Grungeut Samba Member
Joined: June 12, 2005 Posts: 3 Location: tillamook, oregon
Posted: Mon Jun 13, 2005 10:33 pm Post subject: leaky fresh air vents |
i'm up here in the Northewest and two squarebacks have done the same thing. water leaks in through the fresh air vents below the windshield. does anyone else have this problem....and what do you do about it? any suggestions would be awesome. thanks |
SquareTone Samba Member
Joined: July 10, 2003 Posts: 1204 Location: Jenks, Oklahoma
Posted: Tue Jun 14, 2005 7:34 am Post subject: |
Search is always a good place to start.
You can run something flexible down the drain hoses to unplug them.
I also had to replace some missing screws that hold the boxes in place. |
69sqbck Samba Member
Joined: August 12, 2004 Posts: 311 Location: Savannah, GA
Posted: Wed Jun 15, 2005 5:49 pm Post subject: air vents |
I had the same problem with my 69 square. You need to make sure the drain lines (there are 2) are not full of crap. You can check this by pooring some water into each vent box and look under the car by the front beam. If nothing is coming out you have a pluged line. You can clean it out with some flexible wire or by using compressed air. Second you need to check the vent box seals. They are on the inside between the vent box and the cowl. You will have to remove the wiper motor and arms to get these out so be preparred for some fun. The vent box seals are more than likely shot dut to age and you cannot get replacement seals so I used a roll of windsheild tar seal. I rolled it in my hand to get it soft and plyable then set it on top of the old worn seal all the way arount the vent box. Then just put it back in and tighten it down good and snug. Some of the tar will come out on top through the vents so make sure you remove it right away. I have not had a drop of water in the car for over two years since I did this. Hope it helps... _________________ Don't think of yourself as an ugly person, think of yourself as a good looking Monkey!!!!!
1968 Ghia Vert
1969 Type 3 Squareback
1969 Type 3 Fastback
(o)\|/(o) Sole Designs, VW Restorations, Savannah, GA |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Wed Jun 15, 2005 7:43 pm Post subject: |
If the screens are deteriorated, check out the repair article for fresh air vents at www.type34.org _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
