Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Thu Dec 01, 2016 2:45 pm Post subject: Converted to LED turn signals....now weak turn signal dash light |
Converted my 69 Beetle to LED turn signals front and back. Installed electronic control unit. Signals working fine but green turn signal dash light now only works when car is running and is very dim also.
My question....would replacing the dash light with a green LED solve my low light problem ? ( I understand I will need reverse polarity LED for turn signal indicator light)
P.S. The electronic control unit is MUCH QUIETER than the original unit so the light is what I will primarily rely on to remind me that my signals are on. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Thu Dec 01, 2016 10:25 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
What are the terminal numbers on your flasher relay? The stock Euro-style flasher relay will have : #31, #49 (+) and #49a. If your flasher relay has different terminal numbers it may not be compatible with the Beetle wiring. Do your turn signals work normally when the turn signal indicator bub is disconnected?
The flasher relay and turn signals in the corners work how you would expect them to. The flasher relay is powered while the ignition is ON. But it has no path to ground. When you move the turn signal lever to L or R you close the circuit and there is a path to ground thru bulbs on one side. The current flows thru the flasher relay which pulses the output to cause the bulbs to "blink".
The problem is how the Beetle powers the turn signal indicator lamp in the speedo. The three indicator lamps at the bottom of the speedo share a common 12v+ from the ignition switch. Each bulb has 12v+ and is looking for a path to ground. The Gen lamp is grounded by the VR. The Oil lamp is grounded by the oil pressure switch at the engine.
The turn signal indicator is grounded by the corner lamps in a very unique way. Think of the output from the turn indicator lamp on the blue/red wire as a small garden hose (the 2W indicator bulb restricts the amount of current that can flow thru the bulb). Think of the #49a output of the flasher relay and the corner bulbs as a fire hose (the 2x 21W corner bulbs flow much more current than the 2W indicator bulb). When the flasher relay is pulsing ON the current flow from the #49a terminal to the corner lamps is so great that the turn indicator lamp cannot flow much current at all. The fire hose and garden hose are sharing the same spout. While the fire hose and garden hose are both ON the fire hose prevents the garden hose from flowing much water. Both are trying to flow current to the ground by flowing thru the corner bulbs.
When the flasher relay is NOT ON (flasher relay pulsing OFF), there is no current flowing out of #49a so the turn indicator lamp now has a free path to ground thru the corner lamps and the indicator lamp turns ON. When the flasher relay starts to flow current once more (fire hose ON) the turn indicator lamp goes dim.
The problem is that flasher relays not designed for Beetles will "see" the positive current flowing out from the indicator lamp as INPUT voltage on the #49a OUTPUT terminal of the flasher relay. For some relays this can cause a problem as they were not designed to operate with positive voltage on the OUTPUT terminal. You really need a flasher relay designed to work with Euro-style turn/E-Flasher systems. _________________ AshMan40
Posted: Fri Dec 02, 2016 8:13 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
You were right, I have the more common electronic flasher made for American car wiring. When I disconnect the dash indicator light the blinkers work much better........I will now order the correct 31/49/49a flasher.
Once again.....Thank you for all your help now and in the past : ) _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
Posted: Fri Dec 02, 2016 12:10 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
Old n' slow wrote: |
I will now order the correct 31/49/49a flasher. |
Check you local FLAPS and see if they can find a flasher relay with the part# EP-35. These are made by multiple different parts manufacturers but are basically the same. You want the ones that actually state they are LED compatible.
Notice that the terminal numbering matches the stock flasher relay. _________________ AshMan40
Posted: Tue Dec 13, 2016 1:32 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
Went from a weak dash indicator light (with an electronic flasher with B+ L -E terminals) , but LED signals did work perfectly, to almost non working ( barely flash and won't work at all with running lights on and no dash light at all) when I changed to an LED compatible flasher with 31 L49a 49 terminals.
