power , my rear was a kit purchased here made by Chip Birks , they work great .
" Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608
bluebus86
Banned
bluebus86 is offline
PostPosted: Fri Jun 24, 2016 8:57 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
the led interior light is great, got the two row one off amazon, super bright, lights like daytime in the car. the single row ones are good too, but the double row is the way to go. note my car is 12 volt2.
havent done led elsewhere on my bug, but did go with led stop and reverse light bulbs on my vanagon, much beighter, again from amazon, tried several, the more peicey ones were much brighter than stock, the cheaper ones not much if any improvement. I have seen the kkts with circuit board to fit inside the small tail lights of the 61 and back bugs, they are very good.
the led stop lights act faster than regular filiment bulbs, thag can give you that extra margin of safety from being rear ended.
rabbit20v
rabbit20v is offline
PostPosted: Sat Jun 25, 2016 7:25 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
I used the phillips brand LED drop in bulbs for my rear lights.
Much brighter than stock. The LED's are pointed backwards to utilize the stock reflectors so you don't end up with "hot spots" showing through the lens.
Turn signals
https://www.amazon.com/1157-P21-Philips-Replacemen...7+led+bulb
Running/Brake
https://www.amazon.com/Philips-1156-X-tremeVision-...6+led+bulb
I aslo made sure they were red LEDs so it didn't make the lens look pinkish.
Untitled by Steve, on Flickr
PostPosted: Sat Jun 25, 2016 8:32 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
I like those with the backward reflecting - are they available in 6-volt too?
I couldn't find a 6v listing.
Also does it say how many lumens they are on the package?
It's not listed on the Amazon links for those bulbs.
rabbit20v
PostPosted: Sat Jun 25, 2016 10:42 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
Forgot to mention that they are 12v bulbs.
Phillips doesn't tell you exactly how many lumens the bulbs put out.
The package only says "5x more light than a regular bulb"
Some websites I've seen say they're somewhere around 130 lumens.
PostPosted: Sat Jun 25, 2016 10:33 pm    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
Thanks.
I could be wrong but it looks like 130 lumens is the equivalent of about an old style 9 watt bulb.
But when it comes to LEDs it seems all that matters is what you see in real life - brighter or not.
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Jun 26, 2016 7:04 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
rabbit20v wrote:
The LED's are pointed backwards to utilize the stock reflectors so you don't end up with "hot spots" showing through the lens[/u
The hot spot and directional lighting of the LEDS are one reason I dont use them on any of my personal classic cars. ..
Those that actuallly reflect could be a game changer for those of us that want the correct old look and the modern efficient bulb.
It would seem those maybe would have a dead dark spot in the center though??
The main benefit of LED 's are real life brightness and the quick reaction for the stop lamps..
Other that that.. IMO .. on classic cars... it's just not worth it..
Maybe ad some pictures of actual lighting opertation.
I wouldn't be too surprised if they also worked on 6 volts.. but with less lumens,
LEDS are failry combatible regarding voltage less than spec.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
PostPosted: Sun Jun 26, 2016 7:48 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
I wonder that too... but don't want to spend $40 to find out they do not.
I have seen some specs before where 12v volt bulbs are listed as 7-24v and a couple people said they won't light up at 6v.
Maybe I should find some cheaper 12v ones just to try it.
Less lumens might be a problem since if 130 is equivalent to 9 watts, that's already 1/2 the wattage of the original 18-watt brake lights on my daily driver.
bluebus86
Banned
PostPosted: Sun Jun 26, 2016 10:30 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
one thing to consider is the color of the light, 130 lumens of red led light going thru a red taillight lense will be much brighter outside the red lense than 130 lumens of white incandesent light going thru the same lense
. The red lenses passes the red light and blocks all the other colors. if 100% of the light generated by the bulb is red, most all of it will make it thru the red lense. if the light generated is white, most of it will be blocked by the red tailight lense, and thus the lumens that make it out will only be a small fraction of that produced by the source bulb.
thus never use a white led for a tail light, only use a red one for brightest light out the lense. incandesent lights fail miserably in this regard as the filament glows white so that much of the output is lost in passing thru the colored lense.
physics 1A at work!
PostPosted: Sun Jun 26, 2016 10:45 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
Thanks.
Update on this:
After some more searching on watts vs. lumens, it looks like 130 lumens is more like 11.5 watts.
Yes, I have seen multiple people says to use only red LEDs in our red taillights, white LEDs will "blow out" the coloring.
VOLKSWAGNUT
PostPosted: Sun Jun 26, 2016 11:37 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
Yep ^ ... my thoughts exactly..
I really don't think the benefits of LED's as a replacement bulb outweigh the cost ..... yet.
Then there is the problem of the wash out, matching color LED for lens used and the LED light path direction not utilizing a lens to its full potential..
Not to mention.. a flasher change or a fake load is required..
Some love them, some dont..
They have no added benefit as a replacement for me.... (yet)...
The new cars that have LED's integrated are no doubt pretty impressive. Those were designed from scratch with LED's ... and are very different from a design stand point.
Case in point ..
I installed some free LED dome lights in my truck.. and frankly hated them and went back to the old incandescent ... on the flip side.. I used some others in the license plate spot on our Caddy (194's) and they certainly make the white POP bright on the reflective plate...
They certainly have a place in the auto market.
Im still optimistic though as the technology and availability has grown substantially.
I was one of those CFL replacement users ... those things are junk.. burned out in short time cost me more to buy.. so trying LED's in the home.. is a new venture for me.. I just used my first 8 LED's in our home during a kitchen remodel.. very impressed with the light output... So bright I had to install a dimmer. Cool ... Time will tell if they last as they claim.. Im skeptical
aka Ken {o\!/o}
flyboy161
flyboy161 is offline
PostPosted: Sun Jun 26, 2016 11:49 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
I got an LED dome light from a guy here at work (free). It's dim and has a bad habit of coming on all by itself. Not cool, when I walk out to the car at midnight and find my dome light on with doors shut. 😬
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483
PostPosted: Mon Jun 27, 2016 3:57 pm    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
Turn signals
Running/Brake
I thought I would post an update as I contacted Philips to see if these 12v bulb might happen to work on a 6-volt car since sometimes LEDs can work with less voltage.
They said No but to be honest I'm not sure if they said No because they won't light up or because of legal liability issues.
I might go buy some from the local parts store, try them, and return them if they don't work.
If my local store doesn't have a problem with me trying them out in the parking lot.
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jun 27, 2016 4:12 pm    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
I don't think we can generalize. Three is a thread about 12V LED headlights dropping out on our marginal voltage generator-based cars. But many LEDs are 5V devices. I think it varies by design and manufacturer.
rabbit20v
PostPosted: Wed Jun 29, 2016 8:11 am    Post subject: Re: LED Replacement lights. Worth it? Reply with quote
I could throw a 12v to 6v adapter and see if they still work.
