cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Tue Aug 30, 2016 11:27 am Post subject: squeaky slider windows against screen |
How I hate that squeaky sound each time I open or close the sliding windows on slider door and by the sink . I see that the glass surface is rubbing against the inside vertical edge of the screen. How does one eliminate this sound? file down that edge a little so that there's a very small gap between it and the glass surface? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Tue Aug 30, 2016 12:17 pm Post subject: Re: squeaky slider windows against screen |
file = yes
1st though check installation for misalignment _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Tue Aug 30, 2016 12:18 pm Post subject: Re: squeaky slider windows against screen |
Oh, and then there is the window channel slider that often wears out. a nice Sambatisa is making replacements search classifieds or see one of the vendors. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Tue Aug 30, 2016 1:00 pm Post subject: Re: squeaky slider windows against screen |
Hi,
You mean rubbing on the bug screen leading edge? If so try gluing on a strip of fleece to the ledge behind the leading edge. I did that to stop no see ums from getting into the van between the leading edge and the glass. Has the added benefit if a soft sliding surface.
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
