pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Fri Aug 19, 2016 2:18 pm Post subject: Beetle body to floorpan washers |
quick question, is there a reason for the shape of the stock floorpan washers?
if I wanted to could I use a flat washer instead? or even an L profile rather than a U profile.
cheers _________________ 1954 L227 Type 113
1964 L31 Type 265 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat Aug 20, 2016 5:52 pm Post subject: Re: Beetle body to floorpan washers |
I guess you could use flat washers. Would need to be something heavy and you will end up cutting flats into them anyway because things dont quite line up. Way more work than what a set costs CIP1 sells a set of 10 for $13. Seriously, if a flat washer was fine, VW would have used them. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sat Aug 20, 2016 11:18 pm Post subject: Re: Beetle body to floorpan washers |
absolutely. of course they would... but I want to run a fuel line tucked up in the channel, so if I had an L section I can use pipe clips on the opposite side... _________________ 1954 L227 Type 113
1964 L31 Type 265 |
Posted: Sun Aug 21, 2016 6:29 am Post subject: Re: Beetle body to floorpan washers |
That makes sense - small lengths of angle bracket would be handy for that _________________ D-Dubya Manx clone - 63 Short pan,1914.