I'm ready to just live with the working perfectly B+ L -E flasher and the low dash light but just wondering why the correct (???) 31 L49a 49 LED compatible flasher is a complete flop in my 69 Bug ( w/ LED's front & back)
I realize diagnosing electrical problems online is difficult, but curious if anyone had any thoughts on why the "correct" 31 L49a 49 didn't work at all ? _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Tue Dec 13, 2016 4:21 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
I do not know the cause of your problems but one thing I would recommend is performing a voltage drop test across the corresponding wires, maybe you have some issues there. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26322 Location: Douglas, WY
Posted: Tue Dec 13, 2016 4:22 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
The one you had before was actually correct, as that is a grounded relay. B(attery) is the same as +49, L(oad) is the same as 49a, E(arth) is the same as 31. _________________ Andy T.
Posted: Tue Dec 13, 2016 4:32 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
glutamodo wrote: |
The one you had before was actually correct, as that is a grounded relay. B(attery) is the same as +49, L(oad) is the same as 49a, E(arth) is the same as 31. |
Thanks. It did do the job, it was just the dash light that was the problem. It works ( but is dim ) when engine is running and doesn't shine at all when engine not running but key in on position.
Would a green LED with reverse polarity work better ? _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
Posted: Wed Dec 14, 2016 7:03 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
Went from a weak dash indicator light (with an electronic flasher with B+ L -E terminals) , but LED signals did work perfectly, to almost non working ( barely flash and won't work at all with running lights on and no dash light at all) when I changed to an LED compatible flasher with 31 L49a 49 terminals. |
What make/model flasher did you buy? Was it the specified for VW Beetles? There are two flasher models w/ the proper numbering but one has the terminals laid out in a different pattern. Notice RFL3 and RFL9 in the below diagram. RFL3 is the correct one for Beetles.
Your description sounds like a grounding problem at your light assemblies. Remove your flasher relay and your turn indicator lamp for this test. Use a jumper wire to connect the #49 and #49a wires together. This bypasses the flasher relay for testing. Test your turn signals with the parking lights ON and OFF. It should not make a difference. If it does, you probably have a grounding problem.
Are you using the stock light assemblies? If your taillight ground wire is bad/loose, the turn signals and brakes will sometimes ground backward thru the parking light circuit. Then when you turn the parking lights ON, there is no longer a path to ground.
You're not combining the parking and turn signal circuits into a single bulb, are you? Or using a turn signal assembly from a different model year? The early 60's front turn signals were single filament since the parking lights were in the headlight housings. You cannot use a single filament bulb for two circuits w/o a special "trailer circuit".
Using an LED instead of the normal 2W incandescent bulb as the turn indicator lamp is possible but a pain. Most LED replacements assume the bulb holder is grounded to (-), but in the case of the turn signal indicator (and the OIL and GEN lamps too) the bulb holders are (+) and the spade at the bottom of the bulb holder runs to a switched ground (-). Since LEDs only work with current flowing in one direction, you would need to do some "jiggery" to get it wired correctly.
This would not necessarily fix your problem if it is related to grounding. _________________ AshMan40
Posted: Wed Dec 14, 2016 8:55 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
I'm using an RFL3...... When I get time I'll try what you said. Thanks.
There is a company that sells the green turn signal light in reverse polarity LED for $6.00 plus $3 & change shipping...... I might go that route if it would shine more brightly ?????
Just checked....it's a CEC ( RFL3 led comparable, made in Taiwan) EF35L ........EF is a direct replacement for EP and terminals are from left to right -31 L49a +49 _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
Posted: Thu Jan 05, 2017 5:11 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
JUST A FOLLOW UP THAT MIGHT HELP SOMEONE . Not criticism of the help I received ......since it's very difficult to diagnose someone else's electrical problems without being there........ Again thank you all for the help.
Finally fixed my signals by going to a CF 13 relay even though every search on the internet said ( EP 35 L ) RFL 3 relay was the way to go with LED's in my very stock original 1969 Bug......The weak dash indicator was "fixed" by switching out the stock 12 volt ba7s bulb with a 6 volt amber ( couldn't find green ) led ( I solved the reverse polarity problem by isolating and rewiring the led bulb).
