jpaull Samba Member
Joined: February 22, 2005 Posts: 3461 Location: Paradise, Ca
Posted: Wed Dec 07, 2016 2:17 am Post subject: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
Even after degreasing the Magnesium VW case multiple times, it still can look like crap.
Want to get a brighter and more uniform look?
First step, make sure you have a few hours before the wife/girlfriend gets home, then see in my 1 minute video:
https://www.youtube.com/watch?v=fi-g00LzNm0
Jeff |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Dec 07, 2016 3:08 am Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
"So clean you could eat off of it"
Still, that video file is grounds for deee-vorce! destroy it. Tell no one.
I have a mini-dishwasher coming up for retirement, was thinking of using it to clean parts, running it closed loop in the garage, was thinking about cleaning meduims... |
Scott65Beetle Samba Member
Posted: Wed Dec 07, 2016 7:08 am Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
brilliant |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Dec 07, 2016 7:25 am Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
Props for having the air hose accessible in the house! Who needs to sweep/vacuum, just open the front door and blow all the dirt out! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51117 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Dec 07, 2016 9:02 am Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
FreeBug wrote: |
BTDT works great, I had issues with foaming sometimes (Simple green), tried citrus degreaser and it ate all the rubber seals and killed the machine, find the right stuff and it'll be magic. I found the dishwasher detergent darkened the metal significantly, maybe certain brands work differently?
I just disabled the timer so it never drained and remained in wash mode. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Dec 07, 2016 9:04 am Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
I did that with all of my engine tins except the fan shroud in the dishwasher at a rental condo when I lived in Maryland. My wife knew about it too! And I saved our portable dishwasher when we built our new house and had hot & cold water and a drain plumbed to our garage just so I could use it for parts washing. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
jpaull Samba Member
Posted: Wed Dec 07, 2016 12:23 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
I'm Glad some of you guys found it works good too! _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
jpaull Samba Member
Posted: Wed Dec 07, 2016 12:39 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
FreeBug wrote: |
The cascade with bleach works really good! Use the prewash and normal wash, it was almost 3 hours in my dishwasher _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Zundfolge1432 Samba Member
Posted: Wed Dec 07, 2016 1:55 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
Three hours for a 20 minute job no thanks, it looks cute though. We've always gone to local coin op car wash used the wand and high pressure. Wear safety glasses. Oven cleaner preferably easy off cleans the case very nicely and like I said you can be done in minutes not hours. Many machine shops have an industrial type hot water wash with a turn table that rotates the parts as well.
Is this where you got the idea? |
jpaull Samba Member
Posted: Wed Dec 07, 2016 2:36 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
Zundfolge1432 wrote: |
I used to work in a machine shop and yes we did have a nice hot washer that was much like a big dishwasher haha. It was definitely something that used industrial detergent and only took about 5-10 mins.
3 hours in a dishwasher is no big deal. Its not for degreasing, its for brightening the case, as all other ways I tried just made the case darker. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Posted: Wed Dec 07, 2016 5:49 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
I forgot what type of detergent they used in the industrial cleaner and there was an additive to prevent flash rust, but it did clean the shit out of engine and transaxles I gotta admit. Cleanliness is all that matters when you are building stuff. The only thing missing here is using a Bosch dishwasher? cheers |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Wed Dec 07, 2016 7:18 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
This is best if your dishwasher has a stainless inside...especially for keeping it a secret from your wife.
I use the dishwasher only for the final cleaning. Soda blasting first, then remove all plugs, clean oil paths over and over with rifle brushes and patches with solvent. Then throw it in the dishwasher...if you have a steam cycle use it.
I put mine threw about three cycles |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1852 Location: Grass Pants, Orygun
Posted: Wed Dec 07, 2016 8:16 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
I've done it a time or two. LOL _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
jpaull Samba Member
Posted: Wed Dec 07, 2016 9:48 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
txoval wrote: |
Yes!! That's exactly what its great for, final cleaning/brightening after all the major cleaning is done _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
jpaull Samba Member
Posted: Wed Dec 07, 2016 9:49 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
stealth67vw wrote: |
I've done it a time or two. LOL |
I love it!!!!! Your picture, its like Art. I would stop and look at that case chillen in the dishwasher and just stare at the beauty for awhile hehe _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Thu Dec 08, 2016 2:25 am Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
That's cool man
I've been thinking about doing the same,
I'm just worried that the detergent will be too caustic for the mag case.
Or am i just too scared? _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31359 Location: Hot Arizona
Posted: Thu Dec 08, 2016 7:45 am Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
Hmmm - I just got my engine case back from the machine shop, where it had been dipped and align-bored, case savers installed, etc. Machinist said to clean it again before building, so this is an interesting idea, mine wouldn't have grease on or in it now.
But more likely I'll take to $3 car wash and spray/rinse well (wouldn't want Mrs. Cusser to get her nipples all riled up !!!), then bring home and blow out any passages with compressed air. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
jpaull Samba Member
Posted: Thu Dec 08, 2016 2:45 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
hobbybob517 wrote: |
That's cool man
Or am i just too scared? |
Cascade with bleach dishwashing detergent is not a hazard to your case at all. Remember that its designed to clean plates and eat off them later. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
jpaull Samba Member
Posted: Thu Dec 08, 2016 2:48 pm Post subject: Re: Magic Case Cleaning (Don't Let Wife/Girlfriend See!) |
Cusser wrote: |
But more likely I'll take to $3 car wash and spray/rinse well (wouldn't want Mrs. Cusser to get her nipples all riled up !!!), then bring home and blow out any passages with compressed air. |
Does the case look good uniform color now?
Does Mrs Cusser spy on your Samba posts? if so, I will save my next suggestion and let you assume what to do _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
