curtp07 Samba Member
Posted: Tue Aug 30, 2016 3:57 pm Post subject: G&$ D:$&@ Brake Drum |
75 Westy.
Friggin rear drum WILL NOT come off.
E brake loose, stars won't move, pb blaster, heat, bang, repeat.
Even sacrificed the backing plate to get an edge to ping with a brass punch...NOTHING.
Remove the entire hub and go from there? Thoughts?
Thanks! _________________ Subaru |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Tue Aug 30, 2016 4:08 pm Post subject: Re: G&$ D:$&@ Brake Drum |
did you remove the 2 bolts holding the drum to the hub?
is it stuck on the hub, or jiggly and can't get past the shoes? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Aug 30, 2016 4:16 pm Post subject: Re: G&$ D:$&@ Brake Drum |
Hey Skills thanks!
Yea, bolts removed, no jiggling. Thought was maybe the drum had a ridge behind the shoes or something but no movement at all....it turns ok, just no play between the drum and hub... _________________ Subaru |
Posted: Tue Aug 30, 2016 4:24 pm Post subject: Re: G&$ D:$&@ Brake Drum |
do you have 2 ball peens?
take one and place between the lugs. smack hard and fast with the other. go around in between each lug and do the same till she pops. it will pop.... _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Aug 30, 2016 4:25 pm Post subject: Re: G&$ D:$&@ Brake Drum |
Will do! _________________ Subaru |
Posted: Tue Aug 30, 2016 4:30 pm Post subject: Re: G&$ D:$&@ Brake Drum |
careful not to hit the lug studs...
hit it like you mean business.... It'll pop _________________
Jake Raby wrote: |
Brian wrote: |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
danfromsyr Samba Member
Posted: Tue Aug 30, 2016 5:13 pm Post subject: Re: G&$ D:$&@ Brake Drum |
and ear protection..
and gloves. _________________
Abscate wrote: |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Tue Aug 30, 2016 7:53 pm Post subject: Re: G&$ D:$&@ Brake Drum |
Must be an east coast fix. I myself would use my hub puller _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
kooper271 Samba Member
Posted: Tue Aug 30, 2016 7:58 pm Post subject: Re: G&$ D:$&@ Brake Drum |
Not the best solution, but i have a big sledge hammer that I call the negotiator just for solutions like this... Supposedly it could shock the differential so unbolting your cv joints may be a good idea but I never do. |
Posted: Tue Aug 30, 2016 8:07 pm Post subject: Re: G&$ D:$&@ Brake Drum |
aeromech wrote: |
Must be an east coast fix. I myself would use my hub puller |
how? it's a floating drum stuck to the hub. you can't get a puller behind the drum due to the lip.
you west coasters.... _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Aug 30, 2016 8:15 pm Post subject: Re: G&$ D:$&@ Brake Drum |
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Tue Aug 30, 2016 9:11 pm Post subject: Re: G&$ D:$&@ Brake Drum |
*Gary drops the mic*
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Wed Aug 31, 2016 12:10 am Post subject: Re: G&$ D:$&@ Brake Drum |
I always remove the hub to do brake work. This way you can replace the outer wheel seal while you are at it and everything else is just easier. |
Posted: Wed Aug 31, 2016 9:15 am Post subject: Re: G&$ D:$&@ Brake Drum |
I have to say you are all great and thanks again!
Pounded it like Skills said. Damn that worked. Soaked it overnight first.
Picked up a hub puller from aeromech's photo.
Good safety advice as well.
Don't normally pull the hubs for brake work, but may as well do the bearings while I'm there.
Pics to follow! _________________ Subaru |
Posted: Wed Aug 31, 2016 9:33 am Post subject: Re: G&$ D:$&@ Brake Drum |
when you pound it like I do, everything works _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Aug 31, 2016 10:06 am Post subject: Re: G&$ D:$&@ Brake Drum |
skills@eurocarsplus wrote: |
take one and place between the lugs. smack hard and fast with the other. go around in between each lug and do the same till she pops. it will pop.... |
Hitting one hammer with another is not good practise. I have seen people get big holes blown in their cheeks from doing so. A piece of soft metal like aluminium, lead, or brass is safer to whale against. |
SGKent Samba Member
Posted: Wed Aug 31, 2016 10:31 am Post subject: Re: G&$ D:$&@ Brake Drum |
Wildthings wrote: |
I like having a porpoise when I do things. When you whale on something and it flippers over then you've created a fluke. I know that sounds like a lot of blubber but its important to harpoon things that can blowholes in a person's cheek. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Aug 31, 2016 11:28 am Post subject: Re: G&$ D:$&@ Brake Drum |
the comedy....oh, the comedy _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Aug 31, 2016 3:02 pm Post subject: Re: G&$ D:$&@ Brake Drum |
