buggingInFL Samba Member
Posted: Tue Aug 23, 2016 7:48 am Post subject: Need carburetor identification help |
So the carburetor on my engine is a mystery to me. There appears to be no markings on it except for one number on top that doesn't seem to be easily identifiable. I'm hoping someone here can help me definitively identify what it is so i can decide if I need to replace it or not. Here's some pics:
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Aug 23, 2016 7:51 am Post subject: Re: Need carburetor identification help |
looks like a Chinese replacement carb.
Dual port engine? And what's the problem you think it needs replacing? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Tue Aug 23, 2016 7:56 am Post subject: Re: Need carburetor identification help |
It's a 1968 single port 1500 autostick. There isn't a specific problem I'm trying to address other than trying to get the timing right, but it's tough to find good advice when I don't even know what my carb is. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Tue Aug 23, 2016 8:11 am Post subject: Re: Need carburetor identification help |
My guess is its an H30/31 copy if its a small flange carb. Your timing is more of a function of the distributor, BUT if you have a vacuum canister on it, then the carb does matter. Particularly with an auto-stick _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Aug 23, 2016 8:30 am Post subject: Re: Need carburetor identification help |
Right now it has an 009 on it, that I want to replace with an SVDA, but I know I need to match up the distributor with the carb. I'd rather not spring for a new carb as well if this one is good enough, but I don't know what distributor to buy to match up with it. |
Posted: Tue Aug 23, 2016 8:37 am Post subject: Re: Need carburetor identification help |
2 things and you have to bear with me because I have no experience with an autostick, so anything I say about that is "things I read on the interent".
#1 IF you have an H30/31 copy, there is not enough vacuum signal to make an 034 SVDA work, so that will be a waste of money.
#2 look at the old volks home website on distributor applications. I am almost 100% sure there are autostick specific distributors AND carbs. This is the part where I am just parroting what I have read. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Aug 23, 2016 8:46 am Post subject: Re: Need carburetor identification help |
Yeah, it's the point #1 you mention that I want to clear up before I go any further. If the carb is a non-starter with a SVDA, then I'll just replace both. If not, and I can save some money for now, then all the better.
So, I guess the sticking point is figuring out for sure whether that carb will work with an SVDA when you come right down to it. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13843 Location: White Mountains Arizona
Posted: Tue Aug 23, 2016 8:49 am Post subject: Re: Need carburetor identification help |
The correct distributor for the 68 auto stick is as follows;
Bosch no. VW no.
0231 115 056 113 905 205P
0231 115 078 113 905 205AA
use the search function and locate one here. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Aug 23, 2016 8:52 am Post subject: Re: Need carburetor identification help |
Yeah, but will my carb work with that distributor or do I have to get a new carburetor too? |
topconker Samba Member
Posted: Tue Aug 23, 2016 9:29 am Post subject: Re: Need carburetor identification help |
Sorry to hijack the thread.
Looking at the photos there are 2, (at least), blanked tubes showing, which presumably are vacuum pipes?
Would it be possible to take a vacuum off of one of these to run a remote servo for the rear brakes?
TC |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8689 Location: Sunset, Louisiana
Posted: Tue Aug 23, 2016 9:39 am Post subject: Re: Need carburetor identification help |
You need a vacuum gauge to test how much vacuum that carb pulls while running. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Tue Aug 23, 2016 6:23 pm Post subject: Re: Need carburetor identification help |
IF the carb is a copy of an H30/31 you will not have enough vacuum to make it work. Have no clue what the hell you have except what it looks like. How the vacuum circuit is designed is a total guess unless you measure it as mentioned and even at that - how it comes in will make a difference in how the distributor will advance.
