rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Fri Dec 04, 2015 3:30 pm Post subject: Checking R&P ratio with transmission in the car |
How can I verify what my R&P ratio is when the motor and transmission are still in the car? I had my stock '63 swing axle trans rebuilt with a 4:12:1 R&P and I just want to be sure of what's actually in there.
A search turned up methods such as jacking up the car, turning the engine over 10 revolutions by hand, and then counting tire rotations to figure the ratio. What gear should it be in when doing this? Can anyone clarify this method and give me some examples of how many times the tires should rotate when the motor turns 10 revolutions (in which gear) for the different R&P ratios?
Another post suggested putting the trans in 2nd gear and see how many motor revolutions it takes to turn the tires one complete rotation. It goes on to say that 8 turns indicate a 3.88:1 R&P, 8 1/2 turns is a 4:12:1 ratio and 9 turns is a 4.38:1. When I tried this, I got a full tire rotation with less than 6 revolutions of the motor, so something's not right here.
Does anyone have a reliable, easily-explainable method for checking the R&P ratio? All gear ratios are stock for a '63 swing axle trans: First 3.80:1, Second 2.06:1, Third 1.32:1 and Fourth 0.89:1. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Fri Dec 04, 2015 4:16 pm Post subject: Re: Checking R&P ratio with transmission in the car |
rcooled wrote: |
Another post suggested putting the trans in 2nd gear and see how many motor revolutions it takes to turn the tires one complete rotation. It goes on to say that 8 turns indicate a 3.88:1 R&P, 8 1/2 turns is a 4:12:1 ratio and 9 turns is a 4.38:1. When I tried this, I got a full tire rotation with less than 6 revolutions of the motor, so something's not right here. |
It indicates your wheel's brake was dragging.
Another way to do this is jack one rear wheel off the ground and repeat the test in 2nd gear. Except this time, count the number of engine revs needed to generate two full turns of the tire in the air. _________________
Posted: Fri Dec 04, 2015 7:53 pm Post subject: Re: Checking R&P ratio with transmission in the car |
Bruce wrote: |
It indicates your wheel's brake was dragging. |
Thanks for the input, but if a brake were dragging, wouldn't it require more motor revolutions for one complete rotation of the tire I marked, not fewer? Instead of 8 or 9, my tire made a full rotation with only 6 revs.
Bruce wrote: |
Another way to do this is jack one rear wheel off the ground and repeat the test in 2nd gear. Except this time, count the number of engine revs needed to generate two full turns of the tire in the air. |
OK Bruce, I'll give this a try and make sure that the brakes are completely backed off. Will it be the same number of motor revs for two tire rotations now...8 1/2 for a 4.12 & 9 for a 4.38? _________________ '63 Ragtop (current)
Bruce Samba Member
Posted: Sat Dec 05, 2015 3:18 am Post subject: Re: Checking R&P ratio with transmission in the car |
rcooled wrote: |
Bruce wrote: |
Thanks for the input, but if a brake were dragging, wouldn't it require more motor revolutions for one complete rotation of the tire I marked, not fewer? Instead of 8 or 9, my tire made a full rotation with only 6 revs. |
You weren't watching the other wheel, were you? The wheel you were watching had the dragging brake. While the brake stopped that wheel, the other one was turning twice as fast. Until the first wheel started turning again.
rcooled wrote: |
Bruce wrote: |
OK Bruce, I'll give this a try and make sure that the brakes are completely backed off. Will it be the same number of motor revs for two tire rotations now...8 1/2 for a 4.12 & 9 for a 4.38? |
Yes. Don't touch the brakes. The dragging brake won't stop the one wheel in the air this time. _________________
EVfun Samba Member
Posted: Sat Dec 05, 2015 2:09 pm Post subject: Re: Checking R&P ratio with transmission in the car |
For all Bugs with a tunnel type transaxle ('61 up) jack 1 rear wheel up off the ground turn the crank pulley until the timing mark of your choice is strait up. Mark the tire that is off the ground so you know where strait up is on it. Chock the car, put it in second gear, and release the e-brake. Turn the engine until the mark on the tire goes one full turn. If the crank is right back at the timing mark it is a 3.88 R&P, if it is 1/4 turn past the timing mark it is a 4.12 R&P, and if it is 1/2 turn past the timing mark it is a 4.37 R&P. _________________
Wildthings wrote: |
Posted: Sun Dec 06, 2015 1:53 pm Post subject: Re: Checking R&P ratio with transmission in the car |
Bruce wrote: |
...jack one rear wheel off the ground and repeat the test in 2nd gear. Except this time, count the number of engine revs needed to generate two full turns of the tire in the air. |
EVfun wrote: |
Turn the engine until the mark on the tire goes one full turn. If the crank is right back at the timing mark it is a 3.88 R&P, if it is 1/4 turn past the timing mark it is a 4.12 R&P, and if it is 1/2 turn past the timing mark it is a 4.37 R&P. |
Thanks guys! Checked twice using the two methods you suggested and verified that the R&P is indeed a 4.12, which is exactly what it's supposed to be. _________________ '63 Ragtop (current)
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Dec 06, 2015 7:04 pm Post subject: Re: Checking R&P ratio with transmission in the car |
For someone who searches in the future... hopefully.