Everything works great now : ) I hope this helps someone someday. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
Posted: Fri Jan 06, 2017 10:07 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
Interesting...
I thought I would add something for the next person who comes across this thread.
I found a page about someone trying to get LED's working on their restoration (not VW, but conceptually the same issues).
https://914electric.wordpress.com/2011/08/01/bells-and-whistles-part-2/
He posted a nice pic of four LED compatible flasher relays and their terminal numbers:
The reason I include this pic is because it shows the CF-13 relay on the right with the proper 31/49a/49 terminal numbers in the correct positions.
(Interestingly, he couldn't get any of them to work with his LED turn signals. And he tried BOTH the EP-35 and CF-13. Since he was having issues w/ his parking lights flash while the turn signals flashed I suspect he had a grounding issue.)
I also found this diagram from a different vendor which shows three different ways to wire the CF-13 flasher relay.
http://www.vleds.com/3-pin-european-electronic-led-flasher-blinker-fix.html
The thing to note is the "pilot" (indicator) lights. In these examples all are negative grounded and are powered by the flasher relay.
For the VW Beetle, the single turn indicator lamp has a constant 12v+ and the connection to the #49a provides a pulsing path to ground.
It is interesting that the SAME flasher relay can be wired differently for different systems. Not that for the 3-prong European installation the 12v+ comes into the #49 terminal. For the 3-prong American installation 12v+ comes into the #31 terminal! And for the three different installs the output (LOAD) is on three different terminals!
This looks like the most "flexible" flasher relay out there.
I've not used the CF-13 flasher relay, but I'm keeping it on my list of "possible" LED compatible flasher relay replacements. _________________ AshMan40
Posted: Thu Jan 26, 2017 4:45 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
Everything works great now : ) I hope this helps someone someday. |
UPDATE!!!!
Everything works great.....I THOUGHT : /
Didn't notice until recently, with my "fix" I now turn on my dash and parking lights everytime I step on the brake.
Somehow my CF 13 fix with the isolated indicator led bulb is no fix at all.
Went back to all stock ( incandescent bulbs & stock flasher) for now until warm weather and I can leasurely hunt down a bad ground or whatever gremlin I have.
Just didn't want to lead anyone astray that might come across this thread. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
HunterTheBusHunter Samba Member
Joined: September 23, 2014 Posts: 170 Location: Washington State
Posted: Thu Jan 26, 2017 7:38 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
I had the same issue you were having. I replaced the dash indicator bulb with a led and it solved the whole thing. Im using a EP35 flasher and leds all around. You might have the wrong wire placement on the CF13 because it can be wired so many ways. _________________ "This is air. Air is for breathing and for cooling car engines. Air won't freeze up, air won't boil over. Ask any Volkswagen." (o\_!_/o) |
Posted: Fri Jan 27, 2017 7:43 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
Went back to all stock ( incandescent bulbs & stock flasher) for now until warm weather and I can leasurely hunt down a bad ground or whatever gremlin I have. |
Agree it is likely a bad ground at the taillights.
I had a similar problem with one of my rear taillights. The ground for the taillight was bad. All the bulbs in the taillight share the same ground wire. When any of the bulbs (other than the parking light) was turned ON it grounded backward thru the parking light circuit. This resulted in my dash lights pulsating with the turn signals.
When you turned the parking lights ON, the other lights stopped working properly (turn signals and brakes were much dimmer; turn signals would quick flash). _________________ AshMan40
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Jan 27, 2017 9:19 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
I have been following this thread without a particular need- but wanted to comment on Old n' Slow. You sir have provided an example of the BEST thread wherein you asked for help; followed up; listened; replied; tried; failed; admitted- you name it! I wish everyone on the Samba could use your thread as an example of how to use these forums for troubleshooting in the BEST possible way.
