Brake lines
D. Haviland
D. Haviland is offline
PostPosted: Fri Oct 14, 2016 1:36 pm    Post subject: Brake lines Reply with quote
I'm wondering (before I take it out) if it's possible to install a new brake line (the one that goes from the junction in the rear to the passenger side) and have it look somewhat original without removing the body. I replaced all of the lines 16 years ago, but have yet to do this one.
carnut63
carnut63 is offline
PostPosted: Sun Oct 16, 2016 7:13 pm    Post subject: Re: Brake lines Reply with quote
You can install all the brake lines as factory without removing the body.
Tyson
---> Mar 2 1955 Strato Silver Oval <---
---> July 1957 ragtop project <---
---> May 5 1966 Ghia <---
---> 1962 Ruby Red Deluxe (sold)
txoval
txoval is offline
PostPosted: Mon Oct 17, 2016 5:19 am    Post subject: Re: Brake lines Reply with quote
You can definitely do it, it helps a lot if you can get the old one off without bending it up.
That way you can use it as a template. There are two folding metal clips that hold it in place on each side of the tunnel, near the top.
Another tip for safety...and yes i learned the hard way. Disconnect the battery.
While feeding in the new line, I accidently bumped it just right and it came in contact with the damn starter terminals. Sparks and melted a damn hole in the line.
Yes, strange crap happens...just passing along so it doesn't happened to you
dmcglynn
dmcglynn is offline
PostPosted: Tue Oct 18, 2016 3:34 am    Post subject: Re: Brake lines Reply with quote
I love reading things like this when I come on here - it's the little stories like this which make you say "Oh man.. that sucks!" which you will remember when you go to do it on your own vehicle. Thanks txoval!
David
D. Haviland
PostPosted: Tue Oct 18, 2016 12:50 pm    Post subject: Re: Brake lines Reply with quote
Thanks for the tip txoval. Yeah I noticed one of the clips, but not the other.
txoval
txoval is offline
PostPosted: Wed Oct 19, 2016 4:00 pm    Post subject: Re: Brake lines Reply with quote
No problem, that's why we're on here. Probably couldn't do it again if I tried, but it happened.
D. Haviland
PostPosted: Fri Oct 21, 2016 7:04 am    Post subject: Re: Brake lines Reply with quote
Got it done. Was much easier than I thought it would be. Was a bit of a bitch getting to that clip. Brake line from WW 16 years ago turned out to be about an inch short, so it is not back in the clip. Other than that it turned out pretty well.
txoval
txoval is offline
PostPosted: Fri Oct 21, 2016 9:20 am    Post subject: Re: Brake lines Reply with quote
My line didn't hit the passenger side clip either...
