Polo rack and pinion
Page: Previous  1, 2, 3  Next
CNC-Meister
CNC-Meister is offline
PostPosted: Thu May 19, 2016 8:38 am    Post subject: Re: Polo rack and pinion Reply with quote
Hi -Alex77-,
Just wondering if you are still making the Polo rack mount brackets?
I could do with one for my RHD link pin bug (56). It would probably be easiest for me to buy the set of laser cut parts ready for me to weld up the assembly, I have a 3" narrowed beam so things might need some modifying to fit.
I'll drop you a PM, please let me know..
Thanks
Adam
H2OSB
H2OSB is offline
PostPosted: Tue Jan 17, 2017 1:53 pm    Post subject: Re: Polo rack and pinion Reply with quote
Anyone know of an alternative rack for a 1303? These Polo racks look great for a standard Beetle because the steering arms on Beetle spindles face rearward, but they won't work for a 1303 with the arms in the front.
H2OSB
JeeWee
JeeWee is offline
PostPosted: Thu Aug 03, 2017 10:35 am    Post subject: Re: Polo rack and pinion Reply with quote
Hi Alex, what kind of steering dampers are user on te pictures? Are these beetle ones or G40 polo?
-Alex77-
-Alex77- is offline
PostPosted: Mon Aug 07, 2017 12:36 am    Post subject: Re: Polo rack and pinion Reply with quote
It is beetle steering damper. But i think its unnecessary Smile
Lasercut parts and CAD design
lightice
lightice is offline
PostPosted: Mon Aug 07, 2017 12:42 am    Post subject: Re: Polo rack and pinion Reply with quote
H2OSB
If you are a LHD user, look for a RHD polo rack.
RHD user, look for LHD polo rack.
IIRC Meyle still makes them.
lightice
lightice is offline
PostPosted: Mon Aug 07, 2017 1:48 am    Post subject: Re: Polo rack and pinion Reply with quote
I was also looking to convert my split bus to R&P steering.
I found someone with a LHD SB steering rack, he coverted his LHD beetle import to RHD and told me he wanted USD350 R&P.
VW&MGman
VW&MGman is offline
PostPosted: Tue Apr 17, 2018 4:15 pm    Post subject: Re: Polo rack and pinion Reply with quote
Hi All,
I'm thinking of installing a rack and pinion on my '69 beetle. I have a couple of questions.
Is it worth the effort? Will it have the same steering feedback as a more modern car?
I have a 2'' narrowed beam, would there be any additional modifications to be made?
Are there any kits out there that I could purchase in which I would not have to do too much R&D on? I'm looking for something more on the plug and play side.
Thanks
DOBBY-SA
DOBBY-SA is offline
PostPosted: Sun Jan 13, 2019 1:57 pm    Post subject: Re: Polo rack and pinion Reply with quote
Can this rack be flipped over and used for a right hand drive beetle?
I realise that the mount would need to be redesigned but would the rack work properly upside down? I.e no extra wear, lack of lubrication/ lubricant leaks etc...
@There is a kit available for the LHD models from France, kinda pricey but yeah:
https://www.mecatechnic.com/en-GB/kerscher-steering-rack-for-beetle_VJ51452.htm
DOBBY-SA
DOBBY-SA is offline
PostPosted: Sun Jan 13, 2019 2:04 pm    Post subject: Re: Polo rack and pinion Reply with quote
CNC-Meister wrote:
Hi -Alex77-,
Thanks
Adam
Looks like this is Alex's site: http://cal-look.no/lounge/index.php/topic,16738.0.html
challomoner
challomoner is offline
PostPosted: Sun Jan 13, 2019 3:01 pm    Post subject: Re: Polo rack and pinion Reply with quote
I think there are rhd and lhd versions of these racks available, could be wrong on this, you should shout Alex who sells the kits.
-Alex77-
-Alex77- is offline
PostPosted: Sun Jan 13, 2019 4:15 pm    Post subject: Re: Polo rack and pinion Reply with quote
Yes, there is available RHD racks too, but they are only available from UK VW dismantlers, as no new or rebuilt ones are made.
Rack bracket can be made also RHD, just bending the L-profile other way.
RHD conversions may need double jointed steering joint.
H2OSB
H2OSB is offline
PostPosted: Sun Jan 13, 2019 7:06 pm    Post subject: Re: Polo rack and pinion Reply with quote
Alex--
Quick question (indulge me a bit, please). For a Super Beetle, if I were to get a RHD rack and flip it the other way to use on a typical U.S. version of a Super, would the steering input be the correct direction?
H2OSB
(o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants.
-Alex77-
-Alex77- is offline
PostPosted: Mon Jan 14, 2019 1:06 am    Post subject: Re: Polo rack and pinion Reply with quote
Dont really know about 1303 rack and pinion steering..
UK Luke 72
UK Luke 72 is offline
PostPosted: Mon Jan 14, 2019 2:05 am    Post subject: Re: Polo rack and pinion Reply with quote
Citroen AX racks fit too Alex, no sure if that helps with not needing to flip them?
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
Blasted
Blasted is offline
PostPosted: Wed Jan 16, 2019 8:17 am    Post subject: Re: Polo rack and pinion Reply with quote
I had seen this https://www.kerscher-tuning.de/kaefer/index.php?gruppe1=Lenkung&gruppe2=Lenkung
Expensive but looks to be a complete kit.
I wonder how much of a benefit R&P steering is over a well set up steering box with new tie rod ends and ball joints.
cudabear
cudabear is offline
PostPosted: Wed Jan 16, 2019 12:13 pm    Post subject: Re: Polo rack and pinion Reply with quote
not to derail but whats the reason for the frame stiffeners? the bars from the front beam to the pan? Are they really necessary
cudabear
cudabear is offline
UK Luke 72
PostPosted: Wed Jan 16, 2019 3:11 pm    Post subject: Re: Polo rack and pinion Reply with quote
They're there to stiffen the frame.
cunningstunt
cunningstunt is offline
PostPosted: Tue Jun 15, 2021 11:32 am    Post subject: Re: Polo rack and pinion Reply with quote
Alex are you still selling the kits for rack and pinion or just the bracket for a RHD?
petrol punk
petrol punk is offline
PostPosted: Tue Jun 15, 2021 1:22 pm    Post subject: Re: Polo rack and pinion Reply with quote
Anyone tried using a Mk1 Golf/Jetta steering rack to do a rack and pinion conversion? They're cheap and plentiful here in the US, unlike the unobtanium Polo racks.
36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma
Page 2 of 3
