Iguana Samba Member
Posted: Mon Apr 25, 2016 2:04 am Post subject: Re: Rear disc brakes won't fit. Shims? |
Skulptorchaz wrote: |
I'm interested in cast mounts as well.
Hey Iguana, I looked at your Manx post. Good stuff, thanx! But I have a question, it looked like the rotor hugged the inside of the caliper. Is that the way to have it? Or did you get it more "centered"? Thanks for the pix and narrative.
Good info Wythac. I followed the book and the enclosed instructions so if they were made correctly, I should be OK.
I'm also using stainless braided lines, Brad. I understand they are better than rubber and look cooler.
Clone, I used a hardened washer as well. Oddly enough, my parts guy, who got me the washer, suggested not using it because it would be hard to manicure to fit.
Thank you again guys!!!
Chaz |
Hi Chaz,
I usually center the rotor in the carrier before I am done but as long as it clears it should be fine. The big thing is making sure you keep the caliper straight as having it off will cause issues with the mounts. |
Skulptorchaz Samba Member
Joined: June 11, 2013 Posts: 839 Location: S.E. Indiana
Posted: Tue Apr 26, 2016 5:33 am Post subject: Re: Rear disc brakes won't fit. Shims? |
Thanks guys!! |
Bill Kiene Samba Member
Joined: December 24, 2015 Posts: 29 Location: Davis, California
Posted: Tue May 03, 2016 11:32 pm Post subject: Re: Rear disc brakes won't fit. Shims? |
I just put on a new CB Performance rear IRS disc brake conversion kit I got from Bugformance in Sacramento..
First time doing this one.
It came with cast aluminum mounts for the calipers.
It came with 4 sets of different thickness of washers so I could get the calipers centered.
It went very smoothly. _________________ Bill Kiene
Davis, CA
Chuck Beck's Corsair Stripper Buggy - current
http://www.billkiene.com/cars/cars/
1970 Bug - bought new but sold
1978 Bus - bought new but sold |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Tue May 10, 2016 8:43 am Post subject: Re: Rear disc brakes won't fit. Shims? |
Any idea what the threads are for hoses? Are there any issues with an 24" flexible line? I'd like a banjo fitting at the caliper.
Thank you! _________________ If I knew what I was doing; I wouldn't be building a buggy! |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Tue May 10, 2016 9:07 pm Post subject: Re: Rear disc brakes won't fit. Shims? |
heywebonya wrote: |
Thank you! |
Here is the Banjo I used on my rear calipers.
Dorman Banjo bolts #H9449-2 M10-1.50 23.4mm length. Carquest #WBH 301H5375 _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Mon Jun 27, 2016 7:34 am Post subject: Re: Rear disc brakes won't fit. Shims? |
Still shopping around for brake line upgrades and need some more advice.
Clonebug, thank you for the banjo bolt information at the calipers (10 mm x 1.5 mm), I read your build and noted the clever use of a section of hardline. I do not know a place that will make that connection locally.
I am trying to find 24" braided hoses to replace the both flexible sections on each side of the swing arm.
24" braided stainless with banjo at the caliper and female VW 10 mm x 1.0mm at the other. Any concerns? Any suggestions that does not require adapters?
There are VW to -3AN.
Thank you _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 918 Location: Vernon, CT
Posted: Mon Jun 27, 2016 9:20 am Post subject: Re: Rear disc brakes won't fit. Shims? |
These guys can probably mkae what you need. I have used them before, great products. https://www.pegasusautoracing.com/productselection.asp?Product=3 Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
Posted: Mon Jun 27, 2016 7:34 pm Post subject: Re: Rear disc brakes won't fit. Shims? |
heywebonya wrote: |
Thank you |
Most any well supplied hydraulic hose and fitting store should be able to help you.
It is a common fitting in the brake line industry.
It's just a DOT approved compression fitting. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