There are other combos for small flange carbs that work well. I just dont know what they are since I run the 34/ SVDA on any stock 1600s.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2400 Location: Gladstone, Ore
Posted: Tue Aug 23, 2016 8:39 pm Post subject: Re: Need carburetor identification help |
Don't buy new parts until you time the engine with a timing light, 30° BTDC with RPM's up around 3500 or where the advance is all in.
report back _________________ 1972 1302
HPMX 40's & 019 |
Posted: Wed Aug 24, 2016 6:10 am Post subject: Re: Need carburetor identification help |
I set the timing statically to 7.5 BTDC and adjusted the idle speed by turning the "big" screw on the side of the carburetor until it would idle ok for a few minutes, then it just stalls. It also seems to start running rougher if I rev it up to higher RPMs.
I've got to pick up a few things like a portable tach, fuel pressure tester (new fuel pump), vaccuum gauge, and get my hands on a timing light before i can go much further I think. Unfortunately, I have to travel to Kiev for business for the next two weeks so I'll probably have to put it on hold until I get back.
Also, I don't think I mentioned it on this thread, but this is a newly rebuilt engine that i did myself (first time) so pretty much anything could be wrong.
I'll just start eliminating possible problems one at a time (do a valve adjustment, need to change the oil, etc.).
I didn't really intend this as a thread to diagnose problems as much as to figure out if I should replace the carb when I replace the distributor (want to switch to an SVDA), but it has kind of turned that way.
Thanks for the help though and I'll report back when I get some new information. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15975 Location: North Florida, USA
Posted: Wed Aug 24, 2016 9:52 am Post subject: Re: Need carburetor identification help |
buggingInFL wrote: |
You need to determine if your carb's vacuum advance port is connected to venturi vacuum, ported vacuum or both. This thread from glutamodo goes into detail the differences between the different carbs.
http://www.thesamba.com/vw/forum/viewtopic.php?t=185095
The later SVDA and DVDA distributors must be mated with a carb that uses ported vacuum for vacuum advance. Ported vacuum will see more than 12in-Hg of vacuum which is what the SVDA/DVDA distributors need to reach full vacuum advance. The earlier SVA distributors like yours only needed only around 4in-Hg to reach full advance. You see why it is important to match the carb + distributor especially when it comes to a distributor that needs a vacuum signal.
This pic from glutamodo's thread shows the upper vacuum advance port inside the carb throat of an H30/31. If you have this brass tube, try spraying carb cleaner into it and see if fluid seeps out from the vacuum advance port. If it does, your carb uses venturi vacuum for vacuum advance and is not fit for matching up with an SVDA distributor.
This upper area is in the venturi (narrow) portion of the carb throat. Vacuum here (technically low pressure) increases as the speed of the air flowing thru the carb increases. This means vacuum increases due to engine rpms. The larger volume of airflow needed at higher rpms means the air must flow FASTER thru the venturi. Fast moving fluids create less pressure. This is the Bernoulli effect. This signal is not affected by load on the engine where ported vacuum changes due to engine load (except at idle).
topconker wrote: |
Would it be possible to take a vacuum off of one of these to run a remote servo for the rear brakes? |
You will need to test the rear (rear is rear of car) facing vacuum ports on the carb. In the above pics these are capped off since they are not used. Sometimes these ports are connected to intake vacuum. Typically, it is this strong vacuum you want when you are working with vacuum boosters. Also look at the intake manifold. In some years there were ports on the side of the intake "neck". Other times the ports were on the end castings. These are direct intake vacuum port. Be careful that your vacuum booster does not require too much vacuum and will affect your engine idle quality. The last thing you want is the engine to die because your brake draw too much vacuum! _________________ AshMan40
Posted: Wed Aug 24, 2016 11:40 am Post subject: Re: Need carburetor identification help |
Not sure if this was discussed or not. You have a idle fuel cutoff - that can on the drivers side. Apply power and remove it - you should hear it click each time. If not, then its bad and you will have very eratic idle, if it will idle at all. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu Aug 25, 2016 7:10 am Post subject: Re: Need carburetor identification help |
That's great info, thanks. I'll check that stuff out when I get back if Putin doesn't blow up Kiev while I'm there. |
