Best case sealant-Aviation Permatex or Yamabond
PHAT4
PHAT4 is offline
PostPosted: Fri May 20, 2005 11:15 am    Post subject: Best case sealant-Aviation Permatex or Yamabond Reply with quote
I know about Permatex Aviation 2H.
I was at my machinists and asked him if the Permatex was the best thing to use.He replied it is good but there is something better.
It's called Yamabond.
You guessed available through Yamaha.After a bit of research I found plenty of positive feebdack for this product.The only problem is which one to use.If you look here you can see there are many different formulas to chose from.
http://www.yamaha-motor.com/outboard/apparel/apsubcontaineritems/3/123/801/1/detail.aspx
Also I read that it is made for them by 3M.Apparently they also make it for other manufacturers like Suzuki(Sazukibond) and Ducati(Ducatibond).
Though I can't even find it listed on the net, I guess 3M also sells the same product under their own label but I don't know the name.It would probably be cheaper getting it this way.
Anyone use this stuff, what do you think of it?
I know about Hylomar but I think Aviation Permatex probably has it beat.
BattleShipBus
BattleShipBus is offline
PostPosted: Fri May 20, 2005 11:47 am    Post subject: Reply with quote
Yamabond 4 or Threebond 1104 is the same sealant and excellent.
If you can find it Threebond makes a sealant 1 stedp better called 1211
Apply sparingly to one half and left it flash for 1-2 minutes and then assemble. You will NEVER have case leaks.
Andy
PHAT4
PHAT4 is offline
PostPosted: Fri May 20, 2005 12:03 pm    Post subject: Reply with quote
Threebond...Yea that's the stuff I thought was made by 3M.
This the right stuff?
http://www.naturecoastmotorsports.com/eshopprod_ca...T_1104.htm
http://www.naturecoastmotorsports.com/eshopprod_ca...D_GASK.htm
Is there any easy place to get that stuff other than a cycle repair center/dealership??
When you rebuild what do you clean it off the case with?
wheel607
wheel607 is offline
PostPosted: Fri May 20, 2005 1:47 pm    Post subject: Reply with quote
anyone still using Gasgacinch??
fastback1971
Samba Drummer
fastback1971 is offline
PostPosted: Fri May 20, 2005 2:33 pm    Post subject: Reply with quote
In aviation we use a 2-part sealant called pro-seal. Messy stuff but it seals great. Better than any pre-mixed tube stuff. Ive also heard Dave Kawell uses(used?) the sealer G.M. uses on their cars. He said it was great. I havent used it though.
I refuse to tiptoe through life, only to arrive safely at death.
PHAT4
PHAT4 is offline
PostPosted: Fri May 20, 2005 3:15 pm    Post subject: Reply with quote
You talking about the black stuff?
GMS I think they call it.
fastback1971
Samba Drummer
PostPosted: Fri May 20, 2005 3:56 pm    Post subject: Reply with quote
Im not really sure. I talked at length with Dave and he mentioned it as he was talking. I cant tell you much about it. Call him. As for the pro-seal, its black, after you mix it. Two parts, white and black, smells like rotten eggs. Good stuff though, works on 300mph airplanes.
Jake Raby
Jake Raby is offline
PostPosted: Fri May 20, 2005 4:35 pm    Post subject: Reply with quote
I use Curil K2 for cases... And a piece of waked dental floss across the bottom part of the sump area.. Even without sealant it won't leak with this trick.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
PHAT4
PHAT4 is offline
PostPosted: Fri May 20, 2005 4:48 pm    Post subject: Reply with quote
Waked dental floss across the bottom part of the sump area?
You mean just sandwiched between the two?
Jake Raby
PostPosted: Fri May 20, 2005 4:54 pm    Post subject: Reply with quote
opps.. WAXED floss..
Yes, right between the case halves- it compresses to less than .001 when you torque it up.
Smile thats an old pratt and whitney trick from long ago..
Jake Raby
PHAT4
PHAT4 is offline
PostPosted: Fri May 20, 2005 5:02 pm    Post subject: Reply with quote
Laughing Gotcha
nsracing
nsracing is offline
PostPosted: Fri May 20, 2005 9:16 pm    Post subject: dental floss? Reply with quote
So a piece of dental floss?
I tore a Type IV motor apart once before with a piece of some kind of thread stuck between the pan...and I said WTF?
It was not completely squashed. So if the thread is around 0.001 inch thickness, that means the case is actually warped to the "NEW" flatness. Assuming of course the case was flat to begin with.
YOu can see daylight through 0.001 inch gap.
The case halves are machined so nicely from factory that all is needed is some Aviation goop to fill the minute scratches from the toolbits passes. I mean you cannot even see the scratches sometimes they are that good. The Aviation goop you can squash to nothing and seal without warping the part.
If you put a thread on one end of two items that are flat, it is literally a wedge. And when you torque them down..middle and perimeter, all that is happening is bowing of the parts.