Thank you sir and Sincerely, Bradford _________________
EverettB wrote: |
FU#5 |
mcrotty5 Samba Member
Joined: August 22, 2012 Posts: 36 Location: Phoenix, AZ
Posted: Thu Jan 30, 2020 10:05 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
Just wanted to see if there was any resolution to this, as im currently having the same issue. Signals flash at all 4 corners, but i dont get anything on the indicator on the speedo. |
Posted: Thu Jan 30, 2020 11:12 am Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
First thing... test your turn indicator lamp in the speedometer.
With your ignition switch ON and the engine NOT running the OIL and GEN lamps should be ON, but the turn indicator will be OFF. With a short jumper wire, ground the terminal on the center turn indicator bulb holder. This is where the blue/red wire connects to the bulb holder. Doing this should turn the turn indicator lamp so now all three indicator lamps will be ON.
Next, turn the ignition switch OFF and turn the E-Flasher switch ON. The turn indicator lamp should flash along with the corner lamps. In this configuration (ignition switch OFF) the turn indicator lamp in the speedometer becomes a 5th corner lamp.
If your indicator lamps do not work as described above, find the wire connected to the very bottom terminal of the speedometer (below the three indicator lamps). This should be a black or green wire coming from the fuse box. Turn the ignition switch ON and test the end of this wire for 12v+. It should NOT be grounded. If you do not have 12v on the wire, trace it back and see where it goes. Some years it was directly connected to the fuse box. Other years power from the fuse box went to the fuel gauge vibrator before daisy-chaining to the bottom terminal. All three indicator lamps in the speedometer work from a ignition switched constant 12v+ source and each indicator lamp wire runs to a switched ground to turn the lamp ON (oil pressure switch and voltage regulator ground their end of the blue wires to turn the indicator lamps ON.
Test your corner lamps.
Remove the turn indicator lamp holder from the speedometer and remove the bulb. Reinstall the empty bulb holder into the speedometer. Test both the turn signals (L & R) and the E-Flasher (4-ways). All corner lamps should flash with the same brightness and speed.
Reinstall the speedometer turn indicator lamp and rerun the same test.
With the ignition switch ON and turn signal switch ON, the speedometer indicator lamp should flash OPPOSITE (out of sync with) the corner lamps. With the ignition switch ON and E-Flasher switch ON the indicator lamp should flash OPPOSITE the corner lamps. With the ignition switch OFF and E-Flasher switch ON the indicator lamp should flash "in sync" the corner lamps. _________________ AshMan40
Posted: Thu Jan 30, 2020 5:17 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
that was a great explanation. So i thought i would try to clarify, i jumped in on this conversation way after the fact.
I have led tail lights for years. I currently have the EP35 relay in my car. my indicator light in my speedo is LED as well. until yesterday, i had regular bulbs in my turn signals up front. Everything worked exactly as it should, no issues.
however, yesterday afternoon i switched the front bulbs over to LED. once i did that, the signals work on all 4 corners as they should, however the indicator in the speedo will only light once. if i look hard at the indicator, i can see if flicker every 2 or 3 clicks. |
plagos_g Samba Member
Joined: May 25, 2015 Posts: 82 Location: Santiago, Chile
Posted: Thu Jan 30, 2020 6:24 pm Post subject: Re: Converted to LED turn signals....now weak turn signal dash light |
I've been using LED's in my crew cab for about 5 years now, and 2 in the bug.
I had the same problem of the indicator messing up everything else. My solution was... different.
I added two wires coming from the hazard switch (L, R) using two piggyback terminals, joined them using two diodes and replaced the bulb with a custom wired led with a resistor.
EDIT: I use a cheap led flasher from ebay since the day I installed the bulbs, (E, L, B), so I suppose it works with any LED compatible unit.
Picture one shows a basic schematic.
Picture two shows the LED in the drilled bulb holder, with heatshrink tubing for insulation.
The original input wire from 49a is forever covered in insulating tape, if I ever go back to incandescent bulbs, it will be available. _________________ 1998 Volkswagen Sedan (MexiBeetle, daily drive)
1987 Volkswagen Kombi (crew cab, br) |
