reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1927 Location: Bloomington, IN
Posted: Tue Jan 10, 2012 9:21 am Post subject: window scrapers |
What are people doing for window scrapers? Is there a way to put new felt on the old ones? _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
bb412 Samba Member
Posted: Tue Jan 10, 2012 2:54 pm Post subject: window scraper |
good edea,,if you can glue new felt on the original chrome molding,, but on my car, only the outside felt was finish and make glass ratle, if you look your felt,, the 2 inner felt are good,, take the inner felt with the chrome molding on the right side door for to put on the outside lefgth side door,,they are the same,,this is one edea,,cheer,,bb412 |
Posted: Thu Jan 12, 2012 8:53 am Post subject: |
I am used to seeing an actual rubber piece that seals the window on cars. Did the 412/411 have a rubber seal or was it just a felt seal? _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
bb412 Samba Member
Posted: Thu Jan 12, 2012 11:10 am Post subject: window scraper |
i have see only the felt on the vw beefore 74,,,the rubber start with the rabitt or golf,, afther 75,, but i thing if you can buy the felt kit for the alluminium door for your home and glue that on the vw molding ,,but if you can use a rubber strip it can bee betther,, |
Posted: Sun Jan 15, 2017 5:29 pm Post subject: Rear vent water leak |
I am having a problem with water leaking to the inside from the side vents.
I had removed some of the foam in the rear side vent so I am not sure if that is the issue. Any help would be apprciated.
[/img] _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Sun Jan 15, 2017 7:25 pm Post subject: Re: window scrapers |
If you pop out one of those little plastic vsnts....you will notice that they have a seal under the outer chrome trim.
The way they worked when the seals were fresh/new........is that the little bucket dhaped vents had to be pressed in from the outside...fairly hard.. .until the little detents cli ked into place. This compressed the seals and kept the whole thing tight and leak free.
With age they shrink up and leak.
You can do two things that I know of.
1. Run a clean bead of black silicone under the chrome trime and wipe clran and smooth
2. Look in mcmaster carr.....search for foam cord. Tue knly two that fit the bill and are super soft and flexible....are EPDM.....best foam rubber for outdoor....its what your windshield gaskets are made of......or Santoprene. Next best.
They only come in 1/8" smallest cross section. At one time I sealed some of these up with 3/32" cord stock but that was many years ago and I bought jt at a local rubber supply in Dallas.
Carefully stick it down around the perimeter with black weatherstrip glue. Cut to exact length and jlin like an oring. Ray |
