vamram Samba Member
Posted: Thu Dec 01, 2016 10:15 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
Yep, that's the plan. I use Master Series Silver to treat rusty metal instead of POR 15 and have had good results after 4 years. I already replaced the battery tray on this bug! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sat Dec 03, 2016 10:20 am Post subject: Re: Starter Button Wiring Problem...Help!! |
This Super just keeps on giving.
Found this while removing the old factory sound proofing from the driver side floor pan:
It looks like one of the POners cut the wiring harness run then soldered the wires back together and insulated them w/electrical tape. You can see that one of them is bare at the solder point.
Recommendations on cleaning of this mess? New tape? Cut, insert heat shrink wrap, and resolder...? etc? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Sat Dec 03, 2016 7:28 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
Ah haa. And the show keeps a rolling! Just kidding. Good find, Victor.
What I would do is to use your wiring diagram and identify every wire there, where its source is and where it terminates. Then with a DVOM on the 12v dc circuit check for any voltage drop on every circuit there. At least then with this knowledge you will know if any potential problems exist now or possible later down the road.
For example, someone has told you a tail lite is occasionally out or flickres, but every time you check it works. With the DVOM, dc volt scale, positive on fuse (at fuse box) and negative on back of bulb. DVOM says 0.2v drop. Not bad. But you begin to wiggle that connector and the DVOM starts changing volt readings. This would indicate a connection problem there.
Hope this helps, Bill |
vamram Samba Member
Posted: Sat Dec 03, 2016 8:17 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
Bill, let's say everything traces per the wiring diagram. What then? Leave these as is or redo those splices in some other way? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sat Dec 03, 2016 9:32 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
Hi. I probably would look and see. My concern is if there is some nice shrink fit tubing it gets cut away. Maybe some more experienced wiring guru's have idea on that covering. But, I would make sure the wires are soldered. It is a relatively inexpensive repair to solder it all up.
Bill |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Sun Dec 04, 2016 11:28 am Post subject: Re: Starter Button Wiring Problem...Help!! |
Since you're there already, I'd open those wires up to see how well they connect. You can paint them with liquid electrical tape, then when dry, re-wrap with actual electrical tape. It would be tedious, but that PO did things a little wonky. It might be worth the trouble.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
TX-73 Samba Member
Posted: Sun Dec 04, 2016 5:00 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
If I were in that spot I would solder each wire and use shrink wrap. I typically use a barrel connector to first crimp the wires together then solder that connection. _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
vamram Samba Member
Posted: Sun Dec 04, 2016 5:09 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
TX-73 wrote: |
If I were in that spot I would solder each wire and use shrink wrap. I typically use a barrel connector to first crimp the wires together then solder that connection. |
I like that idea of the barrel connector. Why the extra step of soldering this? Strength? Better contact/less resistance? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sun Dec 04, 2016 7:34 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
I would think to reduce the possibility of corrosion and for longevity. Will make for a bulky section, though. At least its hidden, normally. |
TX-73 Samba Member
Posted: Mon Dec 05, 2016 6:07 am Post subject: Re: Starter Button Wiring Problem...Help!! |
I solder everything, I don't like crimp connectors used on their own. Plus I think the conductivity is better since current passes through the entire soldered connection not just the smaller crimped area.
Yes, I know people use the crimped versions, but this is what I would do. I use the barrel connector as initial mechanical connection to hold things until I solder it. Just personal methodology.
A properly sized barrel connector adds very little bulk to the connection. _________________ My 1973 Standard Beetle Build SOLD
Cusser Samba Member
Joined: October 02, 2006 Posts: 31271 Location: Hot Arizona
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Mon Dec 05, 2016 8:22 am Post subject: Re: Starter Button Wiring Problem...Help!! |
Problem is most folks will not choose to or do not know to get the $50 to $150 ratchet crimper and proper crimps like used at the factory that make a gas tight seal between the crimp and both wires. Instead they get a glorified pair of plier crimper tool that never seal the connection.
If no oxygen can get in, then no corrosion can get occur in the connections between those the parts. Even then it would not be bad to solder which again seals out corrosion just like the VW factory battery cables. This is not an area you want to have to pull apart every five or so years to clean out corrosion...
