amishman Samba Member
Joined: March 09, 2004 Posts: 2888 Location: California
Posted: Fri Jul 08, 2005 7:35 pm Post subject: Don't know my greases? |
I purchased and used some Pennzoil 705 Multi-Purpose White Grease for when I did the shift rod bushing fix a while back. Made that shift rod push right thru. Probably good for prostate checks also
Anyway, is this same grease OK to use on my brake drum when I re-insert bearings back into the drum? Or, is it a different kind used for that purpose?
The stuf I have says it is NLGI #2 Water Resistant grease.
Thanks for answering a newbie question. I always see grease things up but never sure what exact greases I should use.
tj |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55680 Location: Long Island, New York, USA
Posted: Fri Jul 08, 2005 7:45 pm Post subject: |
White grease is OK for the asjusting screws and where the shoes contact the bscking plate.
But you should use a good synthetic "wheel bearing" grease (usually blue) on the wheel bearings. _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
radioman Samba Member
Posted: Fri Jul 08, 2005 8:21 pm Post subject: |
What Glenn said!  _________________ It's a Southern Thing, 73, stock.
Bill |
