jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Fri Apr 29, 2005 7:00 am Post subject: door doesnt shut |
my door does not shut all the way. how do you adjust it?
edit _________________ www.cultwagen.com
E-boyz67 Samba Member
Posted: Fri Apr 29, 2005 10:53 pm Post subject: |
You need to loosen the striker plate and move it in then close the door to check the alignment. _________________ 2-67
1-67vert |
Travis Samba Member
Joined: August 07, 2003 Posts: 263 Location: Battle Ground Wa
Posted: Sat Apr 30, 2005 10:02 am Post subject: |
I recently adjusted my door because I was having the same trouble. My trick was I left the striker plate slightly loose, and slammed the door hard to it went to the second click. Then I adjusted my door for how I wanted it to fit. I then pushed the door in very little, while holding the handle, and then pulled the door out. I tightened down the plate, and closes perfectly now. |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Sat Apr 30, 2005 10:03 am Post subject: |
you might try and go into detail of what happend or what you did before the door stopped closing.
with out a pic it's hard to tell what is up without some kind of idea. _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
Posted: Sun May 01, 2005 8:41 pm Post subject: |
it acually shuts just not flush with the body by about 1/4 inch _________________ www.cultwagen.com |
Foxx Uncle Meat
Posted: Mon May 02, 2005 5:24 pm Post subject: |
Foxx4086 JHC wrote: |
with out a pic it's hard to tell what is up without some kind of idea. |
still again what you ask doesn't give any reffrence to what happend. _________________ Frank
OG JHC
59 panel
Posted: Mon May 02, 2005 5:37 pm Post subject: |
Just got the car two weeks ago. was like that when i got it _________________ www.cultwagen.com |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Mon May 02, 2005 5:56 pm Post subject: |
Oil those hinges PRONTO!
- Scott _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Tue May 03, 2005 9:35 am Post subject: |
just oiled _________________ www.cultwagen.com |
vwible Samba Member
Joined: January 02, 2005 Posts: 160 Location: East Windsor, NJ
Posted: Wed May 04, 2005 5:47 pm Post subject: door binds at front edge |
I can slam my 75's door (driver's side) shut, but there is no gap at the front edge. It binds against the A pillar. The door itself is showing some signs of stress at the upper hinge, as it actually touches the A pillar. The gap at the back edge between the B pillar is about the thickness of a pencil = 5/16". How do you fix this? Place a shim between the hinge and the pillar? Bend the hinge? |
volks67beetle Samba Member
Joined: April 16, 2004 Posts: 916 Location: Sturbridge, MA
Posted: Tue May 10, 2005 5:15 am Post subject: |
does that door drop to the ground a little when you open it???? |
vwible Samba Member
Posted: Tue May 10, 2005 4:09 pm Post subject: door doesnt shut |
No, there is no sag in the door when you open it. I believe the pillar to be solid. I've only had the car since November, so I do not know prior accident history. If the door could just be moved back a 1/16", both top and bottom, there would probably be enough clearance so you do not have to slam the door to close it.
Also, I need to do the heater channels, so I'll need to work carefully to keep things aligned.
Posted: Tue May 10, 2005 5:46 pm Post subject: |
Ouch, i herd replacing the heater channels is a pain in the @#$% just did my passenger floor pan a few weeks ago. _________________ www.cultwagen.com |
vwible Samba Member
Posted: Wed May 11, 2005 5:56 pm Post subject: door doesnt shut |
Don's want to change the topic in the thread. Anybody tried adding a shim between the body and the hinge, to push the door back a bit, so it doesn't touch the front pillar? _________________ 1970 Tin Top Walk Through Bus |
