hogan029 Samba Member
Posted: Mon Dec 19, 2016 6:15 pm Post subject: Subaru Cruise Control |
Hi all,
I have put together this quick concept for putting a 2003 Legacy Cruise control system into my 1998 forester 2.5 Vanagon.
I know this has been covered before but I was hoping for some input. I was wondering if I was able to use the Small Car VSS signal without any issues?
Thanks! |
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
Posted: Mon Dec 19, 2016 10:45 pm Post subject: Re: Subaru Cruise Control |
This is my Subaru cruise control install. Uses the unit from a 2003 Outback with a SmallCar V.S.S. No problems with the control unit recognising the V.S.S signal.
http://forums.kombiclub.com/threads/new-project.52257/ |
JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Tue Dec 20, 2016 4:27 am Post subject: Re: Subaru Cruise Control |
Any vss should work fine.
The easiest way to add cruise is a Rostra aftermarket system. _________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
Posted: Tue Dec 20, 2016 9:39 am Post subject: Re: Subaru Cruise Control |
Thats great to hear.. I just polished up the diagram for all to share here in the future
I am going to try this as I already have all the components and dont want to spend 300$ on a rostra.. I will followup with pics of the build when I get around to it. |
0cean Samba Member
Danwvw Samba Member
Posted: Tue Dec 20, 2016 1:01 pm Post subject: Re: Subaru Cruise Control |
Today, Probably Not. I have a 2006 Outback and it has one of the worst cruise controls that I've ever driven. Charges Down Hills, slows way down going up on hills then takes off like crazy near the top and will vary 10 or 15 MPH between up hill and down hill when this happens. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Tue Dec 20, 2016 5:46 pm Post subject: Re: Subaru Cruise Control |
Once they went to the drive by wire throttle the cruise was controlled by the engine ecu. Also have a 2006 Outback (AU version of course) and don't have that sort of trouble with the cruise.
I used the Bentley to wire the cruise into the vehicle the same way as the stock cruise where possible.
I do get a surge oscillation on one particular downhill section when I'm on the highway, but this is a 200m section in a 400km trip. So I can put up with that. |
0cean Samba Member
Posted: Tue Dec 20, 2016 9:49 pm Post subject: Re: Subaru Cruise Control |
I would love to use the stock 2012 Subaru Cruise control buttons for my EE-20 build, yet I'm using completely different Stand alone engine management, so the stock ECU is not an option. Wish there was a way to make it work though. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3) |
Posted: Wed Dec 21, 2016 7:52 pm Post subject: Re: Subaru Cruise Control |
I wouldn't see why you couldn't use the buttons with an older cruise control system.. just a thought.. I could do some digging if you wanted.. |
0cean Samba Member
Posted: Wed Dec 21, 2016 8:17 pm Post subject: Re: Subaru Cruise Control |
I actually have the ECU and cruise control buttons from a 2012 EE-20. Adding the buttons to the big horn button on the steering wheel would look really good. IMHO.
If you could look, I would appreciate it. I really have no clue about it, yet I'm willing to try. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
0cean Samba Member
Posted: Wed Jan 18, 2017 10:40 pm Post subject: Re: Subaru Cruise Control |
Quick update. I have not been able to create a schematic for drive by wire as there is too much ECU tie-in.
Tonight I put together my concept in wire format. I had to use a light switch to emulate the clutch pedal. I just need to find a brave soul to drive my van while I try this out.
dlb154 Samba Member
Joined: December 27, 2006 Posts: 359 Location: Reno, NV
Posted: Thu Jan 19, 2017 5:24 pm Post subject: Re: Subaru Cruise Control |
I guess most don't have stock Vanagon Cruise Control. It was pretty straight forward hooking up the stock system to the Subaru conversion I did on my Westy. Just needed a Subaru actuator and the VSS off my speedometer and all worked fine. |
0cean Samba Member
Posted: Mon Jul 02, 2018 8:36 pm Post subject: Re: Subaru Cruise Control |
So... My experiment was a failure. I have regrouped and am trying this again. This time I am using an older setup from a 98 legacy with the vac servo instead of the electric throtle. I have also used both pedal switches as my previous diagram did not have them (they are required). Here is my mocked up pedal switches that I have got in there so far. I have to trim the brackets etc.
I will add the new wiring diagram once I test to see if this works in the next few weeks. |
Posted: Tue Jul 10, 2018 7:03 am Post subject: Re: Subaru Cruise Control |
Hey all,
Okay So I was able to finally get everything working with my cruise setup. The thing that was holding me back was the wiring for the Cruise Control Sub Switch. The wire colour was different from the schematics I was able to find online. This was a pretty easy setup and seems to work quite well.
Here is the Schematics that I have modified for sharing:
This is for the ’99 Legacy. I took the following parts off the vehicle at the wreckers:
Cruise Control Module – Part # 87022AC051
Cruise Control Sub Switch – Part # 1111000410
Clutch Switch – Part # JA4490
Brake Switch - Part #83311FJ001
Cruise Main Switch – Part #192146061581
Cruise Control Pump – Part # 87052AC030
Cruise Control Servo (With throttle cable and all tubing) – Part # 87012FA040 ( I used the non-electric verson)
I finally got it working and I am happy, it was a long road with this one. Hope someone else can use this. It cost me about $25.00 in parts from the junk yard to get this going. It should be noted that the lamp on the main switch does not turn green when the cruise is activated. I am not sure why but it threw me off for a bit.
This is my switch placement, still have to tidy it up.
**Note this is for a manual transmission setup*** |
dhaines Samba Member
Joined: April 27, 2011 Posts: 43 Location: Denver, CO
Posted: Tue Jul 10, 2018 7:53 am Post subject: Re: Subaru Cruise Control |
Nice work.
I installed the same system onto my van after installing a 98 EJ25.
I used the gowesty speedometer speed sensor to feed the ecu.
The vacuum servo cruise units are independent of the engine ECU which is nice as you can set the cruise speed but then use the throttle to accelerate up hills or pass people. After letting off the throttle, the cruise control will take over again.
It basically thinks that you suddenly went down a hill and ignores what you are doing.
The subaru cruise system can be wired into a vanagon cruise control steering column switch for a factory look.
also, no need to add the mechanical switches to the brake pedals, you can just tie the wiring into the hydraulic brake light switches.
Although, I do like the idea of using the mechanical switch to operate the brake lights instead of the (prone to failure) vanagon hydraulic _________________ 86 automatic westy with EJ25 Subaru and Peloquin TBD. Propex and working AC!! |
Posted: Tue Jul 10, 2018 8:11 am Post subject: Re: Subaru Cruise Control |
Thanks for the reply.. I didn't know about using the gas pedal going uphill, that's super helpful. I was having some issues with it so I used both stock switches. In retrospect, I would probably have used the brake switch on the master cylinder. I was having issues with it which I though was the brake switch but it ended up being the set/resume wiring. But I guess it works with what I have now.
I was surprised that there was no tach signal input. Thought there would be an over rev limiter but I will just have to pay attention. |
