Notchback doors.
Nevada Notch
Nevada Notch is offline
PostPosted: Sun Jul 24, 2005 11:18 pm    Post subject: Notchback doors. Reply with quote
Can anybody out there tell me if doors from a squareback or fasty fit on a 64 notch?
sofaking
sofaking is offline
PostPosted: Mon Jul 25, 2005 5:06 am    Post subject: Reply with quote
Depends on the hinges, if it is a 3 bolt hinge or a 4 bolt. otherwise they will fit.
Nevada Notch
PostPosted: Mon Jul 25, 2005 3:29 pm    Post subject: Reply with quote
What do you mean by either three or four bolt? My drivers door is a three bolt hinged door bolted to my 4 bolt hole configuration 64 body. One of the bolt holes in the bottom hinge does not line up with the body and there is no way to put a bolt in it. My passenger side door is the proper four bolt hinge patern. Any idea which cars or years the hinge changes were made? Are you saying that the overall shape and size of the doors is the same and that there are only variances in the hinge bolt patern? I know next to nothing about type 3's so any help is greatly appreciated!
sofaking
sofaking is offline
PostPosted: Mon Jul 25, 2005 5:06 pm    Post subject: Reply with quote
Yes, and it sounds like you need a 4 bolt for the driver side. And I'm not sure but I belive that all of 64 is a 3 bolt, my car is.
tomnotch
tomnotch is offline
PostPosted: Mon Jul 25, 2005 5:28 pm    Post subject: Reply with quote
4 bolt? like 4 bolts between 2 hinges? I that is the logic, then all notches have 6 bolt doors.
This subject is about a "once a month'er". Try a search as I think I have laid this out a couple of times.
Tom
DVKK
DSD, Dark Side Disciples
Progenitor
