Augie Samba Member
Joined: February 15, 2004 Posts: 160 Location: LI, NY
Posted: Wed Feb 22, 2017 6:33 am Post subject: case savers |
I am looking for 12mm case savers. I see aircooled.net are out. Anyone have a source?
Thanks, Augie |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Wed Feb 22, 2017 6:50 am Post subject: Re: case savers |
Google search for "12 mm case savers" brought up a list of vendors. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Fenix Samba Member
Joined: October 05, 2016 Posts: 468 Location: St Louis
Posted: Wed Feb 22, 2017 8:15 am Post subject: Re: case savers |
Augie wrote: |
Thanks, Augie |
Auto zone, Car Craft, Advance Auto, etc... |
stanthedog Samba Member
Joined: October 11, 2006 Posts: 357 Location: Portland,oregon.
Posted: Wed Feb 22, 2017 3:14 pm Post subject: Re: case savers |
Just curious, why doesn't anyone use helicoils. When I was in collage, instructor did a demo on them, you'd blow the case apart trying to get them to strip. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Wed Feb 22, 2017 5:35 pm Post subject: Re: case savers |
Heli-Coils are great. But if you can use even bigger outer diameter, it'll be even stronger.
They are very nice for repairing or reinforcing any of the M8 threads on the case.
For head studs, I would go case saver to maximise strength.
*edit*
I used a lot of Heli-Coils when working with engines in the past. They are really good when used in the right place. The first knockoff brand I saw and tried were called Re-Coil, and they were actually just as good.
Nowadays there are all kinds of cheap copies of copies that people would call by the original name.
I recently bought a cheap kit just to try it out on a frying pan that needed a thread repair.
The coils are goodish but the taps are sketchy garbage. Probably named differently across the globe depending on market preferences.
You get what you pay for. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
modok Samba Member
Posted: Wed Feb 22, 2017 5:49 pm Post subject: Re: case savers |
The reason they strip out is not just a matter of strength, it's more a matter of expansion and contraction and fatigue. They say the most load is on the first thread. So, the first thread breaks, then the second thread is the first thread, and it breaks, and so on. A helicoil does not solve this as well as a time sert.
Time sert probably does make a VW case saver but it will cost more, and requires the expander tool. |
Posted: Wed Feb 22, 2017 5:56 pm Post subject: Re: case savers |
modok wrote: |
This is true, but the first thread will be almost twice as strong as the stock first thread (M8 ), so there is a real benefit using them all the same. In the right place. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
modok Samba Member
Posted: Wed Feb 22, 2017 6:48 pm Post subject: Re: case savers |
Yeah, a heliciol is stronger than nothing, that's for sure. But they don't seal oil very well |
Posted: Wed Feb 22, 2017 7:03 pm Post subject: Re: case savers |
modok wrote: |
Now you're being grumpy. Heli-Coils have their place. If oil leaking is an issue, gaskets or glue will fix that.
If more strength is needed, a threaded bushing will be stronger. And theoretical oil leaks will still have to be adressed. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
raygreenwood Samba Member
Posted: Wed Feb 22, 2017 7:21 pm Post subject: Re: case savers |
Helicoils do have their place.....but not in cast aluminum or magnesium that is A. not hardened and B. Sees heat cycling.
Helicoils are nothing more than springs in reality. As load is appied in soft materials to the steel thread lands of the helicoil....if the host material deforms even the slighteat amount under load.....the helicoil expands with it ....side loading the thread lands.
At room temp you already get a few microns of defrormation of mag and aluminum. Adx heat expansion...and that side load grows. It will eventually shear the thread lands of the softer material.....meaning the case.
I only use helicoils in aluminum or mag...... A. When I am forced to and B. When its a large, non-heat cycling block of hardened metal.
Helicoils work very well in steel and cast iron.
Use an EZ-Lok solid wall insert or similar. The cost is no higher...and recently....most true value hardware stores have been carrying a decent range of EZ-lok brand solid wall inserts.
If you use a more coarse outer thread on the inserf...they will be stronger. Ray |
mark tucker Samba Member
Posted: Wed Feb 22, 2017 8:06 pm Post subject: Re: case savers |
springs!!! springs??? springs...realy ray springs.... I was in a pawn shop some 35 years ago..or more and they had this box of...heli coils there.no price. so we asked how much and they looked at the one in my brothers hand and said heck those tiny springs should be worth a penny a peace. so we bought a dollars worth. you I like tham springs but I dont see many places for them on the vw head stud issue. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Fri Feb 24, 2017 10:24 am Post subject: Re: case savers |
stanthedog wrote: |
Should've spent less time in art, more time in English class. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Fenix Samba Member
Posted: Fri Feb 24, 2017 11:00 am Post subject: Re: case savers |
SBD wrote: |
stanthedog wrote: |
Should've spent less time in art, more time in English class. |
What if your degree was in an Art field?...I do have a BFA working toward and MFA.... |
Posted: Fri Feb 24, 2017 1:47 pm Post subject: Re: case savers |
Technically....yes....they are springs by design. Even though they are not made of spring steel...they are shaped like....and also behave like ....sprins in the fact that they expand and contract when pushed or pulled. This is a feature you do not want in a malleable metal.
That.....and I DO have a BFA.....primarily in product design. I parlayed that degree along with material studies in the Architetcure program....into work for numerous industrial equipment manufacturers. Having been into and worked in about 3800 manufacturing plants ranging from aircraft, automotive, appliances, medical devices, electronics.....you name it....over the past 28 years....including two spring manufacturing facilities
So when I describe a piece of metal as .....basically a spring....i probably have a good idea of what I am talking about.
And dont Dis art school. Not everyone with a BFA was involved in basket weaving and painting classes in these programs. Ray |
Posted: Fri Feb 24, 2017 2:07 pm Post subject: Re: case savers |
settle down ray I wasent disagreeing with!! exzctly the opposite !!! as far as degrees /diplomas I have a few.... and also a BFH. |
SBD Samba Member
Posted: Fri Feb 24, 2017 4:35 pm Post subject: Re: case savers |
Fenix wrote: |
SBD wrote: |
stanthedog wrote: |
I've got a Bachelor's in Organismal Biology with a minor in Chemistry. Worthless degree! Plus an Associate's Degree and degrees from a couple of tech schools. I'm a well educated ne'er-do-well!
Oh, and I have a brother with some high-falutin' art degree. Gotta' watch out for him. He was an art critic for a time! _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
Posted: Fri Feb 24, 2017 8:45 pm Post subject: Re: case savers |
I know......you are just stirring the pot and tweaking the noses...... ........I got your between the lines meaning. I just tweaked back in case others didn't.
But yes.....I dont see any place for those damn springs on VW head studs. Will they work? Sure!....but in the same respect and at about the same level.....so would JB weld. the question is how long?
Ray |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Fri Feb 24, 2017 9:09 pm Post subject: Re: case savers |
Just curious here - in all the type 1 and 3 engines Dad and I rebuilt in the late '60s to the early '80s we never had to use a heli coil, case saver or had a pulled head stud. What were we doing wrong?
Granted, these were all basically stock engines. Is that the difference? |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Feb 24, 2017 9:48 pm Post subject: Re: case savers |
oprn wrote: |
Is my guess is the weather inCanada. _________________ Good Luck
Al |
Posted: Fri Feb 24, 2017 10:20 pm Post subject: Re: case savers |
oprn wrote: |
No...your engines were just in good shape and you were careful. With age, rust, grime and owners overtorqueing head studs....and/or hard driving and heat cycling.....it happens.
Personally....I like type 4 engines. We rarely if ever have the issue anyway. Aluminum case.
Ray |
