kevlarian Samba Member
Joined: October 16, 2014 Posts: 636 Location: Orange County, CA
Posted: Fri Oct 21, 2016 8:27 pm Post subject: Anyone else running this crazy gear ratio |
So, when I purchased my bug, I was told it was re-geared (freeway flyer) is what the guy said.
I expected a 4.12/.82 or a 3.88/.89 combo, but didn't dig too much into it...
I started to research and work with 'calculators' to figure the RPM/Speed with each of the two gear settings above, and neither matched my RPM/Tire combo. So I started looking for some answers.
Long story short...
I finally figured out, I am running an OLD SKOOL 4.37 RP + 0.82 4th.
I have never seen that combo. Ultimately, it lands my 4th just 100 RPM lower than a stock 4.12/.89 combo. So basically... not what I expected.
I was just curious if anyone else has this combo.
Thanks in advance! |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Oct 21, 2016 8:35 pm Post subject: Re: Anyone else running this crazy gear ratio |
I have. Don't remember what it came out of, old bus I think. Keyed 4th gear .82 ratio. If memory serves, it also had a K 4.37 _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri Oct 21, 2016 8:42 pm Post subject: Re: Anyone else running this crazy gear ratio |
I remember telling you a while back "Freeway Flyer" means nothing.
Nothing odd about it. You have a early Bus transaxle that came with reduction boxes. They removed the RB's and flipped the ring & pinion gear to run in a Bug. It has all the weak parts inside. I would not be dumping the clutch doing drag race starts or smoky burnouts. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Fri Oct 21, 2016 9:15 pm Post subject: Re: Anyone else running this crazy gear ratio |
That's a old school freeway fryer ya got there! |
Posted: Fri Oct 21, 2016 9:30 pm Post subject: Re: Anyone else running this crazy gear ratio |
modok wrote: |
Odd. Knowing that it's an old bus tranny at least makes it a bit clearer. But goodness me. What an odd combination. Should I invest in a new tranny? I'd love to run a 3.88/.89 combo. |
modok Samba Member
Posted: Fri Oct 21, 2016 9:37 pm Post subject: Re: Anyone else running this crazy gear ratio |
yeah, I don't lie the WIDE spacing either, but, somebody out there proably thinks it's great. well, i was gonna say blow it up but actually you should probably sell it |
Posted: Fri Oct 21, 2016 9:38 pm Post subject: Re: Anyone else running this crazy gear ratio |
Looking at the marketplace, it appears they build them with 4.37 options. Mine is rebuilt and looks just like this including the chrome side plate.
http://www.thesamba.com/vw/classifieds/detail.php?id=1136784 |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sat Oct 22, 2016 6:12 am Post subject: Re: Anyone else running this crazy gear ratio |
It most likely has a 1.21 3rd as well. If you go with a stock later 1.26 3rd/.89 4th, it will have a little less of a rpm drop than the 1.21/.82. |
cbeck Samba Member
Posted: Sat Oct 22, 2016 7:15 am Post subject: Re: Anyone else running this crazy gear ratio |
I had my type 1 irs built with 4.37, 1.48 third, and .89 fourth so I can carve the country roads and not get run over on the interstate. |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Sat Oct 22, 2016 8:44 am Post subject: Re: Anyone else running this crazy gear ratio |
Someone may have built it for a glass buggy or Baja. The 4.37 is perfect if you have tires Just a little larger than stock. You wouldn't use 4th off-road with a mild motor, but in the lighter buggy wouldn't notice the wide 3-4 transition on the street so much.
I'm kinda partial to the 4.37 Trannys, but I'm not a street guy and like big tires. _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sat Oct 22, 2016 9:09 am Post subject: Re: Anyone else running this crazy gear ratio |
I did my Cal Look street car (late '70's and early '80's) with a 4.375 and 1.48/1.12 gears. With a 6500rpm 1750 it ran mid 14's and was GREAT on the street. Sucked on the highway though...but boy was it fun in town! _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
mark tucker Samba Member
Posted: Sat Oct 22, 2016 9:23 am Post subject: Re: Anyone else running this crazy gear ratio |
hey alb that was a freeway frier trans you had.....
