mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
Posted: Thu Jan 26, 2017 11:36 pm Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
slalombuggy wrote: |
The rocker blocks are what they are. I've used many different style adjusters and rocker arms and never had to do more than remove a few thousandths to gain some space (like .001-.003) There's no real harm in doing what he did, just that it might not have been nessesary.
One thing I will tell you to do is polish the sides of the rocker arms where they touch the shims. CBs coating is rough and will EAT the shims for breakfast lunch and supper if you don't polish them. I use a fine double cut file to clean off the worst and then some 240 grit paper and finally 600 grit. One side is easy as the rocker is offset, the other is kind of a pain. Do everything you can to keep the surface square to the bore.
brad |
Thanks again brad. I do believe he has done what you've said, but I will check for sure when they arrive. It's good to get experienced comment, one of the huge benefits of TS!
As for the new paintwork, I've resigned myself to a couple of hours cleaning paint off a few bits of wiring. I can see he didn't realise that was important to me, but I think overall it's going to look great once I get everything back together, and I'm really happy it's done! _________________ 1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery! |
c21darrel Samba Member
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Fri Jan 27, 2017 12:09 pm Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
c21darrel wrote: |
Quote: |
As for the new paintwork, I've resigned myself to a couple of hours cleaning paint off a few bits of wiring. I can see he didn't realise that was important to me, but I think overall it's going to look great once I get everything back together, and I'm really happy it's done! |
We have a tendency to focus on these things when they occur. Once you get it back together...no one is going to notice. Its a nice improvement to what it looked like before. I agree, be happy and dont sweat the small stuff. |
Not for the first time, I agree with Darrel, Phil. I (fondly) remember your car as a "survivor" car rather than a concourse restoration. As a very good example of the former, these minor blemishes are an asset, not a negative. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
dshawirwin Samba Member
Joined: June 17, 2016 Posts: 35 Location: Salt Lake City
Posted: Fri Feb 24, 2017 7:00 pm Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
Hello,
I know these are old posts but I'm sure taking a chance you'll see reply. You have very heplfull pics.
I'm hoping you can help me as I'm trying to repair my 68 reverse lights, but I'm not removing engine.
Your Wed Feb 04, 2015 post's first photo shows 2 wires with connector coming out of engine tarboard. The wires just belwo hood hinge. I have the same. Are these the wires that run to the backup lights mounted on bumper? OR what are they?
I'm confused because if they are backup light wires I thought they ran directly to the reverse switch on transmission nose.
Thank you so much! |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Sat Feb 25, 2017 2:01 am Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
dshawirwin wrote: |
Hello,
Yes, that connector has two wires that go to the reversing lights. Sputnik60's diagram shows it. A wire from the switch on the transmission comes through the firewall to connect to this connector.
Bleyseng Samba Member
Posted: Sat Feb 25, 2017 10:04 am Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
What is the white tubing on the bottom of the engine lid? _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
wcfvw69 Samba Purist
Posted: Sat Feb 25, 2017 10:08 am Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
Bleyseng wrote: |
What is the white tubing on the bottom of the engine lid? |
Looks like an added Blazecut. _________________ Contact me at [email protected]
The Samba member since 2004.
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sat Feb 25, 2017 8:40 pm Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
I'd put it on the bus as those catch fire easier... _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Posted: Sat Feb 25, 2017 11:49 pm Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
Thank you both very much |
Posted: Thu Mar 30, 2017 11:08 am Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
Ok. Time for an update!
The Kombi is away having a transmission service, so I've been making some progress with the Ghia. I'm taking my time to put the front trunk back together after the paintwork.
First job was to remove as much of the over sprayed paint as I could. Most was easy enough with thinner and a rag, but some wires had not been masked at all and have thick primer base and clear coat on. It's all a bit inaccessible, so some of the tough wires with no connectors were snipped out and done at home, I'll solder them back in later!
The rubber grommets at the back of the dash script had caught paint too and, predictably enough, trying to lever them off just managed to break one ! I'll glue it back, and I just cleaned up the other two in situ...
The last pics are of a felt buffer for the glove box hinge. I soaked that in thinner and scraped off the paint.
Posted: Thu Mar 30, 2017 11:28 am Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
The first job on the list has to rank as one of the fiddlyest on the whole car , fitting the fresh air diverter ducts. Dear me, they are a pain !
I've used MTB inner tube as the connector seals. If you fold it back on itself then it's simply a case of unrolling it over the metal ducts. Sadly the plastic diverters fit very badly into the space that's meant for them and leave no room for my largish hands to do the unrolling.
I suspect it would be easier putting a condom on a cat hiding at the back of your sock drawer, in the dark (and would result in fewer scratches) .
After I gave up, (on the heater ducts, not the cat ) I called my better half, who had a lot more success, but did still turn the air blue with her unhappiness. Job (eventually) done.
Posted: Thu Mar 30, 2017 11:46 am Post subject: Re: Late 1969 Ghia vert preservation/ restoration |
My experience with fitting those fresh air diffusers matches yours, Phil. I left a lot of my DNA in the form of blood and torn skin on the car when I fitted them.
I'm still trying to convince myself that if a challenge wasn't difficult there wouldn't be any satisfaction in achieving it.
Best of luck in your endeavours in tidying the crow's nest of wires in front of the dashboard. _________________ Festina lente - hasten slowly
