ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Thu Jan 12, 2017 10:09 am Post subject: T handle nut pitch size |
I have gone and lost the nut for my T handle. I know it is an M10 but I can not figure out the pitch size. I tried an M10 X 1.0 it wobbles a bit it seems like the thread on the handle is a little finer thread. Any help would be appreciated, my pitch finder in my tap set does not have the right size. Thanks _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
BotanyBandit Samba Member
Joined: February 13, 2013 Posts: 224 Location: Kansas City
Posted: Thu Jan 12, 2017 2:32 pm Post subject: Re: T handle nut pitch size |
I have run into a lot of 1.25 pitch, I can measure my handle when I get home but mine is an aftermarket. |
Posted: Sat Jan 14, 2017 9:35 pm Post subject: Re: T handle nut pitch size |
BotanyBandit wrote: |
I just tried a nut from a locking aftermarket one. It was way to large. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Abscate Samba Member
Posted: Sun Jan 15, 2017 3:52 am Post subject: Re: T handle nut pitch size |
Put a 1 cm scale against the threads and count 10 thread depth yo measure.
It will be1.0, ,1.25, 1.5 mm per thread _________________ .ssS! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Jan 15, 2017 7:56 am Post subject: Re: T handle nut pitch size |
If M10 x 1.0mm is too big, that's about as fine thread as M10 exists. This is an aftermarket unit, ya' sure it's not 3/8 inch instead? 3/8 inch is about 9.5mm.
Is this a locknut for the unit? If so, is the shifter threaded too? If so, unscrew the shifter and take that to Ace Hardware, have a gray-haired guy help you. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
anthracitedub Samba Member
Posted: Sun Jan 15, 2017 8:33 am Post subject: Re: T handle nut pitch size |
I just went and placed a pitch gauge on mine from my 62... the pitch is indeed 1.0 |
