DWP Samba Member
Posted: Wed Nov 09, 2016 8:19 am Post subject: Sealing welds on widened rims |
Just got my Baja Marathons back from widening. For the short term i plan on sandblasting and painting with an epoxy. Is there anything i need to put on the welds incase there any pinhole leaks where the welds are?
Do,i need to paint the inside of the rim
Thanks
DWP |
Boosten Ya(Josh) Samba Member
Posted: Wed Nov 09, 2016 9:24 am Post subject: Re: Sealing welds on widened rims |
If the welder is good and prepped the metal correctly then there shouldn't be any pinholes.
I would imagine a silicone would work fine but that's just a guess. |
slalombuggy Samba Member
Posted: Wed Nov 09, 2016 5:28 pm Post subject: Re: Sealing welds on widened rims |
Hopefully the welder knew his job. If it's a wheels shop chances are he did. If you want to seal them with something to be sure use a good quality sealant like Permatex The Right Stuff and use it SPARINGLY and apply it EVENLY. use only enough to cover the area with a thin coat. If you have big gobs everywhere it will throw the balance of the wheel off and you'll end up with a bunch of weights on your wheels.
brad |
DWP Samba Member
Posted: Wed Nov 09, 2016 5:53 pm Post subject: Re: Sealing welds on widened rims |
The welder has been doing this for 35 years for all types of rims, the welds do look good. Would just hate to find a pin hole after the tires are mounted.
DWP |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Nov 09, 2016 6:00 pm Post subject: Re: Sealing welds on widened rims |
If the welder is as good as you say, apply a couple of coats of paint and call it a day. After all, you are going to need something on the metal to stop corrosion. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3442 Location: San Diego
Posted: Mon Nov 14, 2016 9:38 pm Post subject: Re: Sealing welds on widened rims |
The only way to know that, is to mount a tire after welding, before painting. Pressure test. If the wheels were widened, you probably have new hoops. Not likely to leak. |
