Jretmier Samba Member
Joined: February 07, 2014 Posts: 29 Location: Hemet, CA
Posted: Tue Sep 27, 2016 1:43 pm Post subject: Help with 66 vert radio |
I have a 66 convertible with a Sapphire 3 radio installed in the dash. I'm thinking it isn't mounted correctly and is held against the dash with just the knobs. This doesn't seem right to me.
I have googled, read my manuals and I am unable to find any info on a parts brake down and or removal / installation instructions.
Anybody out there have some information regarding the mounting hardware / instructions?
Any info would be appriciated.
_________________ Good from afar, but far from good! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24737 Location: Olympia Wash Rinse & Repeat
Posted: Tue Sep 27, 2016 1:50 pm Post subject: Re: Help with 66 vert radio |
Left click on the "Technical" button at upper right.
Scroll down till you find the "Technical Instruction Manuals" column.
Second down that list is "Radios", left click on that, scroll down to what you need, and enjoy! _________________ In Stereo, Where Available! |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Sep 27, 2016 3:44 pm Post subject: Re: Help with 66 vert radio |
Inside the trunk behind the dash there should be a bracket that bolts to the back of the radio and then to the chassis (body of the car). It acts as a support and a ground connection for the radio.
Here is a picture from the Samba gallery. It's actually an oval window beetle but the idea is the same.
_________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Tue Sep 27, 2016 3:48 pm Post subject: Re: Help with 66 vert radio |
Eric&barb,
Thanks, I'll check it out. _________________ Good from afar, but far from good! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Tue Sep 27, 2016 3:49 pm Post subject: Re: Help with 66 vert radio |
Rig up a strap from metal to the back side of the radio, my 2 VW radios had such, straps even were included with new cassette stereos back then.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Sep 27, 2016 3:51 pm Post subject: Re: Help with 66 vert radio |
Tabs,
Yes, I have that grounding strap. I know now, I looking for the front Backing Plate / support plate. It's missing and the radio is just hanging on the dash by the front cover / dash plate. _________________ Good from afar, but far from good! |
Posted: Tue Sep 27, 2016 3:54 pm Post subject: Re: Help with 66 vert radio |
Jretmier wrote: |
Eric&barb,
Thanks, I'll check it out. |
Glad to help! _________________ In Stereo, Where Available! |
GB2S Samba Member
Posted: Wed Sep 28, 2016 6:16 pm Post subject: Re: Help with 66 vert radio |
Take the radio out and see if it has the bracket that attaches to the tabs on the trunk side of the radio opening. If you don't have one, you can find one in the samba ads.
Geoff _________________ 1963 Ragtop |
Posted: Wed Sep 28, 2016 10:10 pm Post subject: Re: Help with 66 vert radio |
GB2S,
Thanks, After research here on the samba, I found I'm missing the bracket and nuts. I found rich @ VWradio here on the samba and he has already shipped my missing pieces.
Thanks everyone for the advise and help. _________________ Good from afar, but far from good! |
