Big Fat Samba Member
Posted: Mon May 30, 2005 6:40 am Post subject: Name that noise... |
Within the past couple of days my '67 has started making this weird sound when running. It's almost like a slight squeaking coming from (it sounds like) the passengerside of the engine bay. It's not super loud - I'd liken it to a mechanical bird being stuck in the engine - but it is annoying as heck. It seems like it might be RPM dependent too, that is, it increases / decreases slightly with a rise / drop in RPMs.
Anyone wanna take a guess as to what this might be? _________________ Ice Blue '67 Squareback |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon May 30, 2005 7:21 am Post subject: |
Crack in the head?? Around the spark plug hole. Or a head stud that has just started to pull. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Mon May 30, 2005 7:29 am Post subject: |
Russ Wolfe wrote: |
Crack in the head?? Around the spark plug hole. Or a head stud that has just started to pull. |
Really? ...cause that sounds pretty serious. _________________ Ice Blue '67 Squareback |
Posted: Mon May 30, 2005 8:16 am Post subject: |
From what you describe, yes, it is a possibility. Have you checked your spark plugs lately?? You may just have a loose one. Also, check for exhaust leaks at the heads. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
