slackin' at work Samba Member
Posted: Mon Aug 25, 2003 9:25 am Post subject: Stupid things you only did once.... |
I was thinking this weekend about all the stupid things I did while working on aircooled vws over the years. I only needed to do them once then learned my lesson... the hard way.
1. "Pump those brakes":
Always remember to put ON you drum before you check pedal pressure. boy that was a mess.
2. "Always be a stud":
while putting on a new 'high volume' oil pump, always use the studs and not longer bolts. It doesn't take much pressure on the cam gear to break your cam shaft in two.
3. "Rotor is as a rotor does":
When gapping your points, always remember to put you rotor back on. You'll spend and hour trying to figure out why it doesn't start.
4. "Voltage drop my ass":
Never assume semiphores can take 12volts.
They go up really fast... once.
I know I have some more. but these are the 'good ones' that sure bring back the memories.  |
Posted: Mon Aug 25, 2003 7:45 pm Post subject: |
oh yeah...
5. "that shiat don't wash off"
and I got a vw tattoo back in college. Now, when I take off my shirt, I feel as if VWoA is going to sue me.  |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5740 Location: Who in the what now?
Posted: Mon Aug 25, 2003 10:05 pm Post subject: |
I'll add one to that.
6. Forgetting the fuel cut-off position on the reserve valve. Actually had my car towed to a shop because of that... _________________ -Andrew
WTB: Kelly Vance Motors Plate Frame
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination. |
A.J. Adams Samba Member
Joined: August 20, 2003 Posts: 115 Location: Stroud, United Kingdom
Posted: Wed Aug 27, 2003 6:10 pm Post subject: |
| 7. Once owned a Ford. |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6397 Location: Rio Rico Arizona
Posted: Wed Aug 27, 2003 6:36 pm Post subject: |
| 8. Asking my son to turn the ignition switch to the on position to check for 12v at the backup lights without disabling the starter. It fired, ran, and launched off the hoist into the tool box, but nobody got hurt. Totally my fault too. |
6d6vdub Samba Member
Joined: August 08, 2003 Posts: 449 Location: Jacksonville, nc
Posted: Thu Aug 28, 2003 9:07 am Post subject: |
| I second owning a Ford. |
79SuperVert  Samba Member
Joined: May 31, 2002 Posts: 8258 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Fri Aug 29, 2003 6:36 am Post subject: |
| 8. Not realizing the car was going to tilt off the jacks and into the wall of the garage while I was stupidly pumping away at the lift handle while staring off into space. |
Posted: Fri Aug 29, 2003 6:37 am Post subject: |
| 10. Not knowing that after 8 comes 9, not 8. |
TimGud Samba Member
Posted: Fri Aug 29, 2003 6:57 am Post subject: |
| 10. Starting an engine without a carburetor by putting some fuel down the intake to see what happens. |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2400 Location: ontario canada
Posted: Fri Aug 29, 2003 9:58 am Post subject: |
adjusting throttle on a running engine while wearing a tie- the air cleaner leaves a funny bruise on your forehead when you get pulled in at 3500 rpm. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
6v Samba Member
Joined: February 01, 2002 Posts: 213 Location: Vancouver, WA
Posted: Fri Aug 29, 2003 1:58 pm Post subject: |
that's what you get for wearing a tie.
Fixed a starting problem, got in, turned the key, freaked out when nothing happened, then realized that I forgot to hook the battery back up. _________________ Just Because You Can, Doesn't Mean You Should. |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2528 Location: Edmonton, AB
Posted: Fri Aug 29, 2003 6:10 pm Post subject: |
| Running out of gas and then forget to put the air cleaner back on after priming the carb, car backfires and spews burning gas all over the engine compartment, including behind the fan shroud. 5 minutes later no more car. |
vintage vee dub Samba Drag Racer
Joined: July 03, 2003 Posts: 601 Location: pumpkinville
Posted: Sat Aug 30, 2003 12:10 pm Post subject: |
| bljones wrote: | | adjusting throttle on a running engine while wearing a tie- the air cleaner leaves a funny bruise on your forehead when you get pulled in at 3500 rpm. |
dude you did not really do that did you ?
hooking the oil breather line from the filler to the port on the fan shroud then wondering why my engine leaks oil from all over the place _________________ OG JHC
www.volksfab.com
www.nidraracing.com
www.morrisraceengines.com |
Ratt Samba Member
Joined: April 15, 2003 Posts: 548 Location: Ballston Spa, NY
Posted: Sat Aug 30, 2003 6:11 pm Post subject: |
Cranked the engine for a good 20 minutes, trying to figure out why it wouldnt start. Well I figured out that the Distributer needs to be seated and the rotor installed before spark will reach the plugs.
Also I drove a good 2 miles befor I remembered to tighten the lug nuts. That one I have to say is the worse one yet.
Andy Rattley |
der winkermeister Samba Member
Posted: Sun Aug 31, 2003 2:38 am Post subject: |
Tried to downshift into first gear after losing the clutch pedal, thinking I could try to shift down with rpm`s as you can with a broken clutch cable (it was an old trick VW`s people did when losing clutch cable`s back in Germany, rpm`s up and down, and gas on and off kinda as you would double clutch a crashbox).........
Well, it was`nt the clutch cable it was the throw out bearing....I lost 1st gear and reverse in my 56 Oval
Now anytime I get that clutch probs or transmission, it`s coast over to the side of the road and let it rest for a while keep your kool and check it all out
Lesson learned
Der Winkermeister
Vintage Square Window Owners Society 1958-61 VSWS
President |
E-boyz67  Samba Member
Posted: Sun Aug 31, 2003 3:21 pm Post subject: |
Trusting a friend when he says he knows how to install the flywheel and clutch. Stupid me not making sure its done right. Then we take it for a drive and when I get on the gas theres a loud thumping sound and vibration. When we got back I tried to figure out whats up as I put my tools away, what do you think I find next to the socket? Why its the gland nut washer. You guys know then what happens when theres no glasnd nut washer? Try it and see
Posted: Sun Aug 31, 2003 4:32 pm Post subject: |
yeah, i actually did that. happened on my way home from a job interview many years ago. since then i reserve ties for weddings, funerals, and important anniversaries. _________________ OG JHC
2% |
TimGud Samba Member
Posted: Sun Aug 31, 2003 6:48 pm Post subject: |
| Turned into a black tie evening did it? |
Posted: Sun Aug 31, 2003 9:23 pm Post subject: |
damn near a black eye evening _________________ OG JHC
2% |
crukab Samba Chef
Joined: December 13, 2002 Posts: 3558 Location: Vermont
Posted: Mon Sep 01, 2003 5:54 pm Post subject: |
Last time I had to wear a tie was at my wedding-June 1985!
Heres a dumb ass move -- left my 72 vertble. Bug in reverse when dick'en around with the flexi heat tubes- heater box to car area- the big screw driver I was useing touched the starter- BOTH terminals, Yep the sucker stared lurching bacwards- OFF the floor jack- acrossed my chest and out into the driveway, lucky I moved fast to miss the front tires crushing my head, scared the hell out of my wife when I came in the house with tire track across my jacket !!!!!
Tom  _________________ '65 Bus/Panel/camper W/T/Shed
'66 Singlecab
'66 Westy
'82 Rabbit Truck
'86 Doublecab W/T
and others. |
