Weak 36hp crank ??
WorkingClass
WorkingClass is offline
PostPosted: Tue May 24, 2005 7:10 am    Post subject: Weak 36hp crank ?? Reply with quote
I'm building a 36hp judson engine, but I'm know that the the original crank is weak.
Is a porsche 64mm stroker stonger than the Vw type?? or is it the same??[/b]
WorkingClass
PostPosted: Tue May 24, 2005 8:37 am    Post subject: Reply with quote
And Can I use (fit) both the 64mm stroke and the 74mm stroke porsche crankshaft??
Question
Teeroy Premium Member
Teeroy is offline
PostPosted: Tue May 24, 2005 8:53 am    Post subject: weak crank Reply with quote
With the 74mm , you will need to use Porsche rods(74mm has 53mm rod journals) , and you might need to clerance the case a bit . I'm helping a freind put together a 74x80 with Okrasa heads for his 58 Ghia . TROY
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
WorkingClass
PostPosted: Mon Jun 20, 2005 5:20 am    Post subject: Reply with quote
ThanX troy,
A 74mm stroker would to big i think. I maybe use a 64mm crank with bigger bore cilinders.
anyone knows if a 64mm porsche crank is the same or srtonger???
what is a better option.
A 74mm crank with (home made rod journals) standard cilinders OR
A 64mm crank with a big bore cilinder set
A 74mm crank will give me more piston speed but I'm not gonna rev my judson.
An other question i have in mind for more pressure
Is overdriving (bigger pully) an better option or more CR better??
