Nevada Notch Samba Member
Joined: May 02, 2005 Posts: 540 Location: Carson City Nevada
Posted: Sat Jun 04, 2005 11:41 am Post subject: Heat Exchangers |
New type 3 dummy here, if I am using an aftermarket header, will type 1 heater boxes work on a 64 notch? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Jun 04, 2005 3:41 pm Post subject: |
NO
Just about nothing external from a T-1 will work with a T-3. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Jun 04, 2005 9:39 pm Post subject: Type 3 dummy (heat exchangers) |
Thanks for the tip. Is there a body clearance issue or is it the attachment to the fan to the problem? |
Posted: Sat Jun 04, 2005 9:54 pm Post subject: |
Attachment to the fan housing, and the cooling tin under the engine. They also may not be the right length. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Jun 04, 2005 10:13 pm Post subject: |
Thanks again. Don't have heater boxes now but will probably looking for a pair in a couple of months. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22426 Location: Kimball, Mi
Posted: Sun Jun 05, 2005 8:20 am Post subject: |
Russ Wolfe wrote: |
Attachment to the fan housing, and the cooling tin under the engine. They also may not be the right length. |
Yup, all the above. The t-1 heat exchanger is about 2.5 inches too short on one side and closer to 3 inches on the other. I know, because I modified a set for my son (he asked me if I could try), but the right heater control cable keeps trying to ground out on the starter. I still have to fix that somehow. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ClareSutton Samba Member
Joined: December 05, 2004 Posts: 466 Location: Sarnia Ontario
Posted: Sun Jun 05, 2005 1:02 pm Post subject: |
There is a plastic cap that snaps over the starter connection that prevents the heater box cable from shorting out on the connection. Most newer type 3's have them (or at least the automatics do). You could probably rig up a cover from any plastic cap or rubber boot. |
Posted: Sun Jun 05, 2005 1:53 pm Post subject: |
It was just the automatics, but would work on others.
http://classicvw.org/gallery/just_stuff/dscf0002
There it is on a junkyard tranny w/starter.
If you want it bob, let me know.
I think I owe you anyway. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sun Jun 05, 2005 8:06 pm Post subject: |
I was just thinking I'd rework the arm on the heat exchanger, or even add a new piece to it to help it clear. I do appreciate the offer though Russ. But he's got a few other things going on with the car at the moment, so it's pretty low on the need to do list. Besides, he still needs to hook up the hoses to the body AND heat exchangers. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
