JKITTLE Samba Member
Joined: December 07, 2014 Posts: 4 Location: United States
Posted: Wed Aug 10, 2016 9:55 am Post subject: Where to find tubes for a paddle tire |
Hello,
I am having trouble finding the right size tube to fit my vw powered sand rail tire. I have a 15 inch dia x 15 inch wide rear rims with 1300x15 Padla trak Paddles on them. One of the paddles has a small leak in the sidewall and I can not find the correct size tube to use for my application. I am just looking for a solution to this problem hopefully someone is familiar with dune tires sand rails. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Aug 10, 2016 2:59 pm Post subject: Re: Where to find tubes for a paddle tire |
There must be a tire shop in the United States that can source a tire tube for you. |
jsturtlebuggy Samba Member
Posted: Mon Aug 15, 2016 10:10 pm Post subject: Re: Where to find tubes for a paddle tire |
Places like Jegs or Summit Racing have tubes for drag slicks that will work in your sand tire. Natural rubber ones are the best to use. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
cudabear Samba Member
Joined: January 27, 2012 Posts: 65 Location: Lk Mary FL
Posted: Fri Oct 21, 2016 7:26 pm Post subject: Re: Where to find tubes for a paddle tire |
Try this trick 1st. Dismount the tire and use a liberal amount of Dawn dish soap inside the tire. Use a shop rag to wipe the soap around on the entire inside of tire. Do 3 coats over a week. I did this too a pair of tube type cheater slicks on my buggy & it worked great. No leaks or seepage at all. |