to the op 100 rpm drop on the highway probably makes mpg and dosent load a small motor as bad as a 300rpm drop. but if you dont have the motor to pull the 100 drop..it's useless for the most part. |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Sat Oct 22, 2016 4:45 pm Post subject: Re: Anyone else running this crazy gear ratio |
I hate the term "freeway flyer". It's an ad gimmick, and probably not a very good idea. A true "freeway flyer" would have a 3.88 R&P and a .82 4th gear. That's really high gearing for a VW aircooled engine. The ideal is to keep the engine in the RPM range where it makes the best torque at freeway speeds. That way it isn't working as hard as it would, i.e., lugging it, with a higher 4th gear ratio. Lugging it = heat. Heat kills ACVW engines. Also, would probably worsen your freeway gas mileage. Contrary to what seems to be popular opinion, higher freeway rpm does not always = worse gas mileage on the freeway, and lower rpm does not always = better gas mileage on the freeway. My experience with these old ACVW's is that Volkswagen knew what they were doing. Have you ever asked yourself why, when they went to a 3.88 R&P, they also went to a lower 4th gear ratio, .92? _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
rearenddude Samba Member
Posted: Sat Oct 22, 2016 6:51 pm Post subject: Re: Anyone else running this crazy gear ratio |
I have the 3.88 and a taller 4th gear as well...
Just under 1500rpm drop with each gear change...
But the FIAT uses 13 inch rims and only weighs in at 1250 lbs..
Still too much rpm drop though...motor can pull it in thos car but i have to run up a little higher than i like some times before a gear change..2500 ish...
Can get annoying if im trying to be stealthy... |
DeathBySnuSnu Samba Member
Posted: Sat Oct 22, 2016 7:34 pm Post subject: Re: Anyone else running this crazy gear ratio |
I run a 3.44 with 1.26 third and .82 fourth.
But I run big motors in a 850lb vehicle.
Bottom line.....if the gearing works gor you. |
Posted: Sat Oct 22, 2016 8:13 pm Post subject: Re: Anyone else running this crazy gear ratio |
DeathBySnuSnu wrote: |
And you also have a huge aerodynamic advantage by not having a large flat windshield to push through the airstream. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
slalombuggy Samba Member
Posted: Sat Oct 22, 2016 8:34 pm Post subject: Re: Anyone else running this crazy gear ratio |
I have a 3.88/.82 freeway flyer in my 57. Works fine for me, but I also have the hp to make it work and that same gearbox in my buggy was a blast. Haven't had a problem with overheating on hour long trips. I also have 26" tires in the back of both cars.
brad |
Posted: Sat Oct 22, 2016 8:52 pm Post subject: Re: Anyone else running this crazy gear ratio |
slalombuggy wrote: |
brad |
and I thought 4.12 / .82 was tall... 3.88 / .82 is TALL.
I just have a 1915 putting out about 100hp. Don't think I could pull 3.88 / .82 with that configuration. But slap a .89 and I could prolly run that all day long. |
Posted: Sat Oct 22, 2016 9:56 pm Post subject: Re: Anyone else running this crazy gear ratio |
I've also borrowed and run a 3.44/.82 gearbox. It made a huge difference in the first 3 gears and I was running 115 mph when shifting into 4th. That was for racing only though and the motor I had at the time would not pull that 4th gear very well, only gained 3mph in 1/2 mile.
Would be interesting to try that R/P and stock gear stack.
brad |
Posted: Sun Oct 23, 2016 6:40 am Post subject: Re: Anyone else running this crazy gear ratio |
I think Glenn uses an .82 as a 5th gear with a 3.88. I would think the torque peak of the engine, and desired cruising speed would come into effect. I have a 1.41/.93 combo that originally was installed for 1/8 mile runs. Once I started running 1/4, I would be really ringing the engine to make it through the 1/4 in 3rd with a short 24.5 tire. It was all bracket, so I started short shifting to keep the rpms down, so I could drive the car home. The torque peak on the engine was around 3800 if I recal, and 1-3 would all be up shifted past that, but the 4th shift dipped below that. It was quite noticeable that the engine had to pull itself back up. If you have a high strung engine that has a high rpm torque peak, if you are cruising below that, I would think the engine would always be working. On the other hand, if you had a mild stroker with a small cam that had a lower peak, cruising at/above that rpm wouldn't have the engine working very hard. There's the torque itself also. Regardless of cruising rpm, an engine with 70 ft lbs. cruising at peak rpm isn't going to pull a tall gear. A huge stroker with 150 ft lbs. below its torque peak probably will. |
