Need help with clutch cable replace
Waltsbrian
Waltsbrian is offline
PostPosted: Sun Aug 07, 2005 6:03 pm    Post subject: Need help with clutch cable replace Reply with quote
Hi Yall!
Ok don't laugh but I've pulled the guide tube out of the tunnel by accident and it was just enough that I couldn't get the end of the guide tube to go back into the right position so that I can feel the end of the tube through the access hole (pedal hole); Thus I am not able to feed the end of the cable into the guide tube. Anyone have any advice?
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Aug 07, 2005 6:29 pm    Post subject: Reply with quote
That tube should not be loose at all in the tunnel. It is welded in 3 places from the factory. Sounds like you will need to open the tunnel and get a little welding done.
Gary: OK. Ima poop.
Waltsbrian
PostPosted: Wed Aug 10, 2005 8:02 pm    Post subject: Reply with quote
So what you're saying is: I shouldn't be able to pull the whole thing out the backend.....
Russ Wolfe
PostPosted: Wed Aug 10, 2005 8:33 pm    Post subject: Reply with quote
Nope, the metal tube is welded in from the factory.
Now, the flex portion over the tranny is removable.
Gary: OK. Ima poop.
