dtadewald Samba Member
Joined: September 28, 2016 Posts: 9 Location: Northeast Illinois
Posted: Tue Oct 04, 2016 7:17 am Post subject: Towing HELP Please?? |
Ok all........ I'm kinda new at the Buggy thing. I have never towed a car and I need to tow my Dune buggy. I installed my tow bar last night and my hitch is going on tonight. I'm being told that I need to disconnect the drive line if all 4 tires are on the ground.
Is this true?
How can I do that?
How is it possible to disconnect the drive line with a direct fit and no driveshaft
Im trying to get to Silver Lake Off Road area Michigan. from Illinois for my sons birthday this weekend and I need the vehicle operational.
Meco Samba Member
Joined: January 09, 2009 Posts: 148 Location: Chula Vista, CA
Posted: Tue Oct 04, 2016 10:20 am Post subject: Re: Towing HELP Please?? |
Put the trans in neutral and go for it. |
Roys_Big_Toys Samba Member
Joined: April 30, 2011 Posts: 225 Location: Richmond, VA
Posted: Tue Oct 04, 2016 10:31 am Post subject: Re: Towing HELP Please?? |
This question comes up often. I just towed mine from Richmond, VA to South Dakota with NO problems. Make sure it's in Neutral, Parking Brake OFF, Don't back up, Safety Chains and Lights, (Mine are wired for towing), Etc. I tow mine @ the speed limit. Usually about 65 - 72 mph. I've towed with inflated tires, deflated also. Deflated (12psi) causes it to ride better, doesn't bump front to rear but get less mpg. I did have a problem when I bought my new truck with weaving side to side. It was because of buggy out of alignment and the tow bar was steep up to the ball. I bought a 6" drop receiver, got the buggy aligned and problem solved. http://www.thesamba.com/vw/forum/viewtopic.php?t=654915&start=0 _________________ I'd rather be an hour early than 5 minutes late. (Mine)
"It's not a hobby, it's an addiction" (My wife)
"Socialism only works in two places: Heaven where they don't need it and hell where they already have it." -Ronald Reagan
Original Meyers Manx
Berrien LKD Warrior Ecotec 2.2 w/ Bus 091 Trans
Original 2 sided Meyers Manx Dealership sign
Meyers Manx Surf Board #1 0f #100
Custom Meyers Manx Cornhole game |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Tue Oct 04, 2016 11:34 am Post subject: Re: Towing HELP Please?? |
One other tip - if you have a locking steering colum, you have to unlock it (and leave the keys in it) so the wheels can steer with the towing vehicle. I have flat towed a buggy cross country with no issues, except warped rotors on the tow vehicle after a couple of high speed panic stops. Leave extra room. Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Oct 04, 2016 3:55 pm Post subject: Re: Towing HELP Please?? |
Dittos to what others have said, Check trans is in NEUTRAL, safety chains , towing lights, unlock steering column, and do not get in situation where you have to back up.... Unless you are white knuckle driver after first 50-100 miles you will forget it is back there (check mirror)..... And take city street corners a little wide to avoid dragging buggy over curb...
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Tue Oct 04, 2016 5:08 pm Post subject: Re: Towing HELP Please?? |
If you get caught towing in the rain put plastic bags over the air cleaners and carbs or they will fill with water. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Gary0302 Samba Member
Joined: August 29, 2007 Posts: 596 Location: Coastal NC
Posted: Tue Oct 04, 2016 5:11 pm Post subject: Re: Towing HELP Please?? |
One more thing; have fun, my friend. _________________ Gary David Holbrook
Facebook and YouTube
Coastal North Carolina
Check out my videos on Youtube
"It's a buggy not a space shuttle...." - Dale M.
"When in doubt, blame it on the previous owner" - Gary0302 |
tgodber Samba Member
Joined: May 02, 2004 Posts: 410 Location: Okanagan Falls B.C. Canada
Posted: Tue Oct 04, 2016 6:58 pm Post subject: Re: Towing HELP Please?? |
Double check everything. I ususlly tow with a VW Jetta TDI.
60 mph and you forget you have it behind you. Tends to push the Jetta in the corners a little. I too warped my front rotors.
My car is standard so I start off then put the clutch in to make sure buggy is freely coasting in neutral.
Can you tow a buggy with a dune buggy? Yes you can.
_________________ My wife said I never listen to her.
Or something like that! |
Posted: Wed Oct 05, 2016 12:46 pm Post subject: Re: Towing HELP Please?? |
Thanks all........ I've only been on this site for a week or two and you guys ROCK!!! I'm sure that the info provided will set me on my way. I will return and let you all know how it went. |
