Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Aug 21, 2005 9:49 am Post subject: |
COFBack wrote: |
Took her for a spin, didn't have any problem holding 60-65 heading up from Colorado Springs (6k ft) to Monument Pass (about 7.5K ft). Comfortable drive between 65-70 on the flats. Not quite as much poop as I expected at slow speeds (even after you get by the hesitation) but hopefully getting the carbs squared away will help this.
Any thoughts?
thanks
RMS |
Get rid of the OH OH nine. That will get rid of most of your hesitation off the line. Put your original T-3 FI distributor in and forget the vacuum advance. The FI distributor has one of the best performance advance curves you can find.
What is happening, is that the 009 is advancing too soon. It was designed as a dist. for an industrial engine, that ran at a constant RPM. The advance comes in very quick to get the power early. The FI distributors are designed to be driven on the street.
http://classicvw.org/gallery/IgnitionManual/ignition_system_manual_017
http://classicvw.org/gallery/IgnitionManual/ignition_system_manual_018 _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Tue Aug 23, 2005 9:50 am Post subject: |
Russ
Thanks for the info, will look into the replacing the 009. I really don't want to mess with points though. I'm a true believer in electronic ignition after dropping a chevy HEI in my 73 Jeep.
I'm not sure if the Compu-fire will work with the stock distributor.
I'm off for 5 days in the mountains. Fly fishing and drinking so it will be a while before I can get down to business on the fasback.
thanks again
RMS |
