bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Fri Dec 02, 2016 6:43 pm Post subject: Engine case - quick question |
While I have the engine out waiting for the Timesert kit to arrive, I thought of checking the torque on the case nuts. But, the torque reading will not be accurate unless the nut/stud threads are clean and lightly lubed (right?).
So, could I remove one nut at a time clean threads and retorque? Would that cause any issues with the case sealing? Not critical, but just something to do on a rainy cool morning here.
THx,
Byas |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Fri Dec 02, 2016 6:55 pm Post subject: Re: Engine case - quick question |
I think you'd need the case together, cylinders and cylinder heads installed, and to torque ALL 16 NUTS in the correct sequence. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bnam Samba Member
Posted: Fri Dec 02, 2016 7:10 pm Post subject: Re: Engine case - quick question |
Thx Cusser. Will just clean up all the tins this morning. |
wcfvw69 Samba Purist
Posted: Fri Dec 02, 2016 8:48 pm Post subject: Re: Engine case - quick question |
Check your head studs torque too. Some studs are 8mm and others are 10mm studs. Find the torque spec in the Bentley for whichever studs your engine has. _________________ Contact me at [email protected]
The Samba member since 2004.
