Rusti shakelfurd Samba Member
Joined: September 06, 2015 Posts: 40 Location: Grants pass oregon
Posted: Thu Feb 09, 2017 9:19 pm Post subject: Homemade diy custom heater boxes ??? |
Has anybody ever made their own heater boxes I have a empi stinger setup and want defrost I am thinking about making my own boxes out of 4 inch exhaust pipe splitting it and putting it around the j tubes and welding in some baffle plates under it and piping the air through it. Has anybody ever done anything similar or have any ideas to get some defrost and maybe a Lil heat thanks in advance and BTW I am not getting rid of the stinger Imo it's not a baja without a stinger lol _________________ 1961 baja (soon to be turbo 1600)
Home made sand and woods rail |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Fri Feb 10, 2017 8:31 am Post subject: Re: Homemade diy custom heater boxes ??? |
Is there a reason you dont want tot use standard heater boxes? they will work with a stinger. |
Fenix Samba Member
Joined: October 05, 2016 Posts: 468 Location: St Louis
Posted: Fri Feb 10, 2017 11:17 am Post subject: Re: Homemade diy custom heater boxes ??? |
dirtkeeper wrote: |
will they work with the non-j tube stingers like tri-mill bobcat or bobtail. |
Posted: Fri Feb 10, 2017 9:11 pm Post subject: Re: Homemade diy custom heater boxes ??? |
Dirt keeper they won't work with the style I have the boxes run under the head where my exhaust runs over I made a box today I will finish it in the morning then post some pics just a test idle with it all tacked together it works bad ass so we will see it maybe the new thing to do _________________ 1961 baja (soon to be turbo 1600)
Q13931152 Samba Member
Posted: Sat Feb 11, 2017 12:40 am Post subject: Re: Homemade diy custom heater boxes ??? |
Your can around the tubing with baffles inside idea sounds like it ought to work if you can get enough heat transfer from the exhaust pipes into the baffles themselves . It sounds a lot like the old buggy heater thing that was available way back when, and I'm curious to see what you came up with.
One of my friends added stock heat exchangers into his exhaust system ( which sounds like it's very similar design to what you have with the tubes above the heads) using some off the shelf exhaust 90's from the local parts store and he just cut them to fit and welded them together himself . I think he ended up either having to clamp or weld the lower ends of the pipes onto the exchangers, but the end where they join with the rest of the exhaust is still a slip joint if I remember correctly so it's still removable . It works really well too.
Of course you could always have a muffler shop make the tubes you'd need to go between the heat exchangers and your exhaust very easily if you didn't want to go the whole diy route. _________________ Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. |
Posted: Sat Feb 11, 2017 8:55 am Post subject: Re: Homemade diy custom heater boxes ??? |
Posted: Sat Feb 11, 2017 9:33 am Post subject: Re: Homemade diy custom heater boxes ??? |
That's pretty clever ! I don't see any reason why that design wouldn't work once you're done.
BTW, that looks like the same exhaust my friend has on his buggy ( minus the stinger), so the modifications he made would work for yours as well. Come off of where the "J" tube enters the header with a pair of 90's and you're all set. _________________ Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind.
Posted: Sat Feb 11, 2017 9:46 am Post subject: Re: Homemade diy custom heater boxes ??? |
Q13931152 wrote: |
That's pretty clever ! I don't see any reason why that design wouldn't work once you're done. |
Agree I like the ingenuity. Didn't realize you had that type over the top header. |
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Sat Feb 11, 2017 10:51 am Post subject: Re: Homemade diy custom heater boxes ??? |
If you weld the baffles completely to the pipe, that will increase your heat transfer surface area. _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
smileyman3000 Samba Member
Joined: November 07, 2010 Posts: 238 Location: Yeppoon, Australia
Posted: Sun Feb 12, 2017 10:31 am Post subject: Re: Homemade diy custom heater boxes ??? |
Ya those boxes were pretty sweet I wanna know what he used for valves to block it off. Mine definately work but don't look that fancy. Pullstart they were just tacked in that pic easier to take apart if it didn't work
f
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Wed Feb 15, 2017 1:58 am Post subject: Re: Homemade diy custom heater boxes ??? |
Here is the first set that I built around 15 years ago. They are still in service today on my Baja. I opened them up because it was starting to smell pretty bad, and I wanted to make sure they weren't leaking. I closed off one end, pressurized them and put under water (notice the wheel stem). Turns out it was just 15 years of crud. Even though these don't have many fins, I get more heat then one would expect.
The last set I made is on my DD, and I used larger and a lot more fins. On them I used 3/16" aluminum plate that I bored the holes on a lathe for a tolerance fit. Then heated each plate, so when they cooled they shrunk onto the 1-5/8" J tube. I didn't take any pics, because that was before I joined the samba. I will say that I get heat sooner then the stock boxes, but the heat is not as "deep" as the stock ones. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
tdrrally Samba Member
Joined: January 05, 2011 Posts: 181 Location: charleston,wv.
Posted: Wed Feb 15, 2017 7:38 am Post subject: Re: Homemade diy custom heater boxes ??? |
i thought about making a set using antifreeze and a pump to circulate with a heater core up front
not as simple but could make good heat.
how well does the oil cooler for a heater work? |
Posted: Thu Feb 16, 2017 7:27 am Post subject: Re: Homemade diy custom heater boxes ??? |
i will say i like it
i thought about putting the heater in the rear under the back window or under the rear seat.
from a rally beetle |
