vtech Samba Member
Joined: August 15, 2006 Posts: 262 Location: CANADA,ONTARIO
Posted: Mon May 23, 2016 10:30 am Post subject: Lowered beetle shimmy |
I have a 63 beetle. When ever into over bumps the rear of the car shakes side to side. Is it because it lowered? I had a lowered beetle before and it drove way better than this one. This car is sometime scary to drive it feels like I will lose control of it. Any ideas on what may be causing the side to side shimmy in the rear? I installed new kyb Shock thinking may be the shock were bad. But it's doing the same thing. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon May 23, 2016 10:44 am Post subject: Re: Lowered beetle shimmy |
How low?
Like saggy bottom scraping the weeds or just mild?
How was it lowered?
Are the sides equally lowered?
Have you had it aligned at all?
Tires balanced?
Good tires?
Tire size?
Rear drums tight?
Trans mounts?
lots of variable.. shocks are only a small part of the equation.
If its drastically lowered its fighting itself for stability.
Swing axles are the worst offenders.
Extreme camber and the rear is steering itself and you are just along for the ride.
Hope you are insured..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
TastyTuner Samba Member
Joined: March 11, 2010 Posts: 108 Location: Tulsa, OK
Posted: Tue May 24, 2016 6:44 am Post subject: Re: Lowered beetle shimmy |
ive got the same issue going on but only at highway speeds. im currently lowered in the back approx two outers with notched spring plates (i have jerfabs to install). i find at approx 60-70mph when i go over any sharp bumps on the highway the rear will sway back and forth. at any speed lower than 60-70 its stable and fine.
my beetle is aligned and drives nice and straight. my thinking is that the excessive toe in at that speed is what is causing the issue. this is why i bought the jerfab plates also, he claims that at this ride height it cleans up most the toe in.
ill elaborate further.... i only seem to have this sway issue when on my staggered wheel set, front tires being 135/15s and rears being 205/65-15s.
when i swap on my smoothies with 135/15s fr and 165/15 rr the issue more or less is non existent. i think alot of the sway can also be contributed to contact patch.
ride height with smoothies
on sprints
_________________ TastyGarage |
vwoldbug Samba Member
Posted: Wed Jun 29, 2016 7:17 pm Post subject: Re: Lowered beetle shimmy |
It can't be aligned with rear wheels setting like that |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Jun 29, 2016 7:32 pm Post subject: Re: Lowered beetle shimmy |
You need longer spring plates or spring plate extensions or dropped plates to run that low. If not you rear toe adjustment will be way off and the car will handle poorly.
Do you have sealed rear axle bearings? If not, your tearing them up rapidly along with axle fulcrum plates. |