Only other problem is it would have been nice if the DPO had staggered at least half of the connections so the loom there would not be such a swollen mass of repairs in a single spot. Hopefully it will not cause shorts down the road as is. _________________ In Stereo, Where Available! |
vamram Samba Member
Posted: Mon Dec 05, 2016 10:24 am Post subject: Re: Starter Button Wiring Problem...Help!! |
Eric&Barb wrote: |
Problem is most folks will not choose to or do not know to get the $50 to $150 ratchet crimper and proper crimps like used at the factory that make a gas tight seal between the crimp and both wires.... |
I actually have a ratchet crimper, just no barrel connectors that specifically work w/it. I guess I can order those, but the crimper is very bulky and I don't think I can use it in the space where the wires are exposed. I suppose I could disconnect the ends of the wires and pull them in to that point, but I won't be able to do that w/ones that run back to the engine compartment. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Mon Dec 05, 2016 10:43 am Post subject: Re: Starter Button Wiring Problem...Help!! |
vamram wrote: |
I actually have a ratchet crimper, just no barrel connectors that specifically work w/it. I guess I can order those, but the crimper is very bulky and I don't think I can use it in the space where the wires are exposed. |
Then just go with soldering if need be. _________________ In Stereo, Where Available! |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Dec 05, 2016 10:44 am Post subject: Re: Starter Button Wiring Problem...Help!! |
WOW if they are already soldered together just tape them up individually and move on. don't make mountains out if molehills. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Dec 05, 2016 11:15 am Post subject: Re: Starter Button Wiring Problem...Help!! |
60ragtop wrote: |
WOW if they are already soldered together just tape them up individually and move on. don't make mountains out if molehills. |
Seen plenty of bad soldering resulting in cold joints that will not do well over time. Would take a little bit of time, but worth it to check say five of them, to see if even one is sub par. If one is, then go thru the rest to get a good solder joint on each. _________________ In Stereo, Where Available! |
vamram Samba Member
Posted: Mon Dec 05, 2016 11:25 am Post subject: Re: Starter Button Wiring Problem...Help!! |
Eric&Barb wrote: |
60ragtop wrote: |
Seen plenty of bad soldering resulting in cold joints that will not do well over time. Would take a little bit of time, but worth it to check say five of them, to see if even one is sub par. If one is, then go thru the rest to get a good solder joint on each. |
I would love to "move on" as getting this car in order has been more than I estimated (shocking, right!?!). I like TX's recommendation to clean them up w/ nice barrel connectors, solder and shrink wrap, but if that's just extra work for connections that *may* be good as they are, I'm open to confirming that first and moving on.
E&B - what's the correct way to test the quality of the soldering? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Mon Dec 05, 2016 11:34 am Post subject: Re: Starter Button Wiring Problem...Help!! |
look them over, give the tug test, check with a volt meter. retape move on.
This car wrenching is not as hard some make it out to be _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Mon Dec 05, 2016 12:05 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
Main thing you are looking for is solder flow and not globbed up in drips. When wires are clean enough and soldering iron used is hot enough the solder should be more of a thin coating over the wires.
Plus look for any sharp points soldered wire can form. Any sharp point will cut through plastic tape/heat shrink and cause shorts. _________________ In Stereo, Where Available! |
vamram Samba Member
Posted: Mon Dec 05, 2016 6:09 pm Post subject: Re: Starter Button Wiring Problem...Help!! |
Here's what the wires look like under the tape. They were cut and *most* of them then soldered back together.
I'm confused by the thin one to the left - going towards the front of the car it's blue, but it's attached to green/red stripe one going to the back. And it's not soldered, just twisted together.
Very confusing because per the diagram, the engine-end of the green/red stripe wire goes to the oil pressure switch. The other end is supposed to connect to the dual circuit brake warning/seat belt interlock warning system, but solid blue goes to the alternator charging warning light in the dash..and there's a 2nd lighter blue wire I can't identify on the right side of the bundle...although there's a 2nd solid blue in the diagram that's tied to K5 the "turn signal warning light..." . There's not much slack to work w/on these wires. And most of them are really stiff for the 1/4" - 1/2" on either side of the solder, not flexible at all.
What a Cluster F*&#! _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