I would bet that after the case has been torqued with a thread for some time will have a gap equal to the dimension of the thread when you remove the thread.
Machine work on parts have evolved so advanced now that the tolerances are so awesome we can run 5W-30 oil and idle at 500 RPM on new cars.
Maybe out of necessity the thread was used to compensate for poor quality machining?
It is interesting.
JamesT
JamesT is offline
PostPosted: Fri May 20, 2005 10:17 pm    Post subject: Reply with quote
I've never had a problem with leaking at the case split and I just use a thin layer of permatex on each side. I've been told about the dental floss trick, but it's never seemed to be needed. I do see how it could end up warping the case, but that would only be a problem the next time you rebuild the motor.
-James T
1968 Kombi (Weekend warior project)
1982 Rabbit Pickup (Forever a project)
vwchaos
vwchaos is offline
PostPosted: Sat May 21, 2005 8:42 am    Post subject: Best case sealant Reply with quote
I don’t how to define “best”, I have had fine results with Gasgacinch (sp) on a new case. I have also had fine results with “aviation” Permatex on used cases. The Permatex has also provided good results for several of my friends on their engines. The motor I am just finishing has Yamabond between the case, I have heard very good things about this product and wanted to try it myself. I was not aware of different Yamabonds; the product I used was light gray and quite thin. On the topic of using thread/floss between the cases, the information I have was from the web 4 or 5 years ago and went like this. Ex-aviation mechanic recalled a Lycome (sp) engine rebuild procedure. Using silk thread size “00” apply your sealer of choice, let tack lightly lay the thread along the case parting line above boltholes and studs. I have not tried this yet but will eventually. I am not real “up” on fabric stores so I spent around 3 hours finding real silk thread in “00” size. The clerk at the store sure thought I was crazy when I told her what I needed if for. Once I had the thread in the shop I measured it for “crush” and with a calibrated Starret micrometer the thread crushed to the point of no perceptible reading, no I wasn’t cranking down on the mic, the thread is that thin. I think the “thread/floss” method would work well using the correct size thread. I suggest using “common sense” talk to folks, see what they use and then go for it, just keep it thin and use it sparingly. Jake, since I learned of this from an aviation mechanic it does not surprise me to see you advocate this method.
BattleShipBus
PostPosted: Sun May 22, 2005 2:01 pm    Post subject: Reply with quote
Gaskacinch of today is NOT the same formula of say 3 years ago. They changed the content to be more EPA friendly.
Yamaha today uses the 1211 formula for sealing metal to metal mating surfaces.
Most people use too much sealer when sealing cases. It simply needs a skim.
NEVER use a Yamabond 5!!!!!!!!!!!!!!!!!!!!!!!!!
Yamabond 4, Threebond 1104, Honda 4, Kawasaki semi sealer and Suzuki sealant are all the same.
I would never use a rvt style sealer as it is just too thick for the tolerance you are trying to seal. All you need to do is fill the miniscule imperfections.
Andy
earthmuffin
Samba Worm Farmer
earthmuffin is offline
PostPosted: Sun May 22, 2005 4:22 pm    Post subject: Reply with quote
The 00 silk thread that is used on aircraft engines is applied all the way around the case so there is no chance of case warpage. It is not used as a crutch for poor machining, but rather just a backup for the sealant. actually Lycoming and Continental cases are machined to pretty tight standards. I think they are a lot better quality than any VW case I've seen.
I personally would never use proseal on a case. It is TOO good. If you ever have to perform an overhaul, you'll spend days picking that stuff off the case.
This thread SUCKS!!!
Dan22
Dan22 is online now
PostPosted: Mon Aug 17, 2020 3:54 pm    Post subject: Re: Best case sealant-Aviation Permatex or Yamabond, Or Neither? Reply with quote
Old thread, but worthy of an update. Definitely relevant.
I found this link from a Porsche site.
https://klassikats.com/index.php/2019/11/08/porsche-crankcase-sealant/
I am going to go with the Loctite 574!
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
fredybear
fredybear is offline
PostPosted: Mon Aug 17, 2020 4:24 pm    Post subject: Re: Best case sealant-Aviation Permatex or Yamabond Reply with quote
Perfect timing for 2020 Cool
now on to painting my studs Shocked
Dan Ruddock
Dan Ruddock is offline
PostPosted: Mon Aug 17, 2020 5:14 pm    Post subject: Re: Best case sealant-Aviation Permatex or Yamabond Reply with quote
I still use gaskacinch but only for valve cover gaskets to keep them in place. I use the gray yamabond for the case half’s. Dan
obieoberstar
obieoberstar is offline
PostPosted: Mon Aug 17, 2020 6:53 pm    Post subject: Re: Best case sealant-Aviation Permatex or Yamabond Reply with quote
Loctite 574 (the orange stuff).
Never have had any leaks.
And, the Porsche guys use it...
