wolfgang67 Samba Member
Posted: Sun May 22, 2005 2:19 pm Post subject: how do i remove this type 3 fan! |
i am at home..converting this old sqaure engine into a type 1 ! this stubborn fan refuses to come off. im 15..so i dont have those "special" tools most older gentelman with volkswagens do..( no offense)..how is a "redneck" yet safe way to remove this damn thing? any help is appreciated. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun May 22, 2005 2:30 pm Post subject: |
Does your neighbor have a steering wheel puller you can borrow??
If not, try this.
There are 2- 8mm holes tapped int the fan hub. Useing 2 longish 8mm bolts. and a piece of steel bar that has holes to line up with the 2 in the fan, put a 7/16" deep socket in the hole in the end of the crank, with a short extension. Now, put the bar across, with the 8mm bolts, and slowly start tightening the bolts alternately. As you run out of threads, put a longer extension or stack some 8 mm nuts in the bottom of the hole in the crank, and start over with the bolts. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
SquareTone Samba Member
Joined: July 10, 2003 Posts: 1204 Location: Jenks, Oklahoma
Posted: Thu May 26, 2005 9:47 am Post subject: |
Or (assuming it's in good enough shape to mess with in the first place) you could sell it to someone who's in need of a T3 engine, buy yourself a proper T1 engine, and save yourself a ton of work. Might even come out a few $ ahead. |
Posted: Thu May 26, 2005 10:20 am Post subject: |
If you get the fan off without bending it, I would be interested in getting it from you. Depends on the condition, as to the price. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Bobnotch Samba Member
Posted: Fri May 27, 2005 8:07 am Post subject: |
Yeah, or you could go to your local Car Quest or Autozone and buy or rent a harmonic balancer tool. I got one from my local Car Quest for 10 bucks, and I've used it on many of my projects (both foreign and domestic). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Gary Massin-Ball Samba Member
Posted: Fri May 27, 2005 1:31 pm Post subject: |
Actually if you just use the longish bolts mentioned earlier and thread them carefully thru the fan hub using the threded holes you can actually push against the fan housing to push off the large fan. be very carefull not to tighten one or the other too tight or you can push thru the housing. Just one turn each bolt evenly till it will come off by hand and your done.
Gary. |
Posted: Fri May 27, 2005 3:16 pm Post subject: |
Gary Massin-Ball wrote: |
Gary. |
And break the friking fan housing.
I have 3 fan housings here that are junk because someone did that. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
