arpbus Samba Member
Posted: Tue Aug 16, 2016 9:01 pm Post subject: Can someone suggest correct distributor. |
I have a 69' fastback with a 1904 and Dell 36's with a automatic transmission. The distributor in it is a svda 034 from hot-spark. Doesn't seem correct for my application. Advance curve wrong. The correct distributor number with automatic is 311-905-205M or 311-905-205AD. Not really finding either of these in classifieds. Anyone have a alternative that will work correctly. Thanks in advance |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Aug 16, 2016 11:05 pm Post subject: Re: Can someone suggest correct distributor. |
I have a core 311 905 205 M that I can send your way. You can PM me. _________________ Roads Scholar &
Erik G Samba Member
Joined: October 16, 2002 Posts: 13269 Location: Tejas!
Posted: Wed Aug 17, 2016 7:50 am Post subject: Re: Can someone suggest correct distributor. |
check that your dells are giving enough vacuum for the advance can, check that the advance can actually works (suck on the vacuum line) and lastly, check that the rubber grommets for the electric module wires are not in the way and keeping it from advancing. I've seen that on those and the pertronix , crap right out of the box and you have to fix it to make it work _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
