micahmonster Samba Member
Posted: Sun Oct 16, 2016 12:54 pm Post subject: Still grinding second even with new bushing and coupler. |
Hi all!
I searched quite a bit and couldn't find anything past the two usual suspects.
My 68 Square Manual had a new shift bushing put in just a small number of miles ago, before I got her back from my friend, but I have the receipt for the work and I verified it is new and in perfect shape yesterday.
Yesterday I also replaced the rear coupler (boy , was that a fun job) - It totally tightened up what was super loose shifting, but when you shift to second from first, it will still grind, unless you do so at a low rpm and a very gentle touch. Downshifting to second? forgeddaboutit.
Any ideas? This has been an issue for a long time according to my friend who had her the last 13 years since I gave it to him in '03.
The Tranny is quiet otherwise, clutch replaced about 4-5k miles (and 14 years) ago. It's strong and I just replaced the gear oil (some very fine metal in the magnets). there is a slight leak just making the front of the tranny greasy - might be the backup seal as they aren't currently working. (of course I bought a new switch AFTER replacing the oil, silly me) - there was a minor leak at the drum seal which I fixed two weeks ago
Any insight appreciated! _________________ 71 Ghia - First car
72 Ghia
71 Square
68 Square
74 T4 Square
73 Ghia
And now I've got that 68 Squareback.. back!
I may have a habit. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Sun Oct 16, 2016 3:29 pm Post subject: Re: Still grinding second even with new bushing and coupler. |
Is your front tranny mount in good shape?
The rear/two lower mounts, too?
Shift plate adjusted properly?
After these, it may be headed for a rebuild. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Mon Oct 17, 2016 6:19 pm Post subject: Re: Still grinding second even with new bushing and coupler. |
KTPhil wrote: |
From appearance they seem to be solid. I could maybe play with the plate a little more, but it's been messed with in the past to no avail.
Eep. Well, she will be dismantled to do body/paint next year.. may as well look into that.
Gear oil was the usual stuff, I want to say 90? Not synthetic - and this issue is a decade old, I changed the oil 2 miles ago. _________________ 71 Ghia - First car
72 Ghia
71 Square
68 Square
74 T4 Square
73 Ghia
KTPhil Samba Member
Posted: Mon Oct 17, 2016 9:30 pm Post subject: Re: Still grinding second even with new bushing and coupler. |
The front mount can look okay, but still allow the front to tilt up when you accelerate. Try lifting it with a scissor or floor jack and see if it moves. |
Erik G Samba Member
dirtslinger Samba Member
Joined: January 20, 2009 Posts: 392 Location: South Bay, So Cal
Posted: Tue Oct 18, 2016 11:33 am Post subject: Re: Still grinding second even with new bushing and coupler. |
2nd gear Syncro probably. _________________ 1967 Class 5
1970 Class 11 HSD Racing
1972 5/1600 V-MAR/Rasta Baja
1956 Baja
1960 Sand Rover buggy
1965 Street bug
1967 Squareback |
Slow 1200 Samba Member
Posted: Wed Oct 19, 2016 4:31 am Post subject: Re: Still grinding second even with new bushing and coupler. |
make sure you are not trying to select reverse (is the plate installed and adjusted correctly?)
make sure that the clutch is disengaging and not dragging
if the above checks out, but it still grinds but you are to downshift by double declutching then the syncro is out |