Another method.. ..easy to do while changing the fluid..
VOLKSWAGNUT wrote: |
You can just count the ring gear teeth through the rear trasnaxle drain plug..
To help identify 1961 and newer tunnel transaxle ring and pinion ratios, the ring gear teeth can be counted through the rear transaxle drain plug hole...
35 teeth = 4.38
33 teeth = 4.13
31 teeth = 3.88 |
Wear safety glasses while counting..
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Dec 08, 2015 2:14 pm Post subject: Re: Checking R&P ratio with transmission in the car |
35 teeth = 4.38
33 teeth = 4.13
31 teeth = 3.88 |
Yeah, I found this post when I searched. One question: How do you mark a tooth so that you know where the count starts? Not easy when everything's covered in gear oil... _________________ '63 Ragtop (current)
Posted: Tue Dec 08, 2015 2:19 pm Post subject: Re: Checking R&P ratio with transmission in the car |
rcooled wrote: |
35 teeth = 4.38
33 teeth = 4.13
31 teeth = 3.88 |
Yeah, I found this post when I searched. One question: How do you mark a tooth so that you know where the count starts? Not easy when everything's covered in gear oil... |
Its very easy..
Too easy as a matter of fact.
Drain the transaxle.. by removing the rear drain plug,
Allow to drip. (Jacking up the rear after being drained level helps stop or slow the drips.)
Spray carb or brake cleaner directly in the drain hole at the teeth, let dry.. Mark a single tooth with a grease pencil or paint pen. .. or make a small indention mark with a punch..
Roll and count..
Just dont forget IF you counted the marked tooth first or last..
. _________________ aka Ken {o\!/o}
EVfun Samba Member
Posted: Tue Dec 08, 2015 5:14 pm Post subject: Re: Checking R&P ratio with transmission in the car |
It is an excellent method Volkswagnut, but I think mine is a lot easier -- you don't have to drain and replace the gear oil, crawl under the car, or even use a jack stand. It's method is simple math, since 2nd gear is always 2.06:1, and if one side of a differential is held still the other side turns twice as fast. If you suspect you may have an aftermarket 3.44 Ring and Pinion you need to count the crank turns because it will be 3.5 turns to 1 turn of the wheel.
Turns, divided by the gear ratios between the engine and axle, time 2 for the differential turning only one wheel, will equal 1 turn at the wheel.
3.875 R&P if: 4 / 2.06 / 3.875 * 2 = 1
4.124 R&P if: 4.25 / 2.06 / 4.125 * 2 = 1
4.375 R&P if: 4.5 / 2.06 / 4.375 * 2 = 1 _________________
Wildthings wrote: |
Posted: Tue Dec 08, 2015 7:49 pm Post subject: Re: Checking R&P ratio with transmission in the car |
EVfun wrote: |
It is an excellent method Volkswagnut, but I think mine is a lot easier -- |
I agree...
I never posted the tooth count method as being the easiest or the only way... but it is accurate and yet just one more method that could be used
It was merely added information to this topic in the slim hopes and chance someone in the future searches the forums and adds to an existing similar topic before starting a new one. .
Its nice to have good information in one spot..
If you 100% know the gear ratios of a particular gear..the math is pretty easy to figure crank rotation to wheel rotation.
One persons easy can be anothers difficult or vice-versa. .
Windisch Samba Member
Joined: October 30, 2014 Posts: 361 Location: Sacramento, CA 95822
Posted: Sun Jan 15, 2017 8:45 am Post subject: Re: Checking R&P ratio with transmission in the car |
And someone did just 'discover' this thread (in 2017) to benefit from the knowledge contained in it! It's good to know all these techniques for determining final drive gear-ratio! Thanks for that prescient sharing of information! _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Der Volkswagen ist ein Ausdruck der deutschen Kultur der Allrad Art ...
[The only irrefutable evidence we have that intelligent life truly exists elsewhere in the Universe is the fact that so far it has NOT contacted humanity...] |
VWNate Samba Member
Joined: October 04, 2016 Posts: 356 Location: Sunny So. Cal.
Posted: Wed May 10, 2023 6:04 pm Post subject: Checking R&P ratio with transmission in the car |
You guys are GREAT ! . _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
