Where do I get a drum puller?
guatebus
guatebus is offline
PostPosted: Mon Jun 20, 2016 1:31 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
Used this monster today to pull my drums:
I borrowed this thing from work, an amazon.com three-jaw puller. It was really freakin' scary pulling these drums...I did the math and calculated I was pulling with at least 8000 pounds of force without budging them. Finally got them moving with some sharp hammer blows to the hub combined with the pulling.
I had the drums off a few years ago and greased the splines upon reassembly, but I found no sign of grease in there once I got them off this time.
I'm going to try the silver looking anti-seize when I reassemble, because this brake job has turned into a giant time sink.
'64 standard microbus
'69 deluxe microbus
'64cal lookdub
1200 Deluxe
'64cal lookdub is offline
PostPosted: Mon Jun 20, 2016 3:52 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
^^^That looks pretty sketchy. I use the same puller Jung Restoration posted, works great, just use longer bolts and not the lug bolts.
guatebus
guatebus is offline
PostPosted: Mon Jun 20, 2016 8:25 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
I saw one like that on Amazon but it had a 7.5 inch max diameter, which was a bit too small. Do you have a link for yours?
'69 deluxe microbus
tanhis
tanhis is offline
PostPosted: Mon Jun 20, 2016 10:12 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
I build my own and it have never failed to pull a drum and it has seen quite seized drums.
-58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton
BarryL Premium Member
BarryL is offline
PostPosted: Tue Jun 21, 2016 7:31 am    Post subject: Re: Where do I get a drum puller? Reply with quote
tanhis wrote:
I build my own...
Killer and a half! I'd like to lose the center screw and run a full set of those bolted up for freeway action Ben Hur style.
cru62
cru62 is offline
PostPosted: Sat Jun 25, 2016 4:58 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
Here is my version-
I needed it to pull these off-
All four were like this. The shoes were welded to the drums.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
redbug64
redbug64 is offline
PostPosted: Fri Jul 22, 2016 3:03 pm    Post subject: Reply with quote
woodslat wrote:
I've pulled at least a hundred bus drums off with this one, only 59 bucks!
http://cgi.ebay.com/ebaymotors/Universal-Wheel-Hub...veQ5fTools
Here it is in use. Yes, I'm wearing white shorts and a white shirt, not necessary to use this puller.
Looks like the $60 dollar one with free shipping only does a 190mm bolt circle.. Does it actually work?
Jason Arms
Fairfax, Vermont
1954 Standard Beetle
1965 Firetruck Red Double Cab
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Random Toyota daily drivers because winter.
woodslat
woodslat is offline
PostPosted: Sat Jul 23, 2016 12:29 pm    Post subject: Reply with quote
Yeah, as hazetguy says you need to use longer bolts though.
redbug64
redbug64 is offline
PostPosted: Thu Sep 22, 2016 1:55 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
Where would one get these longer bolts? Anyone know the specs?
Jason Arms
Fairfax, Vermont
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
d-rick
d-rick is offline
PostPosted: Thu Sep 22, 2016 2:23 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
I got my bolts at the local ACE hardware , same thread pitch as your lug nuts..........just longer bolt is all
1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI
David Raistrick
David Raistrick is offline
PostPosted: Sat Sep 24, 2016 1:23 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
the one I've had for a few years now I got from NAPA, it's the KD-2251 3 arm puller.
A few other options:
OTC # G- 827-B (four arm, use 3 for our application)
OTC # 7394 (3 arm)
OTC # 7393 (same as the KD-2251)
redbug64
redbug64 is offline
PostPosted: Wed Sep 28, 2016 1:58 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
How long do the new bolts need to be??
Jason Arms
Fairfax, Vermont
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
David Raistrick
PostPosted: Wed Sep 28, 2016 4:29 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
I've always used stock lug bolts myself with the OTC puller. I might be less inclined if I didn't have spares.
that said - take one with you when you go, and get something with threads anywhere from lets say 3/4 to 2 inches longer. 1/2 might be fine, but your going to lose some length due to not having the acorn head.
but me, I just use the stock bolts. Smile
general rule of thumb is you want 1/2 the diameter of the bolt's worth of thread engagement. though I dont think the drum is actually that thick in those areas. so just use your judgement as your thread it in to determine if you have enough engagement.
once you get it good and tight, if it doesnt start coming off relatively easy, start tapping on the end of the puller (not hammering hard, just vibrations) and the sides of the drum. DO grease/oil/antisieze the threads of the shaft, but DO NOT use an impact wrench (OK to use it to run it up tight, but dont use it to do the real work. use the included hammer headed thing if you need that kind of force.
'64cal lookdub
1200 Deluxe
PostPosted: Wed Sep 28, 2016 4:43 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
I think mine are 2" long or so, I just told the local bolt place I needed some 14mm X 1.5 bolts.
brokenbus951
brokenbus951 is offline
PostPosted: Fri Sep 30, 2016 10:20 am    Post subject: Re: Where do I get a drum puller? Reply with quote
[/img]
GLHTurbo
GLHTurbo is offline
PostPosted: Fri Sep 30, 2016 10:45 am    Post subject: Re: Where do I get a drum puller? Reply with quote
brokenbus951 wrote:
[/img]
That's how I've done it, except with a hydraulic bottle jack. Not pretty but works!
1957 Beetle
1966 Bus
Nifartachi
Nifartachi is offline
PostPosted: Mon Oct 24, 2016 2:25 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
Can anyone say if this is the right tool?
http://www.ebay.de/itm/BGS-Universal-Bremstrommela...SwMmBVo1wt
easy e
easy e is offline
PostPosted: Mon Oct 24, 2016 2:36 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
It'll NOT work for wide five = 205mm.
It says it only goes up to 200mm.
For USA folks... this is easiere to read: http://www.bgstechnic.com/products/detail/8182?locale=en
- for easy pressing out of drive shafts and
for pulling out of brake drums
- 5 extraction feet with oval mounting holes,
chrome-plated, forged CR-V steel
- 2 pressure pieces (flat and pointed)
- 10 x 185 mm hardened spindle with 190 mm sliding T-bar
drive: 1/2" 4-pt. and 21 mm 6-pt.
- 2 discs for holding the extraction feets,
chrome-plated, Ø 62 and 100 mm
suitable for 3 -, 4 -, 5 - and 6-hole wheel hubs
and brake drums with pitch circle diameter up to 200 mm
aka: Evan
Nifartachi
PostPosted: Mon Oct 24, 2016 2:49 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
Thanks.
I might get this one, if I won't find something better and not too expensive. After all, what's 5mm? Laughing
easy e
easy e is offline
PostPosted: Mon Oct 24, 2016 3:00 pm    Post subject: Re: Where do I get a drum puller? Reply with quote
Nothing a die grinder can't handle...
30 EUR seems like a good deal.
aka: Evan
Page 4 of 6
