SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Mon Aug 15, 2016 8:11 am Post subject: Steering Column Wiring Mistery |
Hi all, I have a steering column that I do not know if its original to the car (71 Coupe) but I doubt it because when I took the car apart the wiring was butchered.
I have looked around the wiring schematic for a 71 but they either don't show all the wiring or I have some other year column.
My column has 14 wires and what I find in wiring schematics show only 10 wires.
How can I find what year this column is from so I can figure out what the extra 4 wires are for?
_________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Aug 15, 2016 2:32 pm Post subject: Re: Steering Column Wiring Mistery |
Its likely that someone changed out the turn signal assembly and or ignition switch. The new replacements will work with more than one application, hence the extra wires.
Just use the wires that match up with the diagram and you should be fine. _________________ Ghia Owner Emeritus |
Posted: Mon Aug 15, 2016 3:06 pm Post subject: Re: Steering Column Wiring Mistery |
NOVA Airhead wrote: |
Just use the wires that match up with the diagram and you should be fine. |
Thank you for the reply. I'll move forward with what maches the electrical diagrams. _________________ Jesse
71 Ghia
art_lessing Samba Member
Joined: February 20, 2014 Posts: 154 Location: Sacramento
Posted: Tue Aug 16, 2016 1:43 pm Post subject: Re: Steering Column Wiring Mistery |
gray
gray/black
gray/red
these are for Euro cars...tape them off, wind them up out of the way, or what I did was get into the turn signal switch and remove the connection and wires completely. As for the other one deduce through elimination.
DanQ |
Posted: Tue Aug 16, 2016 3:13 pm Post subject: Re: Steering Column Wiring Mistery |
art_lessing wrote: |
gray
gray/black
gray/red
DanQ |
What are they used for on a Euro cars? _________________ Jesse
71 Ghia
Posted: Tue Aug 16, 2016 4:03 pm Post subject: Re: Steering Column Wiring Mistery |
Posted: Tue Aug 16, 2016 4:27 pm Post subject: Re: Steering Column Wiring Mistery |
Thank you for that diagram. It is perfect since I'm doing an aftermarket 21 circuit wiring harness and it shows this isolated section.
I am grateful that you guys show up here and take the time to sort out and through all the craziness so thanks again art_lessing and NOVA Airhead. _________________ Jesse
71 Ghia
