redbug74 Samba Member
Joined: June 15, 2004 Posts: 292 Location: Far West Texas
Posted: Wed May 11, 2005 10:17 am Post subject: Best place for senders |
I have a 69 Square back and would like to monitor the engine a little more closely. Where would be the best place for the oil temp. sender and the pressure sender. The PO converted the car to dual solex 32 carbs. I noticed an adapter coming off the oil cooler. Doesnt look like there would be much room for a T-fitting for both temp. and pressure senders. Has anybody had good or bad luck with senders in other locations? I had planned on VDO electrical senders as opposed to mechanical presure sender. Any suggestions out there. Thanks for any help. |
Poor Realist Samba Member
Joined: August 25, 2003 Posts: 305 Location: Stockholm SWE
Posted: Wed May 11, 2005 11:24 am Post subject: |
oil temp - use the relief type sender. It fits in the screw hole where the oil relief spring is.
oil pressure - use a grease gun hose as an extender. you can tee it to have the original idiot light and the pressure sender. Keep the og idiot.
CHT - under #3 sparkplug.
Go for VDO if you are on a budget. If not, go for westach. www.westach.com |
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Wed May 11, 2005 11:41 am Post subject: |
Since I am using a new Universal case with T1 oil dipstick I am also using this as cheap insurance to monitor temp...
http://www.geneberg.com/cat.php?cPath=5_118_2734 _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
Disco Dave Samba Member
Joined: March 24, 2005 Posts: 20 Location: Edmonton,Alberta,Canada
Posted: Wed May 11, 2005 11:48 am Post subject: |
oil temp - Side of the deep sump.
oil pressure - Tee fitting on top of the oil cooler with stock idiot light |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu May 12, 2005 10:16 am Post subject: |
And CHT sender? _________________ Everything known to man has been written.
Readers are Leaders! |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu May 12, 2005 10:41 am Post subject: |
Air-Cooled Head wrote: |
And CHT sender? |
Under the upper-front head nut on #3. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
