Tcash Samba Member
Posted: Sun May 01, 2016 9:56 am Post subject: Re: Front retractable seatbelt length. |
Mine are short. Same thing cannot reach passenger door and if your a little big in the belt line they will not fit without extenders or extensions.
Tcash |
islandtime Samba Member
Posted: Sun May 01, 2016 10:44 am Post subject: Re: Front retractable seatbelt length. |
Tcash wrote: |
Tcash |
Tcash, are yours the gowesty ones? I'm a 42 waist but my 38-40 friends also find the belt a bit snug. |
Tcash Samba Member
Posted: Sun May 01, 2016 11:12 am Post subject: Re: Front retractable seatbelt length. |
islandtime wrote: |
Tcash wrote: |
Tcash |
Yes, Go Westy belts. A 38-40 waist is not really snug, but there is not much room to move around.
Tcash |
Posted: Sun May 01, 2016 11:17 am Post subject: Re: Front retractable seatbelt length. |
Thanks, what do your belts measure fully extended? Pulleout all the way and measures from the reel to the point where the opposite end of the belt attaches. |
Tcash Samba Member
Posted: Sun May 01, 2016 11:43 am Post subject: Re: Front retractable seatbelt length. |
Total length roughly 118".
Center of reel, through shoulder strap, back to mounting bolt. With belt fully extended.
Tcash |
Posted: Sun May 01, 2016 12:05 pm Post subject: Re: Front retractable seatbelt length. |
That's 10" longer than mine. That would make a lot of difference. According to pic in the gallery that explained how to determine the proper length, I would need 120 to be comfortable and that would be a minimum..
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Sun May 01, 2016 1:29 pm Post subject: Re: Front retractable seatbelt length. |
I have the eBay Humvee belts in the Single Cab. There were a tad short once installed. I got a pair of seat belt extenders on eBay for under $12. Easier and cheaper that buying/installing a whole new set of belts. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Sun May 01, 2016 1:47 pm Post subject: Re: Front retractable seatbelt length. |
The seat belt extender would be cheaper, I just worry about the safety of a buckle to a buckle and the shifted position of the main belt. I know it's done everyday, some of my ocd over thinking kicking in.
Just found these. They are 133" fully extended. I was hoping to order from a ACVW shop but no one seems to know or have the right length.
http://www.seatbeltsplus.com/product/WSCH14134C-18.html |
Tcash Samba Member
Posted: Sun May 01, 2016 2:51 pm Post subject: Re: Front retractable seatbelt length. |
18" cable a little long. Wonder if they have shorter ones?
Tcash |
Posted: Sun May 01, 2016 3:55 pm Post subject: Re: Front retractable seatbelt length. |
Tcash wrote: |
Tcash |
Yes, I copied the wrong link when I was looking at the different options. They have a 12" that matches the length of the original non-retractable belts that were in my bus and the ones empi supplied with their kit.
http://www.seatbeltsplus.com/product/WSCH14134C-12.html |
Tcash Samba Member
Posted: Sun May 01, 2016 4:04 pm Post subject: Re: Front retractable seat belt length. |
Could you please post some pics of them installed and let us know how they work.
Thank you
Tcash |
Posted: Sun May 01, 2016 4:20 pm Post subject: Re: Front retractable seat belt length. |
I have ordered them so as soon as I can get them installed I will get some pics. I'll even model one to show range of motion. |
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Sun May 01, 2016 9:58 pm Post subject: Re: Front retractable seat belt length. |
Make your own - it really isn't difficult. I bought a roll of seatbelt webbing on Amazon and took it to my local upholstery shop. Pulled the old one out and stuck a screwdriver in the end to stop it winding back. Pulled the fabric and steel rod that anchors it out and stitched the rod into the new material and fitted it through the spool. Add the shoulder locating tab, bayonet and end tab and you are done. I am going for 120' total length, and you won't squeeze much more in the standard VW unit. Works fine, and you can have whatever color you want! _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
airkooledchris Samba Member
Posted: Tue Aug 30, 2016 9:54 pm Post subject: Re: Front retractable seat belt length. |
islandtime wrote: |
Did you install them yet?
Yes, I already searched the forums to see if you had answered this previously.*
*not really |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
samwise Samba Member
Joined: May 04, 2010 Posts: 611 Location: North Salt Lake, Utah
Posted: Wed Aug 31, 2016 11:21 am Post subject: Re: Front retractable seat belt length. |
I bought mine from www.seatbeltsplus.com, where you can choose a few lengths, colors, buckle lengths, etc. _________________ Ben
1979 7-passenger bus
Harvee the Wonder Bus' pics |
SGKent Samba Member
Posted: Wed Aug 31, 2016 12:26 pm Post subject: Re: Front retractable seat belt length. |
SGKent wrote: |
we bought some gowesty ones and after using them decided we needed more so the driver could for example lean forward and reach the floor, glove box or latch on the passenger door without unbuckling. We went to the German manufacture and got a quote for a longer belt. They quoted a longer belt than gowesty sells but with the same mechanism. The only issue is that the manufacturer is not insured to sell directly to consumers in the USA so someone on the forum who lived in Germany bought them for me and shipped them from Germany to me. They are perfect. We tried one of the online shops here first but theirs are too flimsy. These belts that we ended up with from Germany are OEM belts on many cars. They are made by Carl Stahl,. Inc. They will only converse with you in German so you will have to translate the e-mails unless you speak German.
Here are some other threads:
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
This is what you order and from whom for the Carl Stahl seatbelts.
(2 pieces ea) Length - 780K style belt 3600 mm cutting length of webbing (black)
(2 pieces ea) Cable buckles 300 mm long
They cost:
Quote: |
As already mentioned one belt 780K/300 cutting length of webbing 3600mm, including cable buckle 300mm and fixation parts (screws, washers etc) will cost net Euro 47,50 (x 2) = Euro 95,00 + Euro 2,00 packaging flat rate + Euro 4,10 shipping to Stuttgart = total net Euro 101,10 + VAT 19% =Euro 120,21. |
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Aug 31, 2016 4:33 pm Post subject: Re: Front retractable seat belt length. |
I have been tied up with work and another car of mine and haven't had a chance to install them. I will get one side installed this weekend and post some pictures. My apologies for the delay. |
