Possible Stupid Newbie Question
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Wed Oct 19, 2016 8:02 pm    Post subject: Possible Stupid Newbie Question Reply with quote
On a 1969 911T with worn suspension, is it possible to upgrade to the 1974-82 (or so) front Koni struts so that Koni Sport inserts can be used as well as larger brakes? I'd like to do it without having to change wheels.
Also- it appears that there's a break in ball joint part numbers around '72/3 or so. I'm assuming the later strut housings will work OK with the earlier ball joints... is this correct?
Any advice from someone who has done this would be appreciated. Thanks!
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
Bleyseng
Bleyseng is offline
PostPosted: Sat Oct 22, 2016 5:57 am    Post subject: Re: Possible Stupid Newbie Question Reply with quote
Yes, you should be able to. You might have to change the balljoint to the later style too. If the front suspension is worn install the Elephant replacement bearings on the A arms and toss the rubber crap.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
