Rickles Samba Member
Joined: January 22, 2016 Posts: 213 Location: South Jersey
Posted: Fri Dec 30, 2016 12:35 pm Post subject: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
Is M12x1.5 the correct thread size for 67 and earlier T1's? This information is surprisingly difficult to find. Thanks. _________________ Rick
1967 VW Beetle - Savannah Beige
2002 VW GTi - Reflex Silver (Sold)
1966 VW Beetle - Bahama Blue (Sold)
1961 Porsche 356B Roadster - Signal Red (Sold)
1966 VW Beetle - Sea Sand (Sold)
South Jersey Volkswagen Club
Central Jersey Volkswagen Society |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Dec 30, 2016 12:40 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
It's actually very easy to find, but here it is anyway:
'67 down (wide 5) is 12mm x 1.5
'68 up (4 bolt) is 14mm x 1.5 _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Fri Dec 30, 2016 12:44 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
Thanks, Keith, maybe I just wasn't using the right search terms. I also tried Google. What do folks recommend for lug pins to hang the wheel on while staring the other lug bolts? _________________ Rick
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Dec 30, 2016 12:47 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
I just use my feet to move the wheel around to line up the bolt holes _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Keith Samba Member
Posted: Fri Dec 30, 2016 12:58 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
Once you've done it a few times and get the hang of it, it isn't that hard.
I sit on the ground (if it's not on my lift), put the wheel in between my legs and lift it with my shins or feet. I will put one lug bolt in loose to get started and then adjust the wheel to put another in and seat it finger tight and the the rest just go easily. _________________ Formerly known in the forums as "OVALTEEN"
Posted: Fri Dec 30, 2016 1:02 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
Thanks, guys, that's what I used to do in "the old days". I had an '84 BMW that came with a pin you would thread into the lug hole. That would be so much easier on these tired old bones. _________________ Rick
Keith Samba Member
Posted: Fri Dec 30, 2016 1:06 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
You could always find a stud or a bolt and cut the head off of it and thread that in to help you.
They do sell threaded studs for the drums, you could buy them to use as your assistant to put the proper lug studs in. _________________ Formerly known in the forums as "OVALTEEN"
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Fri Dec 30, 2016 1:11 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
I've also always used my feet.
Keith wrote: |
They do sell threaded studs for the drums, you could buy them to use as your assistant to put the proper lug studs in. |
That's actually a very good idea, can cut a slot to use a screwdriver if needed. One would just need one. I think I'll make one for myself.
Of course we're still jealous that you also have a lift. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Dec 30, 2016 1:13 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
Yes, Cusser, that BMW pin had a slot for that. I would LOVE to have a lift! _________________ Rick
Posted: Wed Feb 22, 2017 5:50 pm Post subject: Re: 67 Beetle: M12x1.5 correct wheel lugbolt size? |
I bought a pair of these on Ebay, about $12. Tried one for the first time today; worked perfectly, made it nice and easy to put the wheel back on.
